Hi!
I have a problem with Premier Elements 7. It gives me error message "../Src/Window.Cpp-251". It seems to appear after adding DVD menus. And actually that problem started after using higher resolution clips. Earlier I was using DV files 720x576, but now 1280x720 and 1920x1080. But I have been able to use these clips too. One moment the program hangs and if I try to open the same project again, it gives the error message and will close. I can open the program and start new project or open other projects, but not that one any more.
Technical data:
RAM 4GB
CPU Intel Core2 Quad Q8300
Windows 7 Pro SP1 32 bit
Hard disk has two partitions - program is on the main part and projects and everything else is on the other.
I hope someone knows the solution! Thanks!
BTW - is your end product a DVD, or BD?
If you are going to DVD, you might have best luck, by setting your Project to your Source Footage, then editing that. Finally, Export/Share to a DV-AVI (PAL, in your case, right?). Then, Import that into a PAL DV Project, and do your DVD authoring from that Project.
Good luck,
Hunt
