Nik Ska
Detecting turning to a page
Jan 23, 2012 3:27 AM
Tags: #edge #api #html5 #preload
So new DPS introduced animation preload.
We are making HTML5 animations in Adobe Edge and including them into InDesign, and now when you look at, say, page one, all other animations are already preloaded and starts playing, which is unacceptable.
Is there any way to trace (via API or other ways) if we are currently looking at a page to tell Edge to start?
And which is more important - is there Adobe DSP html5 API to work with?
  • Bob Bringhurst
    May 29, 2007
    Jan 27, 2012 11:31 AM   in reply to Nik Ska
    This is currently a known issue. I'm not sure when it will be resolved.
  • Branislav Milic
    Jan 12, 2010
    Jan 27, 2012 12:37 PM   in reply to Nik Ska
    I have noticed that weeks ago. But how can I add an Edge animation on page 7 if it starts to play even before reaching page 7? Should I add a trigger button so the user makes the animation start when he displays page 7 ? I don't understand why a Load on Page would be so difficult to do.
  • Bob Bringhurst
    May 29, 2007
    Jan 30, 2012 12:50 PM   in reply to Nik Ska
    This bug is scheduled to be fixed for v19 in February. The only workaround I can think of is to turn off Auto Play, but then you force users to tap an area to start the animation.
    Jan 30, 2012 3:00 PM   in reply to Nik Ska
    What if you add a delay of 0.01 sec to the web content?
    Feb 7, 2012 8:05 AM   in reply to Nik Ska
    We've been investigating this issue internally, and believe we have a temporary workaround. Can you try setting the delay on the web overlay to some number larger than zero (perhaps 0.0001) and see if that resolves your issue?
    Neil
    Feb 7, 2012 8:50 AM   in reply to Nik Ska
    Thanks for the quick reply, Nik. I also tried it and saw the same behaviour. I'll get back with the developer and we'll continue investigating.
    Neil
    Feb 8, 2012 1:02 PM   in reply to missamo80
    Nik,
    What device were you using to test out the delay workaround? Did you upload the updated folio and then view it on an ipad? Or were you in the desktop previewer or on an Android device?
    Neil
    Feb 8, 2012 1:06 PM   in reply to Nik Ska
    Thanks. Can you double-check that you were updating the folio in Folio Builder after making the change? We're able to confirm the workaround on our end, however we did forget to update the folio in FB once and thought it wasn't working
    If you find it still isn't working when you verify tomorrow would you mind sending me your InDesign file? My address is listed in my profile. Thanks!
    Neil
    Mar 14, 2012 4:54 PM   in reply to Nik Ska
    Noticed that the delay thing helped but not solved the problem. Better in iPad 1, but iPad 2 hopeless, still no good.
    Mar 14, 2012 5:27 PM   in reply to PreMedia2784
    PreMedia, can you please provide more details on what specifically you tried to set and what behaviour you saw on ipad 2? If you set the delay in the Web Overlay panel to 0.125 and are careful to update the article in folio builder you should see the correct, start on page load, behaviour
    Neil
    Mar 14, 2012 5:46 PM   in reply to Neil Enns - Adobe
    Hi Neil,
    Has this issue now been fixed with new v19? I mean do we still have to set the delay or does web content load when the page is viewed (if set to auto play with 0 delay)?
    Cheers, Tony
    Mar 14, 2012 5:49 PM   in reply to tony kamberi ug
    You still have to set the delay. I will admit the UI is rather, ah, unfortunate but the best way to think of it is "set auto play with non-zero delay" means "load when page is viewed".
    Neil
    Mar 14, 2012 5:55 PM   in reply to Neil Enns - Adobe
    The problem with that is not the delay (which can be 0.125) but with the web content starting to load when that 0.125 is done, which sometimes means another 2 or more seconds if you have an animation that is complicated. Is there a way to preload web content but have it play after 0.125 secs?
    Mar 14, 2012 6:03 PM   in reply to Neil Enns - Adobe
    Its a simple animation with moving fading type built in Adobe Edge Preview. Not using the latest DPS tools but the one before that (compatible withe the downloaded Adobe Viewer).
    Seems it may be an Adobe Edge problem as animations we have created with another editor work okay.
    Mar 14, 2012 6:12 PM   in reply to tony kamberi ug
    Not currently, but it's on my list to try and get done in Release 20. It's more work than you'd think to switch up the UI so it's abundantly clear how to do "pre-load" vs. "auto-play", but I do hope we can get rid of the one second+ wait that's always there before the content appears. If we can do that, at least the delay before display will only be 0.125 seconds.
    Neil
    Mar 14, 2012 6:27 PM   in reply to Neil Enns - Adobe
    Very good to hear that the loading times of HTML will be improved, Neil.
    —Johannes
    Mar 14, 2012 6:32 PM   in reply to Johannes Eckert
    Note that I said "try to get done"
    Neil
