painter6565
YouTube jumpiness
Jan 28, 2012 8:13 AM
I'm having a problem with videos that look fine on my computer but look "jumpy" on YouTube.
I took the video clips with a FlipCam UltraHD camera, brought them into Premiere Elements 9 and edited them, then "shared" it as a WMV file for computer playback. The video looks great on my computer, but when uploaded to YouTube it looks jumpy.
I've tried a lot of combinations of presets and export settings, also tried saving as AVI and MPG and Flash Video for YouTube, but the end result seems to always be that the video looks fine on my computer but jumpy when uploaded to YouTube.
What the heck is going on? Here's what the YouTube videos look like:
http://www.youtube.com/watch?v=VGjWLsIMuVI
    Jan 28, 2012 8:21 AM   in reply to painter6565
    Welcome to the forum.
    Unfortunately, YouTube will re-Encode your video, after it has been uploaded. The specs. of the Encode will likely change about every quarter, as they try for smaller files.
    As a test, Export/Share your Project to H.264, which should result in an MP4 file, and upload and test that file on YouTube.
    Good luck, and please report back,
    Hunt
    Jan 28, 2012 2:07 PM   in reply to painter6565
    What you first started your Premiere Elements project, did you select the project settings for Flip video?
    Selecting the right project settings is essential to getting a good output. If they're not right, no output settings are going to work particularly well.
    Jan 28, 2012 3:54 PM   in reply to painter6565
    Regarding the 60 FPS, I wonder if the Flip is actually shooting at 60 Frames per Second, or the more likely, 60 Fields per Second, which is actually 30 Frames per Second. Some camera mfgrs. play a bit fast and loose with some of their terms.
    Maybe another Flip user can address that specifically, especially if they have been getting good YouTube results.
    Think that the Arizona Diamondbacks gave my wife a Flip HD camera, but am not sure that it has ever been out of the box. If I can track that down, I will give it a test, to see how the footage behaves. Gotta' be around here somewhere.
    Good luck,
    Hunt
    Jan 28, 2012 4:43 PM   in reply to painter6565
    Out of curiosity, download and install the great, free utility, MediaInfo. run one of your files through that, and tell us what it says about the file. BTW - MediaInfo and G-Spot are two very similar utilities, that anyone editing video, should not be without.
    Good luck,
    Hunt
    Jan 29, 2012 6:21 AM   in reply to painter6565
    You're making this way too complicated, John.
    All you've got to do is:
    a) start a project using the Flip video project settings that match your camcorder (There's one for hi-def and one for standard def video).
    b) Output the file using these settings:
    http://forums.adobe.com/thread/623549
    Then load it up to YouTube using the YouTube site's video uploader.
    If you do those two things, you shouldn't have to do any other tweaks or customizing of the settings. In fact, doing so could undermine the workflow.
    Jan 29, 2012 2:45 PM   in reply to painter6565
    If you're seeing what I'm seeing, that's not interlacing. That looks more liked dropped frames from a poor video capture.
    Is that what you're talking about? The way the video occasionally jumps like a frame or two are missing?
    If so, how did you get the video from the camcorder to your computer? Did you use Premiere Elements' Get Media tool?
    Jan 29, 2012 6:19 PM   in reply to painter6565
    With most flash media footage, it is very important to copy over the entire folder structure for the card, to the HDD.
    Good luck,
    Hunt
    Jan 30, 2012 5:16 AM   in reply to Bill Hunt
    I don't see one jump or tremble in your video.
    On the other hand, it's rare that you see someone trying to push out such a high resolution video on the web! If you're seeing shakey playback, it could be that I'm watching it at 7 in the morning over a high-speed connection. Watching this video on even DSL during a time of even remotely heavy traffic would certainly make it shakey. You just can't put out a video that huge over the internet!
    Try creating a 640x480 or even at 1280x720, as I recommended a few posts up. Chances are it will demand much less bandwith and will play much more smoothly.
    Jan 30, 2012 6:30 AM   in reply to Steve Grisetti
    I watched it last night over DSL through a G-class wireless, and after repeated viewing, saw two tiny "glitches," that resembled a single dropped Frame, or maybe a 1-Frame pause/hang. Even when downloading the content to cache, it looked good. I could not tell if the "glitches" (two by my count) came at the same spot, as the actions are fairly repetitious, and I did not note the TimeCode. Looked good to very good, at least to my eyes.
    Hunt
    Jan 30, 2012 7:07 AM   in reply to Bill Hunt
    To eliminate the Internet from the assessment I downloaded the .MP4 720p version and the .FLV 360 version. The MP4 version played smoothly although the image seemed soft. The statistics tab showed three video frames dropped, but I didn't notice it during replay.
    There is certainly 'something' about the FLV version - hard to put into words. It's more a stutter than a jump - perhaps as Bill says a lost frame. But to me it seems constant throughout the clip as the painter is moving crossways.
    Now it seems odd to me that one should look smooth and the other not if they are both derived from the same upload. Maybe, painter6565, you could post the original raw file somewhere for me to look at.
    Cheers,
    Neale
    Insanity is hereditary, you get it from your children
    Jan 31, 2012 1:12 AM   in reply to painter6565
    painter6565 wrote:
    If anybody knows a disadvantage to sharing the videos this way, let me know. Thanks!
    No disadvantages if it works for you. Stick with it and enjoy making movies !
    Cheers,
    Neale
