Hi all,
I have some unsolved questions about selections, I have panel, ASB, CSB, layoutSelectionBoss and so on:
Thank you in advice
In order to create your own selection suites you need to follow the following steps.
1. Create an interface for the selection suite and place it as an AddIn in the IntegratorSuite and the suite boss that you need to extend. Like for layout you could use the kLayoutSuiteBoss.
2. The implementation for the interface added in the IntegratorSuite will be the ASB implementation, the code for this is pretty much templated, refer SDK sample code to have an idea about it.
3. The implementation for the interface added in the other suite boss will be the CSB implementation. Inside this class you can write the code specfic to your needs.
Regading the call on this code and how do you get your code executed, first you will have to get the selection manager interface which is generally obtained from the activeselection but there are other ways too refer the SDK for it. From this selectionmanager interface query the interface of your suite and if your suite is available you can call it's method else you will get a nill pointer.
I think this should make it pretty much clear, for more clarifications refer the SDK samples and the programming guide.
Manan Joshi
- Efficient InDesign Solutions -
MetaDesign Solutions
http://metadesignsolutions.com/services/indesign-development.php
Thank you for that explanation, it was wery useful ![]()
I have one more question:
In my LayoutCSB I would like to get SeletionHeight, for this, there is GetSeletionHeight in IGeometrySuite. Am I right?
So this method should look like that:
int STSuiteLayoutCSB::SelectionHeight()
InterfacePtr<IGeometrySuite> mySuite(this, UseDefaultIID());
return mySuite->GetSelectionHeight();
this will result in problem...
In IGeometrySuite are these two methods:
virtual void GetSelectionHeight( Transform::CoordinateSpace boundsSpace, Geometry::BoundsKind boundsKind, Transform::CoordinateSpace measurementSpace, K2Vector<PMReal>& results) const = 0;
virtual void GetSelectionHeight( Geometry::BoundsKind boundsKind, Transform::CoordinateSpace measurementSpace, K2Vector<PMReal>& results) const = 0;
Iam a bit confused, how to use these methods, could you please help me here?
thank you in advice
What exactly do you want, from what i see from Pickory's code is you are trying to get the height of the bounding box of the current selection in the layout. For ex if you have three image boxes selected you need the height of the bounding box that encloses all these image boxes. Kindly clarify so that we can provide better pointers for the solution.
Manan Joshi
I want get height, width and position of selected frame on page. I know that every time would be selected only one frame.
Right now I have done step one(according to your answer) and now Iam fighting with step two, i found some samples in sdk, so Iam trying to understand what kinds of methods I would need to write in ASB and how would they be implemented in CSB.
I thing method in ASB for height of selected item would look like this:
void STSuite::GetSelectionHeight(Geometry::BoundsKind boundsKind, Transform::CoordinateSpace mesurementSpace, K2Vector<PMReal> &result)
CallEach(make_functor(&IGeometrySuite::GetSelectionHeight, boundsKind, mesurementSpace, result), this);
After that I need to write its implementation in CSB. That would be consisted of these steps: get IGeometry InterfacePtr and call method GetSelectionHeight. Am I right?
thanks
So I have mooved on,
Right now I have my method in ISTSuite, in ASB and now I would like to create that method in CSB. Could you help me little bit with its implementation, please? I would like to get height of selected item. I know that this can be obtained from IGeometrySuite, so I will create InterfacePtr on IGeometrySuite and next?
Thank you in advice,
Finaly, I have code for obtaining width and height working perfectly!! Thanks again ![]()
I have 2 last questions:
1. If I would like to get x coordinate of left top corner of selection, which interface pointer I should get (on which suite?)?
2. almost same question, but I would like to get page on which is selected content.
Thanks again ![]()
if you wrote the code in accordance to what Pickory had hinted then the PMRect itself has the the top() method that will give you the X coordinate of the top left corner
And for the 2nd question you will can use the method "GetOwnerPageUID" in the "ILayoutUtils", but this method will return the UID of the spread if the pageitem does not lie on a page so make a check for that too.
