cupojoe88
Mobile Twitter defaults to Web Twitter
Nov 18, 2011 9:30 PM
Tags: #twitter #digital_publishing_suite
I'm using the http://mobile.twitter.com URL and in Preview it looks fine and pulls from the mobile site. However when I publish it to my iPad it pulls the stream from the regular Twitter site and the content takes up more horizontal space than the container.
Any thoughts??
    Nov 19, 2011 5:03 AM   in reply to cupojoe88
    For twitter feeds, I use a widget from here.
    Bob
    Nov 19, 2011 11:34 AM   in reply to cupojoe88
    Sorry. I thought I added the link to my reply.
    http://twitter.com/about/resources/widgets
    Bob
    Nov 19, 2011 2:01 PM   in reply to cupojoe88
    No. Read the directions.
    You need to paste that code into the body of a valid HTML page.
    FWIW, I just create a new HTML page in Dreamweaver and copy the code in. Save as HTML and link to that file.
    Bob
  • Bob Bringhurst
    May 29, 2007
    Nov 20, 2011 5:58 PM   in reply to cupojoe88
    Make sure that the HTML file is in its own folder. If the HTML file is in, say, the Documents folder, the entire contents of the Documents folder (and all subfolders) is uploaded as part of the HTML.
    Nov 20, 2011 6:55 PM   in reply to cupojoe88
    This forum. J
    Bob
    Jan 26, 2012 11:51 AM   in reply to Bob Levine
    hello, i stumbled across this whilst researching the same issue as joe. i then followed the instructions that worked for him, yet my twitter feed displays as code in my test app on the adobe content viewer.
    i have an html (DW CS4) file saved in its very own folder on my computer, yet the app shows the code from the widget-maker window. any ideas?
    note: i used the Widgets>My website>Profile widgets option.
    Jan 26, 2012 12:02 PM   in reply to candyland715
    Saved the HTML file and then create a new frame in the article
    With that frame selected you choose web content in the overlay creator panel and browse to the html file.
    Is that what you did?
    Bob
    Jan 26, 2012 12:28 PM   in reply to Bob Levine
    yes, and all it shows in the frame is:
    <script charset="utf-8" src="http://widgets.twimg.com/j/2/widget.js"></script>
    <script>
    new TWTR.Widget({
      version: 2,
      type: 'profile',
      rpp: 4,
      interval: 30000,
      width: 'auto',
      height: 300,
      theme: {
        shell: {
          background: '#333333',
          color: '#ffffff'
        tweets: {
          background: '#000000',
          color: '#ffffff',
          links: '#4aed05'
      features: {
        scrollbar: false,
        loop: false,
        live: true,
        behavior: 'all'
    }).render().setUser('davidmcnierney').start();
    </script>
    Jan 26, 2012 1:14 PM   in reply to candyland715
    Is that all that's in the HTML file?
    Bob
    Jan 26, 2012 1:30 PM   in reply to Bob Levine
    Yes.
    Jan 26, 2012 1:42 PM   in reply to candyland715
    That's your problem right there. You need to create a valid HTML file like this:
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <html xmlns="http://www.w3.org/1999/xhtml">
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
    <title>Untitled Document</title>
    </head>
    <body>
    <script>
    new TWTR.Widget({
    version: 2,
    type: 'profile',
    rpp: 4,
    interval: 30000,
    width: 'auto',
    height: 300,
    theme: {
    shell: {
    color: '#ffffff'
    tweets: {
    color: '#ffffff',
    links: '#4aed05'
    features: {
    scrollbar: false,
    loop: false,
    live: true,
    behavior: 'all'
    </script>
    </body>
    </html>
    Notice how the script is between the body tags.
    Hope that helps.
    Bob
    Jan 26, 2012 2:20 PM   in reply to Bob Levine
    yep, i see. i'll give that a whirl. i am not a coder by any stretch of the imagination
    thanks!
    Jan 27, 2012 5:45 AM   in reply to Bob Levine
    I have an issue on the same subject.
    I'm using http://mobile.twitter.com/#!/USERNAME to link to a specific twitter feed by creating a button and adding a Go To URL command so the feed appears within the popup browser.
    On the iPad this works fine but on an Android device (Galaxy Tab 10.1) the link sends me to the twitter login screen.
    Does anyone know if this is an Android bug and if there is a workaround? i.e. a way to display a specific twitter feed using the popup browser rather than an inset web content view.
    Mark
    UPDATE: I discoverd that removing the #!/ allows the link to work.
    http://mobile.twitter.com/USERNAME
    Jan 27, 2012 7:39 AM   in reply to candyland715
    it works now. thanks, bob
Bookmarked By (2)
