Replies 1 2 Previous Next
    Jan 25, 2012 8:26 AM   in reply to MurraySummers
    awww....let me try changing them. Should it be caps or uncaps? or that doesn't matter?
    But some tabs, like marketing, program, tradeshow are just one words with no spacing. But they are still not working correctly
    Jan 25, 2012 8:43 AM   in reply to zDesign3
    All lowercase is the best, but caps/no caps really makes no difference at all - it's important though that if you use caps, you must ALWAYS use them because on *nix servers, Foo.jpg and foo.jpg are two different files.
    Jan 25, 2012 8:56 AM   in reply to MurraySummers
    I removed all the spaces with underscore and all the caps to no caps... but still same problem..
    And I thought I had everything under control....  :-(
    Do youknow what else could be the problem?
    Jan 25, 2012 9:22 AM   in reply to zDesign3
    Make sure you adjust this line in your javascript to match the new names (for files and folders) -
    var g7url="images/Menu Tabs/about_us.png"
    Jan 25, 2012 9:56 AM   in reply to MurraySummers
    Its working now! Thanks Murray!
    Jan 25, 2012 10:58 AM   in reply to zDesign3
    When the code is right, it works!
1 2 Previous Next
