Our app is on Newsstand, and I clicked 'Notify' on our Folio Producer panel to inform our customers about the new issue.
However, I haven't seen a PN on my own iPad yet - it has been a day.
Any ideas?
i thought the push notification will be send automatically!? Today apple approved the new issue of our magazin and i
add a new issue in newsstand (iTunes Connect). When i build the app i enabled the "Apple Push Notification service"
in iOS Provisioning Portal. I thought thats enough!?
But if it is, what does the "notify" Button in "DPS / Folio Produce / Organizer" mean? This Button appears some days
ago. I never saw it before!?
With this release of the tools we pulled the notification functionality apart from the publish operation. Apple has a rule for newstand apps that limits the number of push notifications an app can recieve to once every 24 hours. We decided to let users explictly decide when to send that notification instead of doing it on every publish to ensure that they control exactly when the notification is sent.
Hi John
Thanks for your reply.
However, despite checking and double checking my iPad settings for enabled notifications; checking the app viewer set up to ensure that PNs are enabled (they are) and finally hitting 'Notify' on Folio Producer this morning (having uploaded and had a new issue accepted) - still no PN.
Is there a wider problem here or am I missing something?
Thanks in advance
The sending of notifications is under your control. Just know that newstand apps only allow 1 notification through to the app every 24 hours. We don't prevent users from hitting the notification button more often as it may be useful for non newstand enable apps.
Adobe doesn't have any plans to add messaging to our notification service. We only support notification for background download for newsstand and badges for non newstand applications. Enterprise customers have the ability to call their own notification service if they want additional notification functionality.
Hi John and Bob, thanks for your help on this.
Sorry for being dim, but what do you mean by 'background notification'?
I don't seem to be seeing or noticing any notification whatsoever apart from once you go into the app itself. Are you saying we cannot get the alert or banner notification styles?
Is this correct? If so, that's fine - I just want to know that I'm not missing something.
Thanks in advance.
With kind regards,
Klaasjan Tukker
Adobe Systems
I have a non-newsstand app on my iPad with developer push certificate and
all, but nothing happens when I hit notify.
Do I need to publish before doing that? Or can I send multiple
notifications after publishing (regarding the 24hour limit)
—Johannes
(mobil gesendet)
The folio needs to be published. With a non newsstand app, you can hit notify multiple times. The notification won't go out realtime.
The requests are being queued and then segmented into batches before the notifications are sent to the Apple push server. I don't know what happens after that and how much time it takes..
With kind regards,
Klaasjan Tukker
Adobe Systems
Hi
Thanks for the info. The mystery still remains - what are you actually defining a notification as? I'm seeing nothing about from the blue pop up message when you go into the app.
Bob mentioned something about that with newstand you only get a 'background' notification. Like Johannes and MC, I'm not getting the alert or banner style notifications - or even a red badge on Newsstand.
We just need some clarity in terms of what a notification actually is.
To be clear, our app is in newsstand and I've been clicking 'notify' after the app has been published.
J
Newstand apps recieve a notification that triggers a background download. This is subject to some caveats - 1 notification gets through iOS to the app every 24 hours (controlled by apple). The device has sent in a valid notification token (some devices are sending in invalid tokens, Apple rejects any attempt to send notiifcations to those devices).
Non newstand apps recieve a red badge on the app that specifies the number of notifications sent. This number goes up for each notification unless the user takes some action (opens up the app, updates the library).
Adobe's notification service does not support sending text or putting up a dialog as part of notification.
