execute js function on clicking tab?
Jan 31, 2012 8:45 AM
i have a js function that works fine when attached to the onClick event of a button, but i want it to execute when user clicks the tab
is there a way to do that?
function clearURL() {
var testURL = document.URL;
var urlQry = testURL.split("?")[1];
if (urlQry != "")
    var activeTab = ColdFusion.Layout.getTabLayout('myLayout').getActiveTab().title;
    if (activeTab == 'myTabTitle')
        var newURL = testURL.split("?")[0];
        window.location = newURL;
thanks
    Jan 31, 2012 11:37 AM   in reply to ion
    <div onclick="clearURL()">
    <cflayout>
    </cflayout>
    </div>
    Feb 1, 2012 12:23 PM   in reply to ion
    ion wrote:
    thanks BKBK, but is not really working. is not the whole layout that needs to be affected, only one layoutarea.
    when i do this, it throws the layout out of wack, and when clicked, it does nothing (no error either)
    I understand. You could place the DIV within the layoutarea, as in this example:
    <script type="text/javascript">
    f = function () {
        alert('Karamba!')
    </script>
    <cflayout type="tab" name="tabLayout">
        <cflayoutarea name="tab1" title="Tab 1">
           Tab 1 contents
        </cflayoutarea>
         <cflayoutarea name="tab2" title="Tab 2">
               <div  onclick="f()" >
           Tab 2 contents
        </div>
        </cflayoutarea>
    </cflayout>
    Jun 21, 2012 4:45 PM   in reply to ion
    I used this to submit a form using ajax whenever a new tab is selected.  This is essentially the onclick portion:
    ColdFusion.Layout.onTabActivate = function(tab)
    ColdFusion.Layout.onTabActivate = function(tab){
          ColdFusion.Ajax.submitForm('myform', 'my.cfm')
      </script>
        <cfform id="myform" name="myform" action="my.cfm" method="post">
            Tab 1 contents (form input)
          </cflayoutarea>
            Tab 2 contents (form input)
        </cflayoutarea>
      </cflayout>
      </form>
    Jun 21, 2012 5:30 PM   in reply to ion
    Maybe this will help: http://api.jquery.com/keypress/
