ajkessel
Acrobat Pro X freezes up for 10-15 seconds shortly after opening PDF
Jan 31, 2012 8:36 AM
Tags: #delay #bug #acrobat_pro #windows_7_64_bit
Transferring this discussion from another forum.
I believe my issue may be the same as or similar to http://forums.adobe.com/thread/867133 , but I'm not able to post to that forum.
Running Acrobat 10.1.2 on a fully-patched Windows 7/64 Bit system (Office 2010/32 bit). Antivirus is eSet NOD32 4.0.437.0. I've been having this problem for several versions of Acrobat Pro.
Frequently, when I open a PDF, Acrobat shows the document and is responsive to user action (e.g. scrolling) for a few seconds, and then becomes completely unresponsive for 10-15 seconds, and then is usable again. This happens fairly consistently. Even if I already have Acrobat open, opening a new file causes the same behavior.
Many of the comments on this sort of problem suggest security settings might be an issue.I have tried disabling Enhanced security, disabling "automatically trust sites from my Win OS security zones", disabling "verify signatures when the document is opened", disabling "load security settings from a server", also done "clear remembered account information" for LiveCycle Rights Management. Further disabled everything in advanced settings under Windows Integration. None of these changes have any effect on my problem.
Any suggestions for how to troubleshoot?
    Feb 8, 2012 8:51 AM   in reply to ajkessel
    Could you please let me know if you are facing this issue with any PDF that you try to open or only with a specific PDF? Also, do you face the same issue while accessing PDFs in the browser as well?
    Please download the PDF at: kb2.adobe.com/cps/837/cpsid_83708/attachments/Acrobat_Reader_ReleaseN ote_10.1.2.pdf and see if Acrobat still stalls for some time while rendering it.
    May 9, 2012 12:49 PM   in reply to Ankit_Jain
    Amazing that ADOBE CAN NOT HELP US SOLVE THIS HUGE PROBLEM!!!!   Instead of offering a solution to our major problem with this HORRIBLE PRODUCT ADOBE ACROBAT X PRO -- They always turn it around and ask another stupid question !!!
    Jun 21, 2012 5:34 AM   in reply to gotchabebe
    Adobe Acrobat Reader X is a bummer, I agree 100%
    Now, here is the solution to your problem: Go to Edit -> Preferences -> and uncheck the Option "Enable Protected Mode at Startup". Now close you Acrobat Reader and when you start it again it shloud not freeze anymore.
    Calculating status...
    Dec 27, 2012 8:18 AM   in reply to ajkessel
    Preferences-->security(enhanced)
    Add folder path (where all your pdf are)
    It work for me even for the pdf that are no inside this folder
    Then a go back to add one more folder and the first folder that i add was not there
    Did a repair acrobat
    Go back to preference an the folder add is back
    So i decide to uncheck  "Automatically trust sites from my Win os security zone"
    Since then everything work fine for me so i don't know witch part of this process fix my problem
    Good luck
    RL
    Jan 15, 2013 10:28 PM   in reply to Roberto L
    This has helped alot.  I was entering a document and then after a few seconds it would freeze for 20-30 seconds and then come good, darn frustrating!  Turned off "Automatically trust sites from my Win OS security zone" now allows me to operate as normal.  Every once in a while a document would pause but I don't believe it is related to this issue.
    Thanks for the suggestion.
    Dec 16, 2013 5:21 AM   in reply to JTB1965
    On my computer, a issue with similiar symtoms was a network path pointing to an unavailable computer. Opening local files until the path disappeared from the recent files resolved the issue.
    Apr 22, 2014 8:09 AM   in reply to ajkessel
    I changed recently used documents list to 1 [Preferences/Documents].  This has resovled the problem for me so far.
    Variables:
    Acrobat Version: 10.1.9
    Document Size: 42x30
    File location: Desktop
    File creator: CutePDF Writer
    Application: PScript5.dll Version 5.2.2
    PDF Producer: GPL Ghostscript 8.15
    PDF Version: 1.6 (Acrobat 7.x)
    Prior to that, I tried unchecking "Automatically trust sites from my Win OS security zones" [Preferences/Security (Enhanced)]
    and unchecking "Enable Enhanced Security" to no avail.
