Lightroom conflicting with Microsoft Office Home and Business 2010
Jan 28, 2012 2:52 PM
This is a third posting on what is the same topic/experience.
See postings under ROBBIECRAFT:
http://forums.adobe.com/thread/947181?tstart=60
http://forums.adobe.com/message/4137324#4137324
Hal and Beat were very helpful at that time.
Quick background and current situtation (after some 5 plus weeks)
- Shortly after ver 3.6 was released, Lightroom 3.6 began crashing while in the DEVELOP module after 30 minutes plus or minus.
By ``Crashing``, I mean the computer shuts down, no blue screen, and reboots to screen recommending START WINDOWS NORMALLY
- Computer is 6 months old, Computer shop replaced, in sequence with my testing,
          Video Card
          Memory
          CPU
- crashing continued, so they installed a temporay new C drive to see what would happen.
- With LR only running, all was fine so Win 7 (home premium) was re-installed on my C drive and I stared re-installing the software.
With each installation LR was tested twice for 60-90 minutes, before proceeding to next software install
RESTORE POINT created after FIREFOX ``ìnstalled``
- Lightroom 3.0 installed
     tests run
- Lightroom 3.6 installed
     tests run
- Photoshop CS5 installed
     tests run
- MS Office installed, some issues with setting up OUTLOOK
- drive permissions fixed
     tests run and LR crashed
-Uninstalled Office
- crashes continued (much quicker)
- worked back through RESTORE POINTS and eventually ended up at inital RESTORE POINT
Then worked back through the installs again (and restore points)
- No crashes until I installed MS Office.
- I have backed up to the RESTORE POINT before Office install and still crashing.
At this point I am ready to set up Lightoom in a Virtual machine within the computer and run everything else normally. (not sure I said that correctly, but that was what I thought my technical assistant said)
But before doing that, has anyone else had this problem and solved it ???
Thank you
Jim Robertson
    Jan 28, 2012 2:55 PM   in reply to Jim 185
    What were these drive permissions, which you had to manipulate?
    Beat
    Jan 28, 2012 7:03 PM   in reply to Jim 185
    I know in the previous thread overheating was considered but then ruled out after replacing the fan, but your symptoms certainly match overheating.  (The BIOS will immediately shut down the computer with no warning if it thinks it is too hot). LR is particularly good at heating up the CPU, since it can utilize all of your processors very easily.
    Has your technician checked the System events log?  You can check that yourself: Start > Control Panel > Administrative Tools > Event Viewer > Windows Logs > System. On the right panel, click Filter Current Log and check Critical and Error.  That will show you really "important" events, and if you scroll to the time right before your computer crashed, you can often see clues as to the crash, e.g. an error event that says "The system was shut down due to a critical thermal event." It's unusual for the computer to crash without some indication or clue in the System event log.
    Jan 28, 2012 7:41 PM   in reply to Jim 185
    Jim 185 wrote:
    Hi Beat
    When the computer shop re-set my C drive, the other two drives (my data and picture drives) did not have permission for me to have full control or to modify them.
    That, after much searching and pulling out of hair, was I had to use Adminstrator authority to run LR when you pointed out that I had a permissions issue when I was working with the temporary C drive from the computer shop.
    So I fixed it under drive>properties>security (under the guidance of my technical assistant.
    I understand what you're saying, but I'm puzzled. I agree with John, that overheating is the most likely cause for such behaviour. Have you ever considered a tool like SpeedFan to monitor (and log) your temperatures? Logging has the advantage that you can check what has happened before the shutdown.
    Beat
    Jan 29, 2012 5:19 AM   in reply to Jim 185
    Event ID 41 is "The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly". (You can see the text of an event in the lower pane after clicking on the event in the upper pane.)  This event just indicates that Windows noticed, after rebooting, that it had crashed unexpectedly.  Preceding events in the log would be the ones that might indicate why.
    It would be highly unusual for this kind of crash to be caused by applications like LR or Office.
    Jan 29, 2012 5:59 AM   in reply to Jim 185
    Jim,
    You really ought to run a temperature logging program. Speedfan is good. Here's how:
    Download speedfan: http://www.almico.com/sfdownload.php
    Run the downloaded exe file to install.
