(Using CF Builder 2 on Win 7)
Assuming I'm using the right phrases since I'm new to this editor, but Code Assist, I like that. When you type part of a tag and it gives you the option of tags or attributes/etc. I don't want to disable that.
But my mouse rests over code and up pops these light yellow background blocks of text that can be varying in size and are appearing so often throughout my coding that it is fast becoming annoying.
For example, I rested my mouse over a CFFUNCTION tag and it says:
CFFUNCTION
Description: Defines a function that you can call in CFML. Required to defined CFML component Methods.
They all end with the same notice "Press F2 for Focus".
Is there anyway to get rid of these things?
This might do the trick:
http://eclipseone.wordpress.com/2010/08/24/configure-tooltips-in-eclip se-to-only-popup-on-request/
Yes, it says "java", but it works in Flash Builder, so it may work in Coldfusion Builder just as well.
Afterall they're all just Eclipse variants.
Yup you're right. Doesn't work for ColdFusion and if a similar option like the one for Java isn't available under the ColdFusion preferences I'm afraid there's no way to turn it off.
In that case you could file an enhancement request.
https://bugbase.adobe.com/index.cfm?event=newFeature
In case you do, post it here so people can vote for it ![]()
