I love that this feature has finally been added. Thank you.
On my first attempt to test it out, I can't seem to find CMYK as a profile option. Am I missing something?
Personally I don't believe that LR "can not handle CMYK", it is just not implemented. You can help yourself with a CMYK plugin from the UK and please add your +1 to the wishlist at http://feedback.photoshop.com/photoshop_family/topics/cmyk_in_lr4 so that it can be tracked by Adobe, even when this forum is closed after the beta phase of LR4.
Even if it could preview CMYK, you can’t edit CMYK. You’d end up with RGB. So how useful would seeing CMYK now be? The LR/ACR engine is RGB. It always renders through MelissaRGB (ProPhoto 1.0 TRC gamma). That is true if you work with a raw or a JPEG or a TIFF.
Sorry, the editor killed the link, it's http://feedback.photoshop.com/photoshop_family/topics/cmyk_in_lr4
It's a bit like comparing apples with oranges, but imagine you need to deliver your material in full color, but your client is printing it in b/w: although you are not even allowed to deliver it in b/w, you need to know how it will translate later.
Another example: visit any recording studio of your choice all over the world: They are working with the best monitor speakers they can afford. BUT there is always at least one set of cheap speakers so that they can check how well their mix will work later on a listeners kitchen radio. Sometimes those trash speakers are more used than the big ones. So for me soft proofing is not an option, but sometimes I think I should only work in sp mode ...
So as I am very sure that a big, big percentage of all LR processes material will be converted earlier or later to a CMYK color space, we all should be able to check easily wheter we are more or less within the CMYK space or have left it too far. And I have seen masses of material that is far out of the CMYK color space and results in big problems.
It's not the nice color on our wide gamut monitor that counts, but how well the picture rocks later on the kitchen radio!
You would probably be wrong about that. I think the overwhelming majority of material processed through LR stays in RGB space either because it goes straight to the web, to a printing lab (who all operate in RGB), or to inkjet printers that are fine art oriented or consumer grade. All of those are RGB devices nowadays. I think the images that are printed in books are probably more the exception.
Nevertheless, I personally would really want to have cmyk softproofing support in Lightroom, but I do realize that I am an edge case.
To answer your question Andrew, I dont want to edit in CMYK, I just want to know what my image looks like if converted to CMYK.
I love LR. I do 98% of my editing in LR. I also own PS, but use it for very few tasks. One of them is soft proofing for CMYK printing.
Here's my workflow: Use LR to get my image just right. Export to PS to soft proof for CMYK. Go back to LR and tweek a setting or two. Go back to PS to soft proof again. Repeat until no (or very few) colours are out of gamut.
Once OK, I go back to LR and output a high res TIFF in Adobe RGB. Yes, I said Adobe RGB. That's what the magazines want me to send them. Not the CMYK file. They prefer doing the conversions from RGB themselsves.
I, on the other hand, like knowing that what they print is what I saw on my monitor while editing. That's why I spend the time hoping back and forth between LR and PS. Its a pain in the a$$, but at least I get called again because I give them good images.
As far as I'm concerned, the soft proofing feature in LR4 is incomplete for a professional workflow without CMYK.
I don't disagree that it would be "useful" to have CMYK soft proofing in LR4.x but the reality is, ain't gonna happen (at least in the 4.x time frame). Unless you can imagine a really good use case why LR, an RGB processing pipeline), NEEDS to have a CMYK soft proofing, the odds are it won't happen.
Personally, I think it would be useful to predict what a PPRGB>CMYK conversion would look like in LR4. But...that's an edge case as most photographers tend to supply RGB rather than CMYK for assignments...not a hill worth dying on for me...
"I don't disagree that it would be "useful" to have CMYK soft proofing in LR4.x but the reality is, ain't gonna happen (at least in the 4.x time frame). Unless you can imagine a really good use case why LR, an RGB processing pipeline), NEEDS to have a CMYK soft proofing, the odds are it won't happen."
