Pixel bender Vignette circle to elepsis
Jan 18, 2012 3:39 AM
Hi Everyone, Im pretty new to PB and am tweaking a file to use in a Flash project. My problem is creating a new paremeter which distorts the circular vignette to an eleptical one. Increasing the blurWidth Size should increase the width (not height) of the focal point making it wide, can anyone point me in the right direction? Many thanks Code so far is below.
<languageVersion : 1.0;>
kernel ZoomBlurFocus
    namespace : "com.abril";
    vendor : "Daniel Allegretti";
    version : 1;
    description : "Ajustable zoom blur, you can control focal size, edge hardness and light. Based on ZoomBlur by Ryan Phelan.";
    parameter float amount
        minValue:0.0;
        maxValue:0.5;
        defaultValue:0.25;
    parameter float2 center
    minValue: float2(0.0);
    maxValue: float2(900.0);
    defaultValue: float2(200.0);
    parameter float focalSize
    minValue: 0.0;
    maxValue: 500.0;
    defaultValue: 100.0;
    parameter bool invert           // TODO: nada de boolean
    defaultValue: false;
    parameter int invert
    minValue: 0;
    maxValue: 1;
    defaultValue: 0;
    parameter float vignette
    minValue: 0.0;
    maxValue: 1.0;
    defaultValue: 0.6;
    parameter int blurWidth
    minValue: 0;
    maxValue: 2;
    defaultValue: 1;
    parameter float edgeHardness
    minValue: 0.0;
    maxValue: 1.0;
    defaultValue: 0.0;
    input image4 src;
    output pixel4 dst;
    void evaluatePixel() {
        float str = 1.0 - vignette;
        float2 coord = outCoord();
        float cur_radius = length(coord - center);
        pixel4 color = sampleNearest(src, coord);
        int cond1 = (cur_radius > focalSize) ? 1 : 0;
        if(invert == 1) {
            //cond1 = !cond1;
            if(cond1 == 0) {
                cond1 = 1;
            } else {
                cond1 = 0;
        float strength;
        if(invert == 1) {
            strength = cur_radius / focalSize;
        } else {
            strength = focalSize / cur_radius;
        float tmpAmount = strength * amount;
        coord -= center;
        pixel4 tmpDst = float4(0.0);
        float scale;
        scale = 1.0;
        tmpDst += sampleNearest( src, coord*scale + center );
        scale = 1.0 + tmpAmount * (1.0/14.0);
        scale = 1.0 + tmpAmount * (2.0/14.0);
        scale = 1.0 + tmpAmount * (3.0/14.0);
        scale = 1.0 + tmpAmount * (4.0/14.0);
        scale = 1.0 + tmpAmount * (5.0/14.0);
        scale = 1.0 + tmpAmount * (6.0/14.0);
        scale = 1.0 + tmpAmount * (7.0/14.0);
        scale = 1.0 + tmpAmount * (8.0/14.0);
        scale = 1.0 + tmpAmount * (9.0/14.0);
        scale = 1.0 + tmpAmount * (10.0/14.0);
        scale = 1.0 + tmpAmount * (11.0/14.0);
        scale = 1.0 + tmpAmount * (12.0/14.0);
        scale = 1.0 + tmpAmount * (13.0/14.0);
        scale = 1.0 + tmpAmount * (14.0/14.0);
        tmpDst /= 15.0;
        if (cond1 == 1) {
            dst = ((1.0 - edgeHardness) * ((color * strength) + (tmpDst * (1.0 - strength)))) + (tmpDst * edgeHardness);
            dst.rgb = ( vignette * dst.rgb * strength ) + ( dst.rgb * (1.0 - vignette) );
        } else {
            dst = color;
        dst.a = color.a;
    Jan 19, 2012 3:56 PM   in reply to WChristian
    I'm not totally sure what the effect is that you're going for, but as soon as you mention ellipses you're going to need to use separate scaling values for the x and y values of the sampling coordinates.
    Bob
    Feb 16, 2012 8:55 AM   in reply to WChristian
    If you change your scale variable from a float to a float2, then the x,y components of should scale the width/height of the effect...
