Frames per second
Jan 21, 2012 2:41 PM
Hello all,
I have a question I am using adobe live eocoder 3.2. I change the FPS from 60 to 25 trying to test the best FPS rate. however when record the FPS show at 8 or 12 FPS regardless to the setting has anyone experience this. I have attached two screenshots
    Jan 27, 2012 12:29 AM   in reply to crene21
    There could be 2 reasons for that:
    - Device doesn't support the selected fps.
    - Device can't output a higher fps because of high CPU usage. Check if your cpu consumption is high (>70%). To reduce the CPU usage you can set input and output size to same. Currently you are upsizing from 640x480.