Having worked in photography for over 50 years I see a definite trend toward usage of other media, such as offset printed photo books, HD monitors, and the Web. I use both Adobe CS5 Design Standard and Lightroom 3 for my business materials and personal photography work. Most of my business materials are sent to an offset printer, which uses 4-color CMYK process. I currently do all of my soft proofing inside PhotoShop and/or InDesign. I am now considering using Blurb books for distribution of my personal photography, which also uses CMYK offset print process:
http://forums.blurb.com/forums/5/topics/560
If I want to soft proof camera images placed in the Blurb book I can do that inside InDesign or Photoshop, but not all Lightroom users have that option. It would be far simpler and efficient to do CMYK soft proofing in Lightroom using a virtual copy. The virtual image copy can then be adjusted inside Lightroom to correct for “out of gamut” color issues, and then exported to proper layout size for placement in the target RGB application. I agree that first and foremost Lightroom should provide capability to output images to wide-gamut inkjet printers for producing high-quality prints, but let’s not neglect the other media.
That is both counter productive and not a very good way to handle OOG colors. Let the profile do this. Here is why:
http://digitaldog.net/files/LR4_softproof2.mov
It is even more so with CMYK than the sRGB demo shown in this video!
Technically that is correct. In reality, considering the single CMYK profile Blurb supplies, not at all. The profile isn’t used to convert the data for all output needs (one profile can’t define all the papers and conditions). So using that for soft proofing is nothing more than a feel good button. For other book publishers, that might be different.
Thank you for the informative video on LR 4 soft proofing tools. I agree that an ICC color profile should be generated for each paper type, but Blurb only provides one. From everything I've read so far it appears there isn't much difference in photo reproduction between the different paper types. It's more an issue of paper weight and print through:
http://forums.blurb.com/forums/5/topics/10111
Blurb also mentions that "repeatability" between print runs will not necessarily be what you expect from a well-managed inkjet printer. I still think the ability to do CMYK proofing in LR would be helpful for target applications like Blurb books and other publishers using offset 4-color printing. As with any soft proofing, it's difficult to simulate the actual reflective paper print image on the display, but it's better than nothing. As you pointed out in your sRGB example, out of gamut colors in most images usually have minimal damage from the sRGB export. Given the smaller gamut of CMYK offset printing like Blurb books, the impact will be more noticeable and may cause disappointment if not corrected before uploading.
You read that where?
I’ve built dozens of profiles for Indigos using differing stocks. What you read could be considered true if you are OK with max deltaE values between two papers that exceed dE10! That’s a max using an ECI2002 target measurement. You OK with more than 10 dE? Add coatings and the numbers are even worse. And that doesn’t take press variation over time into consideration, and these are averages of press runs used to build the profiles (dozens of ECI’s). On a single press run, with two different papers, the dE values are significantly higher.
Nope, not even close. I have a lot of data about that as well. A really, really good shop might be able to keep a average dE of a similar target in the range of 3 or so compared to the profile.
It would be easy to monitor Blurb by simply inserting a small target with every book you print and measuring it, then ideally, plotting that against the profile (since that is what is the expected behavior). When Blurb sets up my free account for books, I’d be happy to do that <g>.
Unless you are viewing those high dE values based alone on differing profiles! That doesn’t take the press changing over time or from the reference (the profile) into account.
Using a canned profile this way really isn’t effective.
I was referring only to the paper types used by Blurb and comments posted by a number of their customers on results. I couldn't agree with you more concerning the wisdom of profiling each paper type.
Most of my soft proofing concerns have been with logo and product colors to minimize customer complaints. The soft proofing tools in PhotoShop and InDesign have been helpful for this purpose. I have very little experience with 4-color offset printing of photographic images using a printer such as Blurb. Based on your experience what is effective?
Soft proofing for 4 color images is super useful when the profile (and it’s previews) reflect the printing conditions. Here is another rub. You have to play the rendering intent guessing game with workflows that provide a generic profile and don’t also specify what intent the RIP uses. Effective is, what you see is what you get and consistently.
Thanks Andrew. I did find this Blurb link with information on soft proofing:
http://www.blurb.com/guides/color_management/image_prep_pdf
Blurb recommends Perceptual rendering "to preserve subtle gradients," Black Point Compenstaion, and Simulate Paper Color (if your monitor is 100-120 cd/m2).
