This sounds funny, but here is my scenario:
I got 10 operations in a process. In the 6th step, it fetches the username to be assigned in the 7th step from the custom DB using JDBC service.
Unfortunately, the username was not maintained properly (with some mistyping in the DB). In the 7th step, I use Assign User service which takes the username got from 6th step. As it cannot find the username (as it was a mis-spelt name), the operation stalls.
If I see the status of the process,
I see
step1 - COMPLETE
step 5 - COMPLETE
step 6 - COMPLETE (fetching record from DB)
step 7 - STALLED (with error - user name doesnot exist)
i realized the error and corrected the Custom DB with right username.
Now my question is, How can I re-execute the whole process from step 6?
I checked it, but adminui doesnot allow to re-run the operations with COMPLETE status. if I rerun the step 7, there's no use as it is still holding the wrong user name.
Only option i see is asking the users to trigger it again from step 1 which doesnt make any sense for user as they think it's a re-work for them again and also there are multiple users in between the process who approves the form and they all have to rework on this.
highly appreciate your help on this.
kc
This can be done!
Do not let the Operation Stall because of Invalid Principal. Because this cannot be retried using AdminUI.
Instead, stall the Branch so that you can retry the Branch through AdminUI.
Catch the Invalid Exception from AssignTask activity and connect to a Stall activity (as shown in the attached screenshot).
This will cause your branch to stall. After correcting the UserName in DB, you can retry the branch which will resume its execution from Step 6.
Hope that helps..
Nith
Hi Nith,
I tried exactly the same way and it worked perfectly in my test system. However in my prod system,
After I added the exception and routed to the stall process, I saw that process got halted this (below screen shot) way. After the invalid principal exception thrown, it should goto the next step which is Stall process that generates the stalled branch error.
As it got stopped here, now its not even allowing me to retry the operation. The process status is still in running state. I'm suing 8.2 ES.
I'm not understanding why the same steps worked in Test system, and not in Prod system.
very much appreciated if you can help me on this:
In PROD:
| Operation Name | Status | Branch Name | Start Date | Completed Date | |
| Employee Owner Review | EXCEPTION THROWN | main-branch | February 7, 2012 11:15:04 AM EST | ||
| Assignments [3] | COMPLETE | main-branch | December 19, 2011 12:14:33 PM EST | December 19, 2011 12:14:33 PM EST | |
| Search E Owner | COMPLETE | main-branch | December 19, 2011 12:14:22 PM EST | December 19, 2011 12:14:32 PM EST | |
| Apply Rights | COMPLETE | main-branch | December 19, 2011 12:14:22 PM EST | December 19, 2011 12:14:22 PM EST |
In TEST: (this throws the branch error - execute13 is the stall process)
| execute13 | COMPLETE | main-branch | February 8, 2012 12:16:25 PM EST | February 8, 2012 12:16:25 PM EST | |
| Employee Owner Review | EXCEPTION THROWN | main-branch | February 8, 2012 12:16:24 PM EST | ||
| Search E Owner | COMPLETE | main-branch | February 8, 2012 12:15:34 PM EST | February 8, 2012 12:15:40 PM EST |
kc
