Okay, well I tried that but no change. Being left with a totally non-functional LR4, I wanted to get back to the state I was in before troubleshooting, i.e. being able to work in all but the Book module. I trashed the beta and its catalog, put back my original Lightroom folder, reinstalled LR4 and let it create a new catalog. Unfortunately, that didn't help and I can not use any of the modules. *sad face*
Hey Julie, if you happen to have that old preferences file, I'd be curious to look at it (along with the fresh, working ones) to see if it gives me more clues as to what is wrong.
If not, no worries. I do still have a couple of traceback clues to follow, but I still haven't quite figured out what conditions would allow the error I saw in your log to occur.
Thanks! -- DT
Quick question. I've been puzzling over a difference in the call pattern shown in your log and what I see when I run it myself.
Sorry if this was already answered already, but what do you have selected in Library when you (try to) enter the book module? I think the source type (smart collection, whether the library filter bar is active, etc) might influence the order of operations in a way that affects whether this bug manifests or not. Just a hunch.
Thanks -- DT
Dan
Not sure if this is the correct address to send this to. Not even sure which logs you want so here is a copy of all message from console. All I did was start Lightroom 4, attempted to select book module, got the error "An error occurred when attempting to change modules", then tried to select library and got the same error.
Feel free to coach me on how to extract the most useful logs.
Brian
MacBook Pro running 10.7.2
The logging I've been using to confirm cases of the same bug is emitted to the console when running Lightroom from Terminal.app (in /Applications/Utilities) with the -tracebacks option like this:
/Applications/Adobe\ Photoshop\ Lightroom\ 4.app/Contents/MacOS/Adobe\ Photoshop\ Lightroom\ 4 -tracebacks
That said, so far I haven't figured out what causes the errors that are being thrown.
There's some detail I haven't figured out that perturbs the module switching sequence and makes it blow up.
DT
Hi Dan, Victoria,
I was wondering if I might get a workaround for the same book module problem? I created a new user account and it runs fine in there. I tried copying the Lightroom file over to my main account but still doesn't work and I am not sure how to repair the permission as p.roehl has done.
I would really like to use the book module in my main user account.
Thanks so much,
Kim
I am having the same problem. I have tried everything here and everything else I can think of but i a;ways get the same error when I attempt to load the book module.
If I create a clean account it works fine, but attempting to copy the support folder back doesn't work. Changing the permissions doesn't work. I've even deleted the Lightroom folder in the application support folder, re installed the application and it still doesn't work.
I do have the Nik software suite installed, so I'm not sure if that's the issue, but removing the entries from the external editors folder doesn't work either.
Your help would be greatly appreciated as I would really like to try out the book module
I think to copy the folder will not help since the "owner" of the Folder would be incorrect.
What I did is the following, requires a little Unix Shell knowledge...
Started a Terminal Session:
Than:
cd Library/Application\ Support/Adobe/
than:
ls -al
result like
drwxrwxrwx 3 peter 502 102 27 Jan 12:02 Fonts
drwxr-xr-x 33 peter 502 1122 27 Jan 13:08 Lightroom
drwxrwxrwx 4 peter 502 136 15 Feb 2006 Linguistics
drwxrwxrwx 3 peter 502 102 20 Mai 2008 LogTransport
Check for Lightroom.
In my case the Owner (3rd colum) was not me (peter)
To change this type:
sudo chown -R peter:502 Lightroom
Replace peter with the correct user, look at the other Folders.
You will be asked for a password since it requires root privileges and it will change the owner of that folder to yourself and will also work thru sub-folder.
to check type again and look for Lightroom:
ls -al
Now the owner of Lightroom should be you...
I hope that helps.
Regards
Peter
All the subfolders in my Lightroom folder inside the Appleication Support folder are owned by me and have read write privelages for everyone. I even tried removing the flder and letting Lightroom create a new one but to no avail. I've tried trashing the preference and I've tried creating a new catalogue. All to no avail. And yet it works in a clean user?
Here's what comes up in the console when you try to change modules:
28/01/2012 21:34:15.150 Adobe Photoshop Lightroom 4: CFURLCreateWithBytes was passed these invalid URLBytes: '/Applications/Adobe Photoshop Lightroom 4.app/Contents/Frameworks' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateFromFileSystemRepresentation should be used instead.
28/01/2012 21:34:15.204 Adobe Photoshop Lightroom 4: CFURLCreateWithBytes was passed these invalid URLBytes: '/Applications/Adobe Photoshop Lightroom 4.app/Contents/Frameworks' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateFromFileSystemRepresentation should be used instead.
28/01/2012 21:34:15.273 Adobe Photoshop Lightroom 4: CFURLCreateWithBytes was passed these invalid URLBytes: '/Applications/Adobe Photoshop Lightroom 4.app/Contents/Frameworks' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateFromFileSystemRepresentation should be used instead.
28/01/2012 21:34:18.946 Adobe Photoshop Lightroom 4: Performance: Please update this scripting addition to supply a value for ThreadSafe for each event handler: "/Library/ScriptingAdditions/SIMBL.osax"
28/01/2012 21:34:43.622 Adobe Photoshop Lightroom 4: Failed to restore first responder (message was inputContext) NOT KEY
28/01/2012 21:34:45.542 Adobe Photoshop Lightroom 4: Failed to restore first responder (message was inputContext)
28/01/2012 21:34:46.479 Adobe Photoshop Lightroom 4: Failed to restore first responder (message was inputContext)
28/01/2012 21:34:47.520 librariand: client connection is invalid: Connection invalid
Not sure if that hellps in the troubleshooting process but anyway!
Thomas
Ok, I figured it out
the problem (for me anyway) was a corrupt font. Or at least a font that Lightroom doesn't like.
If you go to your users library folder and look in the fnts folder. Quit Lightroom and Drag everything out to a temporary folder and try LR4. If that works, then you will have to go through a process of elimination by dragging back a couple of fonts at a time and re-launching lightroom
Hope this helps!
Thomas
Hi Thomas, I spoke too soon. I tried putting some fonts back into my user font folder and now then the module changing error as soon as I launch Lr rather than only when trying to access the book module. Then I put all the fonts back where they were before and continue to get the error on launch. I don't know where that leaves me but maybe it will help Dan Tull troubleshooting this. I hope.
Wow. That's it! Thank you Thomas!
For purposes of debugging, the font is called aescrawl.ttf. What's interesting is that when you look at the font info, the full font name is Aenigma Scrawl, but in some parts of the font info, its being registered as ∆nigma Scrawl. It generates a name table useability caution when I validate it in fontbook. It's a freeware font, easily downloadable if anyone wants to check out what the specific problem is.
Julie, Did you try taking the fonts all out again?
Thomas...Thanks so much!
That worked for me too. I have a folder right below fonts called fonts disabled and I dragged the whole lot into that. I restarted lightroom and it opened up the book module!
I have so many fonts in there that figuring out the corrupt one will be the next challenge.
Kim
Thanks! ...It didn't take long to find the font causing my book module problem...cafenorden.ttf
It looks ok but when I click it to see it, the e has turned into a question mark so maybe the odd character too. The font below it, Mom.ttf also has an odd character and although it wasn't crashing the book module, it is not showing up in the lightroom 4 beta font list when I dragged it into the fonts folder.
Maybe a picture is worth a thousand words...here is a screen shot...
...as per Thomas's suggestion I dragged all the fonts from Fonts into Fonts Disabled, then as artemesia suggested, I tried a few at a time to narrow down the bad font. Hope this works for you Julie and anyone else having problems with the Book Module.
