Close document after background export to PDF
Jan 6, 2012 9:20 AM
Hello all,
I've javascripting InDesign for about a year. My job is almost completely automated now.
However, something is eluding me.  When I export a document to a PDF, I have a script that adds the export to a queue (aka a background task). It exports to 3 different places (two back-up folders and the desktop). However, one server is slower than the others and when I use myDocument.close() at the end of the script, InDesign gives me a message that says it can't close the document because it is being used by a background task. Here's the code:
myDocument.asynchronousExportFile (
     ExportFormat.pdfType,
     File (desktopFolder.fsName+"/"+pdfFile),
     false
myDocument.close();
Ideally, what I'd like to do is add some sort of event listener to wait for the background tasks to complete before closing the document. But, not affect the ability to move on to other tasks while the export is happening. How do I do that??
-Mike
    Jan 6, 2012 4:53 PM   in reply to BreachofMind
    Hi Mike.
    Here is an example of capture export event:
    #targetengine session
    (function() {
        app.addEventListener("afterExport", function(evnt) {
            var task, listener;
            task = app.idleTasks.add({ name: "exportPDF", sleep: 1000});
            listener = task.addEventListener(IdleEvent.ON_IDLE,
                function(ev) {
                    listener.remove();
                    task.remove();
                       if (/Adobe\sPDF/.test(evnt.format)){
                           app.activeDocument.close (SaveOptions.YES);
            }).name = "exportPDF";
        alert("custom exporter installed.");
    If you want stop listener, run below:
    #targetengine "session"
    myListener = app.eventListeners.itemByName("exportPDF");
    if (myListener.isValid) {
        myListener.remove();
        alert ("custom exporter removed." )
    ...or you can disable background export. You can read as reference below:
    http://forums.adobe.com/message/3689090#3689090
    Ten.
    Jan 7, 2012 1:11 AM   in reply to Ten A
    @Ten: the "old" exportFile method is still available.
    So, if you want to export to PDF without a background task you could do it like this:
    myDocument.exportFile (
         false
    myDocument.close();
    But I think Mike did deliberately choose the "asynchronously" variety…
    Uwe
    Jan 13, 2012 12:46 AM   in reply to BreachofMind
    Hi Mike.
    Your code works fine in my environment. But I think better to kill Listener each time automatically.
    function Listen () {
        app.addEventListener("afterExport", function(evt) {
            var task = app.idleTasks.add ({name:"exportPDF", sleep: 1000});
            var listener  = task.addEventListener (IdleEvent.ON_IDLE, function(e) {
                listener.remove();
                task.remove();
                if (/Adobe\sPDF/.test(evt.format)) {
                    myDoc.close(SaveOptions.YES);
                    app.eventListeners.itemByName("exportPDF").remove(); //kill listener.
                    //alert ("custom exporter removed.")
            //alert ("Custom exporter installed.");
    //my test parameters.
    var myDoc = app.activeDocument;
    pdfFile = "/test10.pdf";
    Listen();
    myDoc.asynchronousExportFile(
    File (pdfFile),
        false
    Event classes dropped from Object Model Viewer. But we can correct props ourself like below :
    var str ="";
    for (var a in Event) {
        str += a + "\n";
    alert(str);
    But I think best way of reading Object Model, download and read Jongware's CHM file. Check below link.
    http://forums.adobe.com/thread/668578
    @Uwe : Thank you for your information.
    Ten
  • John Hawkinson
    Jun 25, 2009
    Jan 13, 2012 9:59 PM   in reply to Ten A
    var str ="";
        str += a + "\n";
    alert(str);
    Eww!
    Just use reflection:
    alert(Event.reflect.properties.join("\n"));
    Jan 25, 2012 7:10 PM   in reply to BreachofMind
    Hi Mike,
    We can do that, simply counting finished time. But regular variables lost value when functions finished.
    So I try to use closure and it works, see below:
    function Listen (num) {
        var flg = (function (){  //closure
            var _f = 1;
            return function(){return _f++;}
                listener.remove();
                task.remove();
                if (/Adobe\sPDF/.test(evt.format)&&flg()>num) {
    //test
    var svLen = 3; //document length
    Listen(svLen-1);
    for (i=0;i<svLen;i++)
    myDoc.asynchronousExportFile(ExportFormat.pdfType,File ("/test" + i + ".pdf"),false);
    Ten
    May 20, 2013 7:48 AM   in reply to Ten A
    Hi Ten,
    I can't get this to work....
    Script is able to close only one document after exporting to pdf.
    Also - when I open 3 different documents, script generates 3 the same pdfs from one of opened docs.