Several odd comments there. I agree about BPC and Simulate paper color and ink. The rest seems up to debate but whatever.
I have to agree, especially since Blurg has now added a 'ProLine' with two more paper options, Pearl Photo and Uncoated. I can't see how one paper profile will work.
I just received this response from Blurb Tech Support concerning why the only provide one ICC color profile:
"Blurb currently offers five different paper choices for your books. We felt that trying to supply a Color Profile for each of the substrates would be confusing for some users. Instead what we have done is have our printer calibrate and target their printing device directly to our single Blurb ICC Profile against the paper type chosen during checkout. This takes any confusion out of the equation while still providing the most advanced color management available for a Print-On-Demand workflow."
I would still prefer to use a paper specific color profile and make my own decison on soft proof corrections, but at least we now know the print output isn't being generated directly using the single ICC profile.
"Instead what we have done is have our printer calibrate and target their printing device directly to our single Blurb ICC Profile against the paper type chosen during checkout. This takes any confusion out of the equation while still providing the most advanced color management available for a Print-On-Demand workflow."
Are they actually saying they send the same RGB numbers through that single profile that goes out to the different papers? That be the question I’d ask. I’ll bet dollars to donuts the RIP is setup for different profiles for each paper. If so, what they are saying is silly. It is useful to calibrate the press to a specific and desired condition, no argument there. That calibration doesn’t in any way make differing papesr behavior such that a single profile could be used however.
Exactly.
Agreed. I have sent Blurb Tech Support a request they offer customers the option of using seperate ICC paper profiles for at least the new 'ProLine' Pearl and Uncoated book paper types.
Suggestion emailed to Blurb Tech Support: Since Blurb is now offering new ProLine services and paper types it makes sense to offer professional customers the option of using separate paper profiles for at least the new Proline Pearl and Uncoated papers.
Here's Blurb Tech Support's reply received today:
"Thanks for your suggestion, I'll make sure to pass it along!"
At least they acknowledged the suggestion with a reply. Let's see what happens.
What on Earth is the point of introducing soft proofing if you can only use it for web images?!
You can clearly see in the LR4 intro videos that there are CMYK profiles for the Epson 2200 papers.
And look at the check box for simulate paper color and ink?
You want us to try out Blurb book printing but not let us use the profiles? Insane!
For printing to Epson, the profiles are considered "RGB profiles" not CMYK. Have you actually tried doing soft proofing for inkjet printing? Worlk pretty well. Try it and get back to us...
Yeah, I've tried it plenty. It does work quite well. Why didn't they put a Blub profle on here? I really hope they plan on doing it given the fact that the "Book" tab and softproofing are the 2 biggest features of this release. Otherwise, Adobe will be dealing with lots of angry photographers.
I too was excited to see softproofing finally added to lightroom... but like the original poster I was dismayed to see that it does not include soft proofing CMYK. And I do not buy into any of the reasons suggested so far as to why it is not there? I also find it incredibly hard to believe that some people were suggesting that although it might have been usefull... they considered it of limited use to most photographers and an edge case due to the fact that most photograpers supply RGB images to thier clients... who then do the CMYK conversion for the commercial printing presses? That may be true... but since the images will be converted into CMYK in the end... it would be hugely usefull to be able to soft proof images in lightroom first... just to see if there is going to be problems with the CMYK conversion! There are millions of photographers out there who are supplying stock or assignment photography that will be eventually be converted to CMYK for printing presses... and most would find that being able to do a quick preview of the conversion in Lightroom first... would help to reduce the rude suprises that many have when they see the final image in print. Yes... I know you can always open the image in photoshop and soft proof it there... but that is time consuming and in this busines time is money! I try to spend as little time as possible in Photoshop for that very reason... and I am sure I am not the only one!
Yes, it would be useful - but only some.
Because as far as I know there is no CMYK profile that is valid for all printers. The RGB profiles (proPhoto, Adobe, sRGB) are device independent. But CMYK profiles are device specifc.
As far as I know each printing press has its own CMYK profile and just using a generic profile won't do much good.
It would give you a rough idea, though.
WW
Exactly (well stated). You’ll have to have another application to convert to CMYK, presumably Photoshop so might as well soft proof and convert there.