    Run speedfan. Go to configure.
    Go to the Log tab and click the Enable box.
    On the temperatures tab, choose the temperatures you want monitored in the Speedfan window by putting a check in the box. Then click on each of those lines one at a time to select them and notice that a "Logged" checkbox appears at the bottom of the dialogue box. Tick that box for each temperature you want logged.
    Click OK.
    Leave Speedfan running and run your LR tests. Speedfan's "Readings" tab will show you real-time temperatures, and your selected temperatures will be logged to a file every 3 seconds.
    When you want to read a log, you can find them in Program Files( x86)\Speedfan with names of the form SFLOG<date>-<sequence>.csv. You can load them directly into your favourite spreadsheet program.
    Hal
    Jan 29, 2012 9:02 AM   in reply to Jim 185
    Jim,
    To get the actual temperatures in Speedfan's log, you have to select the line in the Temperatures tab, and tick the Logged box that appears:
    Even with your log not working correctly, your CPU shows 124 degrees Celsius. That's gonna shut you down in a hurry.
    Either your cpu fan isn't running well (it shows 20 rpm, which ain't good), or your cpu heat sink was installed without any thermal grease. I'd suspect the former.
    Hal
    Jan 29, 2012 2:16 PM   in reply to Jim 185
    Jim,
    The Speedfan numbers don't look conclusive. All of them except for the second CPU numbers seem to be within normal bounds and those look to be a probable artifact of Speedfan.
    On the other hand, if Prime95 will kill your computer in five seconds, you definitely have a problem, either with your CPU overheating, or possibly your power supply overheating or simply being incapable of supplying enough current to your CPU.
    If I were you, I'd take it back to the shop and tell them that you don't want to see it again until it will run Prime95 for an hour without perishing.
    Hal
    Jan 29, 2012 2:57 PM   in reply to Jim 185
    Jim,
    I completely agree with what Hal has stated. Something is wrong with your system, as you should be able to run your system for an indefinite time with all your CPU stressed to the max. Do you know if you run your system overclocked? If so, I'd take it back to defaults.
    Beat
    Jan 29, 2012 4:46 PM   in reply to Jim 185
    Jim,
    So it was the "blend" test but not the one that produces maximum heat.   Perhaps it's a memory problem, since that's what Blend does a lot of testing of.
    Try downloading Memtest (http://www.memtest.org/#downiso), burning the .iso image to a CD, and then booting from the CD. It's a standalone memory tester, and if you have a bad spot in your memory, it should find it pretty quickly. Worth a shot.
    Hal
    p.s. An iso CD image is an image of how the cd should look after it has been burnt. Win 7 knows about such things and will do the right thing when you ask it to burn the iso file to CD.
    Jan 29, 2012 6:08 PM   in reply to Jim 185
    Jim,
    Keep us posted.
    Hal
    Jan 29, 2012 11:49 PM   in reply to Hal P Anderson
    You guys are amazing!! Medals all round as soon as we can find some....... or go and get a free d/l of Lightroom4       .............beta!!!
    Feb 5, 2012 5:10 PM   in reply to Jim 185
    Jim,
    If you suspect a driver to be the issue (which I agree it looks like if your system runs stable in safe mode), you can do the following to narrow down the offender:
    • Enter msconfig into the search box of the start menu
    • Select the Startup tab
    • Disable all startup items
    • Reboot your system
    • Run your tests
    • If the system runs OK, one of the items is the offender
      -> Narrow down the offender (see next section)
    To narrow down by disabling (you need lots of reboots if doing them individually), I usually perform a binary drill down as follows:
    1. Sort the items by name
    2. Disable upper half
    3. Reboot, test
    4. If OK, the offender is within the first half
      1. Cut down the disabled items to a quarter (re-activate half of the de-activated)
    5. If not OK, the offender is within the second half
      1. Re-enable the disabled items
      2. Disable the lower half
    6. and so on
    By doing this, you don't need so many steps to end up with one item.
    Have a good Super Bowl!
    Beat
    Mar 14, 2012 4:28 PM   in reply to Jim 185
    Thanks for the feedback, Jim, we'll keep our fingers crossed for you.
    Beat
