Creating sequential, non-consecutive Numbered Lists throughout doc
Mar 15, 2011 1:19 PM
Ok, I know someone is going to tell me there's already a discusson on this topic so I'm telling you right now, I have searched the Forum every which-way on this question and came up blank. So thank you for bearing with me ...
I am sure this is a very simple remedy but for some reason I just cannot figure it out/find the solution. Needless to say, I am very frustrated!
I have a long document with several different areas where there are numbered lists, each beginning with the number 1:
1. text here
2. more text here
Another paragraph or 2 here. Then another numbered list:
1. blah blah
2. blah blah blah
3. and so on
I have the first batch of numbered items (1-5) formatted and styled. No problem. When I apply the style to the next batch of numbered items (a few paragrahs down), it begins with #6. When I go into Bullets & Numbering and choose Mode: "Start at ... 1" ALL the numbers display as 1, including those further up in the document.
What's the secret here??
HELP?!
Thank you!!
    Mar 15, 2011 1:34 PM   in reply to kimberfo45
    Sounds like you need to set the list to restart numbering after any other intervening paragraph style...
    Mar 15, 2011 2:05 PM   in reply to kimberfo45
    1. text here
    2. more text here
    1. blah blah
    2. blah blah blah
    3. and so on
    HELP?!
    Thank you!!
    Yeah, it's frustrating when searches fail, no matter what you try.
    I usually suggest searching Google, rather than InDesign (or other app's) Help, because resources from Adobe forums, Adobe on-line documentation/help, and lots of related sites all produce good suggestions. Search Google for terms like "InDesign restart numbered list" without quotes to find a few good tips near the top of the returned links, from Adobe's LiveDocs. Those that indicate CS3 or CS4 usually have links to the same topic in CS5 docs.
    HTH
    Peter
    _______________________
    Peter Gold
    KnowHow ProServices
    Mar 15, 2011 2:15 PM   in reply to kimberfo45
    I don't do a lot of work with lists, so let's see if I can remember how this goes....
    Define a new list and make the numbers you want to resart level 2. Go to the style definition for your intervening style and make it also a numbered list, using the same list you just defined, but set this one to start at 0, and make it level 1. Make the number fomatting None and leave the character style blank, as well as the number text field so no actual numbers will be added for these paragraphs, and leve the indents at 0 or whatever the correct indents for the syle might be.
    I think that's right, but maybe Eugene or one of the others who regularly use lists will chime in with a better description.
    Mar 15, 2011 2:24 PM   in reply to kimberfo45
    If you can't get it to automate, there's always manual restart numbering: http://help.adobe.com/en_US/indesign/cs/using/WSC105E394-B092-44cf-94D F-FD13EC1211EAa.html
    Mar 16, 2011 4:08 PM   in reply to kimberfo45
    kimberfo45 wrote:
    Thanks Peter (#2) ... I did try that and got an override in my "numbered list" paragraph style. When I "redefined" the style, it applied all 1's to each list. Ex:
    1. dkafj dslkfj a
    1. glake alkjfd
    1. agldkj falkjs
    1. aldfkj lfajk
    Ad nauseum.
    BTW, I have searched all over the web for help with this! I've been on this for over 2 hours and not making much progress. Many of the vids are good for basic bullets & numbering but they do not reveal the secret to non consecutive numbering throughout a long doc!!!
    Yes, Indeed ... verrrrrry frustrating!
    Thanks again! I'm here if you have any other suggestions re styling. Otherwise, I'm just going to leave that "+" sign where it is and hold my breath!!
    kimberlee
    It's not clear exactly which of the suggestions in the links that result from the Google search I suggested. Maybe there was too much information, maybe you tried to apply some suggestion(s) to what you have in place that's not working. Your example shows that you're using a restart-at-1 paragraph for all the steps in the list. So, let's start over.
    You need two paragraph styles to manage multiple list instances. One style starts the list, the other continues the numbering. The continuing is easy; the restarting seems to confound some folks because there are two ways to approach it.
    You also need a named list, so that it's isolated from other lists with different names.
    Here's the general idea:
    * Create a named list with Type > Bulleted & Numbered Lists > Define Lists
    * Create a paragraph style that uses the defined numbered list and continues numbering from previous
    * Create a paragraph style that uses the defined numbered list, and does one of the following:
    - restarts the numbering from 1 and includes the ^1 numbering placeholder
      NOTE: PRO: It's easy to remember that a paragraph style that includes "restart" in its name must be used to restart list numbering
                   CON: If the first item in the list is deleted or moved elsewhere in the list, it must be retagged with a style that increments the list number, rather than restarting it, and the new first paragraph in the list must be retagged with the restart-at-1 style.
      - restarts the numbering from 0 (zero) and includes no numbering placeholders
    NOTE: PRO: Moving the first item in the list to another position, or deleting it, doesn't require retagging it, and the new first paragraph also doesn't need retagging.
               CON: It may take some effort to remember to precede a list with an "invisible zero list resetter" paragraph style. It's a bit easier if the style guide requires an introductory paragraph style to precede new lists.
    The paragraph defined above uses the numbered list "named list," and restarts auto-numbering at 1. Not shown is the General > Next Style that designates "continuednumber" as the style applied to a new paragraph created when Enter/Return is pressed.
