I have a lot of illustrator files in folder A and each file has tons of images from different folders (B, C, D...). All of these folders are inside a main root folder.
Recently I moved this root folder to an external drive then all the illustrator files disconnect with the images. Is there any way to relink all of those images all together instead of relink them one by one?
Thanks but then does it mean I not only have to relink everything but also have to gather all the images from different folders and put them in the same folder as the ai files? The images are from at least 20 different folders and there are more than a hundred of images in these 20 ai files.
unfortunately "relinking" not the same as in indesign... and one by one the only way now. But for the future:
1. If its a complex project i always try to copy/move the "images—links' to a links folder inside the project folder, and place from there. Try and improve your workflow, project file structure.
2. Then you could have saved as: checked the include links option. Draw back is it will embed everything. At least the document will be complete.
G
I would say you made a big mistake by moving all those image especially since you know you had 20 ai files each with hundred of images.
Even if you did not move them this is a poor workflow sinvce for out put you more than likely would need to collect those linked images. That can be too much fun.
Thanks a lot for the advice!
Those ai files are different projects and the images are grabbed from the company's product image database directly. The products have different catagories that's why they are from different folders. I thought it would be like dreamweaver updating the links automatically as long as you moved the root folder. Obviously I was wrong.
So it would be the best practice to have the images in a folder with the ai file right?
