Milko Schiopetto
export data and attached files
Jan 25, 2012 8:05 AM
hello
i know that i can export data to xls or csv format: do i need to manually download each embedded files or there is an automatism to do it ?
tx, milko
  • Randy Swineford
    Mar 7, 2011
    Jan 25, 2012 8:33 AM   in reply to Milko Schiopetto
    You can only download them manually using the File menu. When you say "automated" - what would you like the product to do exactly?
    Randy
  • Randy Swineford
    Mar 7, 2011
    Jan 25, 2012 10:11 AM   in reply to Milko Schiopetto
    Are you using Adobe Acrobat (PDF forms) or Adobe FormsCentral (which does HTML forms)? You mentioned "acrobat form" in your email so I wanted to make sure we are talking about the same thing.
    Randy
    Mar 7, 2012 8:50 AM   in reply to Milko Schiopetto
    I have the same question (at least what I understand his original one to be):
    Lets assume that I have a list of 100 respondants, that each have a file acttachment.
    Can these file attachments be exported/downloaded all at once with the spread sheet via File>Export Responses, or by means other than having to download each attachment indivudually?
    Thanks.
    Joe
  • Randy Swineford
    Mar 7, 2011
    Mar 7, 2012 8:53 AM   in reply to JCMake
    Select all of the cells with attachments you want to export. Right-click and choose Download selected. All of the files will be downloaded into a single ZIP file.You can also prepend a field value so you can tie them back to the form.
    This post explains in more detail: http://forums.adobe.com/thread/934728
    Randy
    Mar 7, 2012 8:57 AM   in reply to Randy Swineford
    Thanks Randy.
    The prepending feature is big deal. Great stuff.
