Hello all:
I've built a small plugin that creates PDFs out of InDesign documents. I set the following export options just prior to generating the PDF (sorry about the table format--the forum editor is doing that--not me):
| InterfacePtr<IPDFExportPrefs> CmdExportPrefs(PrintOnePDFCommand, UseDefaultIID()); |
| CmdExportPrefs -> SetAddStructure( | kFalse); | // Tagged PDF | |
| CmdExportPrefs -> SetIncludeSlug( | kTrue); | ||
| CmdExportPrefs -> SetUseDocumentBleed(kFalse); |
| CmdExportPrefs -> SetPDFExMarkLineWeight( | .25); | |
| CmdExportPrefs -> SetPDFExPrinterMarksOffset( 21); | // .29 inches roughly equals 21 | |
| CmdExportPrefs -> SetPDFExSubsetFontsThreshold(100); | // 100% of subsetted fonts are embedded |
| CmdExportPrefs -> SetPDFExBleedTop( | 9); | |
| CmdExportPrefs -> SetPDFExBleedBottom( | 9); |
| CmdExportPrefs -> SetPDFExBleedInside( | 9); | |
| CmdExportPrefs -> SetPDFExBleedOutside( | 9); |
| CmdExportPrefs -> SetPDFExAcrobatCompatibilityLevel( | IPDFExportPrefs::kPDFVersion16); | |
| CmdExportPrefs -> SetPDFExBleed( | IPDFExportPrefs::kExportBleedON); |
| CmdExportPrefs -> SetPDFExColorBars( | IPDFExportPrefs::kExportColorBarsOFF); |
| CmdExportPrefs -> SetPDFExCompressColorImages(IPDFExportPrefs::kExportCompressImagesAut oLZWJPEGHigh); // Quality? | |
| CmdExportPrefs -> SetPDFExCompressGrayImages( IPDFExportPrefs::kExportCompressImagesAutoLZWJPEGHigh); // Quality? |
| CmdExportPrefs -> SetPDFExColorSpace( | IPDFExportPrefs::kExportPDFColorSpacePassthru); |
| CmdExportPrefs -> SetPDFExCompressLineArtAndText( IPDFExportPrefs::kExportCompressLineArtAndTextON); | ||
| CmdExportPrefs -> SetPDFExCompressMonoImages( | IPDFExportPrefs::kExportCompressImagesCCITTGroup4); // Quality? |
| CmdExportPrefs -> SetPDFExCropMarks( | IPDFExportPrefs::kExportCropMarksON); |
| CmdExportPrefs -> SetPDFExDisallowImageCrop( | IPDFExportPrefs::kExportDisallowImageCropOFF); // Crop image to frame |
| CmdExportPrefs -> SetPDFExIncludeICCProfiles( | IPDFExportPrefs::kExportIncludeICCProfilesOFF); | |
| CmdExportPrefs -> SetPDFExPageInfo( | IPDFExportPrefs::kExportPageInfoON); |
| CmdExportPrefs -> SetPDFExReaderSpreads( | IPDFExportPrefs::kExportReaderSpreadsOFF); | |
| CmdExportPrefs -> SetPDFExRegistrationMarks( | IPDFExportPrefs::kExportRegistrationMarksOFF); | |
| CmdExportPrefs -> SetPDFExThumbnails( | IPDFExportPrefs::kExportThumbnailsOFF); |
| CmdExportPrefs -> SetPDFExLinearized( | IPDFExportPrefs::kExportLinearizedOFF); |
| // process kSetPDFExportPrefsCmdBoss to change current settings | |||
| InterfacePtr<ICommand> SetPDFExportPrefsCmd(CmdUtils::CreateCommand(kSetPDFExportPrefsCmdBos s)); | |||
| if (SetPDFExportPrefsCmd == nil) | |||
| ASSERT_FAIL("Failed to get setPDFExportPrefsCmd"); | |||
| break; | |||
| InterfacePtr<IPDFExportPrefs> pdfExportPrefs(SetPDFExportPrefsCmd, UseDefaultIID()); | |||
| if (pdfExportPrefs == nil) | |||
| ASSERT_FAIL("Failed to get IPDFExportPrefs/pdfExportPrefs"); | |||
| break; | |||
| pdfExportPrefs -> CopyPrefs(CmdExportPrefs); | |||
| CmdUtils::ProcessCommand(SetPDFExportPrefsCmd); |
With this set of options, some of our images are getting downsampled to 150 dpi when they otherwise have decent resolution.
I removed all the compression lines, for example:
| CmdExportPrefs -> SetCompressColorAbove( | 300); | //Color: 300JPEG | |
| CmdExportPrefs -> SetCompressGrayAbove( | 300); | //Grayscale 300JPEG | |
| CmdExportPrefs -> SetCompressMonochromeAbove( 1200); | // 1 bit 1200 CCITT |
Suddenly all of our images were downsampled to 150 dpi. What's making that happen? How can I stop it?
TIA!
John
Not originally, but later on as I studied IPDFExports.h and found them. Interestingly enough they did little.
What finally seemed to fix the problem was a combination of the code you suggest and setting the compression member functions to high. Here’s the code:
CmdExportPrefs -> SetPDFExSampleColorImages(IPDFExportPrefs::kExportSampleImagesByBicub icDownsampling);
CmdExportPrefs -> SetPDFExSampleColorImagesXRes((int32) 300);
CmdExportPrefs -> SetPDFExSampleColorImagesYRes((int32) 300);
CmdExportPrefs -> SetPDFExSampleGrayImages(IPDFExportPrefs::kExportSampleImagesByBicubi cDownsampling);
CmdExportPrefs -> SetPDFExSampleGrayImagesXRes((int32) 300);
CmdExportPrefs -> SetPDFExSampleGrayImagesYRes((int32) 300);
CmdExportPrefs -> SetPDFExSampleMonoImages(IPDFExportPrefs::kExportSampleImagesByBicubi cDownsampling);
CmdExportPrefs -> SetPDFExSampleMonoImagesXRes((int32) 1200);
CmdExportPrefs -> SetPDFExSampleMonoImagesYRes((int32) 1200);
CmdExportPrefs -> SetCompressColorAbove( 300); //Color: 300JPEG
CmdExportPrefs -> SetCompressGrayAbove( 300); //Grayscale 300JPEG
CmdExportPrefs -> SetCompressMonochromeAbove( 1200); // 1 bit 1200 CCITT
CmdExportPrefs -> SetPDFExCompressMonoImages( IPDFExportPrefs::kExportCompressImagesCCITTGroup4); // Quality?
Thanks for the information, Norio.
R,
John
