x4smile
unable to update an article in the folio …
Jan 18, 2012 5:43 AM
Error:
"InDesign says that the file couldn't be found for the layout." Has anyone the same problem?
Fehler:
"Während der Aktualisierung des Artikel-Layouts ist ein Fehler aufgetreten.
Die InDesign-Datei für das Layout wurde nciht gefunden."
Hat jemand das gleiche Problem oder eine Lösung?
Vielen Dank im Voraus
    Jan 18, 2012 6:37 AM   in reply to x4smile
    I have seen that error and it happened when I saved over a file in an article with a new version. The fix was to delete the article and reimport it.
    Bob
  • Bob Bringhurst
    May 29, 2007
    Jan 18, 2012 7:08 AM   in reply to Bob Levine
    You can also use the new Relink option in the updated Folio Builder panel to relink the article to its source layouts.
    May 2, 2012 2:43 AM   in reply to x4smile
    i have the exact same problem, but relinking doesnt help. restarting indesign doesnt help. deleting the folio and trying to rebuild everything doesnt help either.
    why the hell doesnt he find the file which i apparently have already open?
    the whole digital publishing suite is a pain to use so far, sorry
    ps: after reboot it worked. wtf?! as this problem frequently happens, this is quite a bad workaround.
