Reader 10.1.2 won't print
Guest
Jan 15, 2012 Jan 15, 2012
Operating System XP SP3.  Installed Reader 10.1.2 and now cannot print pdf's opened in IE8, nor pdf's opened directly in the reader.  Printer (HP Laserjet 1020) "prints" a blank sheet, then displays error signal and has to be switched off and on again before it will print anything else, from any other source.  Prints WORD 2003 documents perfectly - as always.  When previous reader version was in use, there were no problems. It looks as though an urgent error fix is needed - am I right?
Brian.
15.5K
Adobe Employee , Jan 19, 2012 Jan 19, 2012
Please see if any of the workarounds listed below, work for you:
http://kb2.adobe.com/cps/928/cpsid_92870.html
Adobe Employee ,
Thanks Ankit_Jain. It works fine
Following latest security update from Adobe for Acrobat Reader, I was unable to print anything anywhere (Reader crashing). Even reinstalling from scratch didn't change anything.
After I followed the workaround listed (Reader 10.1.2 does not print), I shared all the printers from my XP Virtual Machine, thus allowing me to print again.
Adobe Employee ,
Glad it worked for you.!!
Jan 20, 2012 Jan 20, 2012
I am running Windows 7 (64-bit) and Adobe Reader 10.1.2, and have the same problem.  My printer is "shared" per the KB article refrenced above, but still will not print.  When I hit the "print icon" or do Cntrl-P, the Adobe application closes.
Any Suggestions?
Adobe Employee ,
Jan 22, 2012 Jan 22, 2012
Please post a screenshot of the printer sharing settings if possible.
Guest
Jan 23, 2012 Jan 23, 2012
Thanks, Ankit_Jain; the second suggestion (double-sided option) solved the problem.
Suggestion: make single-sided printing the default in future releases, to avoid this happening to others.
Brian.
Adobe Employee ,
Jan 24, 2012 Jan 24, 2012
We have provided the permanent fix for this issue. please refer http://kb2.adobe.com/cps/928/cpsid_92870.html.
Atul Agarwal
Adobe Systems
Guest
Feb 01, 2012 Feb 01, 2012
I am having the same problem. I tried the download and it didn't change anything. I uninstalled 10.1.2 and installed 9.5 and still have the same issue. I can print from all other programs but not Adobe. I have tried restarting the computer (Win XP SP3) and the printer (HP Officejet 6500). I have also tried to print as an image and that does not work either.
Any other suggestions?
Did you also run the patch?
Guest
Yes, I did. And restarted everything again afterwards.
Lisa Smith
703-401-2831
