So new DPS introduced animation preload.
We are making HTML5 animations in Adobe Edge and including them into InDesign, and now when you look at, say, page one, all other animations are already preloaded and starts playing, which is unacceptable.
Is there any way to trace (via API or other ways) if we are currently looking at a page to tell Edge to start?
And which is more important - is there Adobe DSP html5 API to work with?
Bob, do you have any dates?
tony - that won't help. All the animations are now loaded simultaneously. What you can do is loop all actions, so it won't affect you. But if you have time-based animation, that won't work, only if you force users to click the animation, which is pretty annoying.
Thanks. Can you double-check that you were updating the folio in Folio Builder after making the change? We're able to confirm the workaround on our end, however we did forget to update the folio in FB once and thought it wasn't working ![]()
If you find it still isn't working when you verify tomorrow would you mind sending me your InDesign file? My address is listed in my profile. Thanks!
Neil
PreMedia, can you please provide more details on what specifically you tried to set and what behaviour you saw on ipad 2? If you set the delay in the Web Overlay panel to 0.125 and are careful to update the article in folio builder you should see the correct, start on page load, behaviour
Neil
The problem with that is not the delay (which can be 0.125) but with the web content starting to load when that 0.125 is done, which sometimes means another 2 or more seconds if you have an animation that is complicated. Is there a way to preload web content but have it play after 0.125 secs?
Its a simple animation with moving fading type built in Adobe Edge Preview. Not using the latest DPS tools but the one before that (compatible withe the downloaded Adobe Viewer).
Seems it may be an Adobe Edge problem as animations we have created with another editor work okay.
Not currently, but it's on my list to try and get done in Release 20. It's more work than you'd think to switch up the UI so it's abundantly clear how to do "pre-load" vs. "auto-play", but I do hope we can get rid of the one second+ wait that's always there before the content appears. If we can do that, at least the delay before display will only be 0.125 seconds.
Neil
