Loop through XML
Feb 1, 2012 4:36 PM
I am looking for an example of how to loop through an xml structure, preferrably in VBScript, but I will take a Javascript example and try to figure out how to adapt it.
Is a FOR EACH loop possible? In normal VBScript you can do something like this...
‘strQuery = “/ProfilesInfo/Profiles/ProfileInfo/Profile/Fields/Field [Name='ProfileUri' or Name= 'Age'] /(Name|Value)”
Set colNodes = xmlDoc.selectNodes( strQuery )
If colNodes.length>0 Then
For Each objNode in colNodes
Print objNode.nodeName & “: ” & objNode.text
Next
is it possible to do something like this with XML? Maybe something like
For each node in myDocument.XMLElements.Item(1)
     {do something}
Next
If there is a better way, and I am sure there is, I'll take an example of that instead.
I am sure there is probably a way to do it with XPath, but I haven't been able to find any examples of using XPath with VBScript.
If anyone has an example of how to use XPath with VBScript I would greatly appreciate it.
Thank you
  • John Hawkinson
    Jun 25, 2009
    Feb 1, 2012 10:51 PM   in reply to BigGunN
    Feb 1, 2012 11:01 PM   in reply to BigGunN
    You can do this using XML rules. Check out a chapter of the same name in the InDesign CS5 Scripting Guide (VB version). There you will find many examples.
    You can indicate which nodes you want to process with XPath. For example, this will match on every XML element in the XML structure:
    Public Property Get xpath
         xpath = "//*"
    End Property
    And this matches all following sibling XML elements of the first "item" XML element:
         xpath = "/xmlElement/item[1]/following-sibling::*"
    End Property
