w00dybrand0
add an edit without pausing?
Jan 27, 2012 2:01 PM
Hi All,
is it possible to add an edit to a clip during playback without causing playback to stop? I'm coming from avid mc5.5 where u can do this. hoping it's a setting in preferences somewhere but haven't found anything.
cheers,
Jayson
AWDEfilms.com
youtube.com/AWDEfilms
    Jan 27, 2012 4:39 PM   in reply to w00dybrand0
    You can edit a Multicam sequence without pausing.
    Jan 27, 2012 5:43 PM   in reply to w00dybrand0
    Just curious..
    What sort of editing apart from live broadcast requires one to do this?
    If you drop in an edit without pausing playback..surely you dont see it until you replay the timeline ( unless you have a time machine of course). so what is the point.
    Premiere will allow you to drop in  or overlay an edit  during playback...but the instant you do so..it will pause the playback..
    Jan 27, 2012 8:40 PM   in reply to w00dybrand0
    So where do the source edit points come from that you just drop in as the playback head rolls through ?
    ie . how do you select the in and out points from a source file while a program file is playing ?
    I have never seen any NLE that has this "on the fly" capability or seen a workflow like this before. If Avid can do that.. you should stick with it because Premiere certainly  can not.
    Note: Multicam edit modes  require everything to be be pre synched as a video/audio stream ( simulated live mode) to do what you wish.
    Just in case you are talking about setting MARKERS on a source clip or a TIMELINE..you do this by rolling the playback and hitting the asterisk key on the NUMPAD.
    Jan 27, 2012 8:59 PM   in reply to shooternz
    shooternz, w00dybrand0 is not talking about 3 point editing, he is talking about add edit function (cmd+K ; ctrl+k), on the fly. Avid & FCP can do that, and it can be very useful.
    Jan 27, 2012 9:15 PM   in reply to w00dybrand0
    Unfortunately not. Adding markers on the fly and than snapping to them is the closest you can get.
    Jan 27, 2012 9:55 PM   in reply to I.R
    Thanx
    Because I cant visualise this...I cant understand it ..but that also means I probably never had any particular need for it either.
    Good luck.
    Jan 27, 2012 11:43 PM   in reply to w00dybrand0
    If you dont mind I would like to see you do this in avid.
    Use Screenr and upload a sample somewhere if you dont mind.
    Maybe others will like it and can ask for it.
    http://www.screenr.com/
    GLenn
    Jan 28, 2012 10:09 AM   in reply to Powered by Design
    I had some time so I did screencap for w00dybrand0 :)
    You can't see what I'm doing with keyboard, but that's simple add edit function (cmd+k in pp) while playback is going. When I hit stop all my edits are there. Imagine doing some rough cuts to the bit or similar:
    http://www.sendspace.com/file/9bju01
    When we are talking about basic editing functions that are missing I think that dynamic JKL trimming is more important (AVID and FCP7 have that too). For those who are not familiar how it is working - you hit shortcut to go into trim mode, than JKL edit point while you have real time preview of both incoming and outgoing clip:
    http://www.sendspace.com/file/wdosou
    * Of course I couldn't get decent FPS for screen capture but I hope that it is clear enough (in real life it is all real time and much more fluid )
    I don't want to go deeper with asymmetric trimming, sync point editing, etc., but functions above should definitely be included.
    May 9, 2012 10:42 PM   in reply to I.R
    I'm happy to say premiere cs6 has added this feature! you can now add an edit without pausing, this is making me really like adobe. and i can finally cut on the beat again since leaving avid! Also, you can switch out of the program without pausing!
    thx 4 listening adobe!
    cheers,
    Jayson
    AWDEfilms.com
    May 9, 2012 10:48 PM   in reply to woodybrando
    Pleased you got your wish..
    So how do you actually add the edit on the fly inCS6?
    May 9, 2012 11:06 PM   in reply to shooternz
    Just hit the add edit button while playing. And u can add as many cuts as u like and it'll keep playing.
    cheers,
    Jayson
    May 9, 2012 11:33 PM   in reply to woodybrando
    I will have to take a look for the "Add Edit" Button.
    Any clues where to start looking?
    I would use the Help File except there aint one.
    May 9, 2012 11:58 PM   in reply to shooternz
    I think he's talking about ctrl-K, which creates a cut at the CTI position.
    May 10, 2012 12:05 AM   in reply to Wil Renczes
    Yup, Will is correct in avid it's called "add edit"