Manan Joshi
I was not able to use Pickory's code, because it gave me error.
void STSuiteCSB::GetSelectionPositionX(K2Vector<PMReal> &result)
InterfacePtr<IGeometry> iGeometrySuite(this, UseDefaultIID());
if (iGeometrySuite == nil) {
ASSERT_FAIL("Error");
PMMatrix inner2parent = InnerToParentMatrix(iGeometrySuite);
PMRect boundsInParentCoords = iGeometrySuite->GetStrokeBoundingBox(inner2parent);
I know that InnerToParentMatrix is a method from TransformUtils.h, but when I use #include "TransformUtils.h" I get following error:
Undefined symbols:
"typeinfo for ISTSuite", referenced from:
typeinfo for CPMUnknown<ISTSuite>in STSuiteASB.o
ld: symbol(s) not found
collect2: ld returned 1 exit status
When I dont include header for utils, i cant call InnerToParent...
I have been trying all possible combinations and still got errors...
Regarding point 2.
I have:
Utils<ILayoutUtils> iLayoutUtils; that is easy, right now I would like to call its method GetOwnerPageUID as you mentioned earlier, but first argument (as it is in documentation) is const IHierarchy *pageItemHier. I Have tried to do this:
iLayoutUtils->GetOwnerPageUID(IHierarchy::QueryChild(0), kFalse); Iam wondering how to call this method ...
You should call it like
iLayoutUtils->GetOwnerPageUID(IHierarchy, kFalse);
Where IHierarchy is the interface of the pageitem, if you use querychild then you are moving into the pageitem like for ex in to the image in a pageitem.
Manan Joshi
This works for me fine, maybe the interface that you are sending is not correct. UID 0 represents the document if i remember correctly. See the code that you are using to get the IHierarchy interface.
Manan Joshi
This would return a null interface as you did not query the interface from any boss class, you need to get this interface from the selected pageitem's boss class.
Manan Joshi
Ok, the selection would be some frame, so what is the best boss to get interface pointer? What about selection manager?
SelectionManager* iSelectionManager = iSelectionUtils->GetActiveSelection();
if (iSelectionManager != nil)
InterfacePtr<ISTSuite> mySuite(iSelectionManager, UseDefaultIID());
InterfacePtr<IHierarchy> iHierarchy(iSelectionManager, UseDefaultIID());
or is there anything that iam missing?
If you are writing this code inside the CSB method then you can query for "ILayoutTarget" interface that has "GetUIDList" method which will give you the UIDList of the selected page item. From this you can get the UIDRef of the selected pageitem, which can be quried to get the correct iHierarchy interface.
If you are writing this code outside CSB method then write a method in the CSB to get the UIDRef of the selected page item and do as before.
Hope this is not very confusing.
Manan Joshi
I have this:
void STSuiteCSB::GetSelectionPage(K2Vector<PMReal> &result)
InterfacePtr<ILayoutTarget> iTarget(this, UseDefaultIID());
if (iTarget == nil) {
ASSERT_FAIL("Error in iTarget");
cout << "Error in iTarget";
UIDList selectionList = iTarget->GetUIDList(kStripStandoffs , kDontStripIfParentLocked);
UIDRef item = selectionList.GetRef(0);
cout << "Number of items in seleciton list:";
cout << selectionList.Length() + "\n";
InterfacePtr<IHierarchy> iHierarchy(item, UseDefaultIID());
from this i cannot get anything useful ...
Hi all,
Iam sorry for opening this thread again, but I finally have some time to rollback to this issue with getting page of selected item(frame). I know how the system should work, but I am not albe to get everything working, I have something wrong in implementation. I was searching thru google for some tutorial or some sample project, but no luck at all, does anyone knows about some material where I should learn about this??
What I want to do - when user click on button in my plugin I want to show him, on which page is selected frame. Everytime there always will be only one frame selected not more. About my implementation, as I wrote before I have SuiteCSB, SuiteASB, SuiteLayoutCSB and the ButtonAction.cpp files. I would like to call from ButtonAction method on interface, getPage. Method get page must be defined in SuiteCSB and its implementation should be in SuiteLayoutCSB?? How does the definition of this method should look like??
Thank you all in advice