    The paragraph defined above uses the numbered list "named list," and restarts auto-numbering at 0 (zero) invisibly, because the Numbering Style > Number text box is empty.
    NOTE: Either of the restart-numbering styles creates a following paragraph a "continuednumber" paragraph style, which increments the list's number by 1.
    Here are some examples:
    HTH
    Peter
    Peter Gold
    KnowHow ProServices
    Mar 17, 2011 10:10 AM   in reply to kimberfo45
    kimberfo45 wrote:
    Hi Peter,
    I sure appreciate your help and all the details! It seems so much more complicated than it needs to be, doesn't it? In my research, I have discovered I am not alone in my frustration with InDesign's numbered list procedure! David Blatner does a video/blog on this topic in InDesign Secrets and there is a huge discussion, revealing complaints and frustrations from other designers (pleading with Adobe for a fix in CS5 but alas, it's not there ... yet).
    I finally reached my former InDesign teacher and for the benefit of everyone, I am posting her suggestion ... WHICH WORKED! Caveat: when I did multiple levels, I did use a Defined List, but did not with basic numbering (1, 2, 3, etc.).
    Here's what you can do:
    1.  Create a style for numbered lists and make them continuous.
    2.  Create all your text:
    1. text here
    2. more text here
    3. blah blah
    4. blah blah blah
    5. and so on
    Then, all you do is select the #3 paragraph and have it start at 1 [right click > Restart Numbering]. Don't select #4 and #5, and don't change the style.
    What I found is that the style I had created auto-redefined after restarting the numbering ... WHEW, I hate seeing that little "+" sign!
    Thank you again for all your help!
    Happy Green Beer Day,
    Kimberlee
    Hi, Kimberlee:
    You're welcome.
    You're correct about there seeming to be a lot to explaining this stuff. IMO, it's necessary here, and in other forum discussions, because of how the forum model affects how folks communicate. Often, the way a query is first posted, it seems that the poster has some knowledge and experience that merits a particular level of response; sometimes this is a wrong assessment. Also, responses are often too terse, too personal to the responder and not clear to the rest of us, and may leave essentials unstated. Then, the back-and-forth, and the piling-on begins. Some responders try to fix omissions or other errata (as they see it) in the offered responses. Rinse and repeat.
    It's pretty simple, and as you illustrate in your example, a resetting operation is needed to restart a numbered list. There are different ways to achieve this reset, as I described earlier.
    Your example may work for projects whose contents are at or near completion; this describes probably most designers' work. But it invites madness if and when that content requires re-ordering of numbered items, whether in a project that's given to a designer, and then must be revised before final lockdown.
    Authors are much more likely to need to rearrange content often, as their grasp and development of content reveal other organization that improves clarity and an audience's understanding. Here's where the use of named lists everywhere, a continuing-autonumber paragraph style for list items, and a pre-list paragraph style that resets new lists with either the invisible-zero, or visible-1 method. It's more common to rearrange numbered list items, than to change a list that starts at 1 to a list than continues from a previous fragment. By having all list items tagged with the continuing (increment-by-1) property, there's no need to manually retag an item that's promoted to the first position with the appropriate paragraph style, or by the select-and-apply-restart method, and also change the former first step to a continued-numbering paragraph style, or apply the numbering property.
    Well planned styles and careful consistent use of styles is especially useful where more than a single person works on the file. IMO, the worst-case scenario imaginable is a team that's untrained to the process, or who doesn't stick to it consistently, that collaborates on a document that contains ad-hoc formatted unnamed lists sprinkled through it.
    My earlier detailed response isn't complete; it's longish because I wanted to avoid omissions and assumptions that could interfere with understanding the relatively-simple use of the process, once it's set up.
    HTH
    Peter
    Peter Gold
    KnowHow ProServices
    Feb 2, 2012 7:25 AM   in reply to peter at knowhowpro
    How comforting to come across a known name the first time I try and find an answer in the InDesign forum!
    I'm finally getting to grips with ID by trying to reproduce a FrameMaker book, and until I read your posts I couldn't grok how to restart numbering with an invisible counter. Seems to work now ...  I'll be back once I've worked out how to formulate my questions about graphics placement ;-}
    Niels Grundtvig Nielsen
    You know what you're talking about - I can help you say it
    www.kbss27.be
    Feb 2, 2012 7:37 AM   in reply to kimberfo45
    Set other styles that are not numbered to Start at 0
    Then remove any of the Numbering formating like so:
    Then set the numbered paragraphs to continue from previous number.
    Feb 3, 2012 12:51 AM   in reply to Eugene Tyson
    Yup, that's the secret! Thanks for the screenshot.
    Aug 19, 2012 10:32 PM   in reply to kimberfo45
    Insert the cursor at the beginning of the subsequent list (where you want to start at 1 again):
    Type > Bulleted & Numbered Lists > Restart Numbering
    Nov 27, 2012 12:08 PM   in reply to peter at knowhowpro
    This is the same response I got from the awesome folks at Luminous Works in Seattle.
    Simply create a new paragraph stlye based on your exhisting.  Then change just one setting: in the Bullets and Numbering panel set the Mode dropdown from "Continue from Previous Number" to "Start At".
    Once you have created this Paragraph Style apply it to the first item in the sections that you want to start over at the number 1.
    Simple and easy.
