bandl44
Buttons do not work in Encore
Feb 5, 2012 8:29 AM
Tags: #cs5 #adobe #buttons #menu #blu-ray #encore #dvd #build #menus
I posted a question earlier  (about 1 hour ago), that is still unsolved.  But I have more problems with Encore buttons.  If I want to delete, stop a process, or anything else I get the "Are you sure you want to do this..." window with the "yes" and "no" choices.  regardless of which I choose... nothing happens!  The only way I have to get out of this window is hitting the Esc key, but then, of course, the choice is not excecuted.  What am I doing wrong?
    Feb 5, 2012 10:21 AM   in reply to bandl44
    No idea... but, for here, you need to provide DETAILS for anyone to help
    Examples below... not all for Encore, but the kind of information you need to supply
    Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
    What is a CODEC... a Primer http://forums.adobe.com/thread/546811
    What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
    Report back with the codec details of your file, use the programs below... a screen shot works well to SHOW people what you are doing
    For PC http://www.headbands.com/gspot/ or http://mediainfo.sourceforge.net/en
    For Mac http://mediainfo.massanti.com/
    http://blogs.adobe.com/premiereprotraining/2011/02/red-yellow-and-gree n-render-bars.html
    Once you know exactly what it is you are editing, report back with that information... and your project setting, and if there is a red line above the video in the timeline, which indicates a mismatch between video and project
    More information needed for someone to help http://forums.adobe.com/thread/416679
    Some is general about your computer and OS, some is specific to video editing
    Build a Configuration file http://www.piriform.com/speccy
    Brand/Model Computer (or Brand/Model Motherboard if self-built)
    How much system memory you have installed, such as 2Gig or ???
    Operating System version, such as Win7 64bit Pro... or whatevevr
    -including your security settings, such as are YOU the Administrator
    -and have you tried to RIGHT click the program Icon and then select
    -the Run as Administrator option (for Windows, not sure about Mac)
    Your Firewall settings and brand of anti-virus are you running
    Brand/Model graphics card, sush as ATI "xxxx" or nVidia "xxxx"
    -or the brand/model graphics chip if on the motherboard
    -and the exact driver version for the above graphics card/chip
    -and how much video memory you have on your graphics card
    Brand/Model sound card, or sound "chip" name on Motherboard
    -and the exact driver version for the above sound card/chip
    Size(s) and configuration of your hard drive(s)... example below
    -and how much FREE space is available on each drive (in Windows
    -you RIGHT click the drive letter while using Windows Explorer
    -and then select the Properties option to see used/free space)
    Windows Indexing is BAD http://forums.adobe.com/thread/676303
    While in Properties, be sure you have drive indexing set OFF
    -for the drive, and for all directories, to improve performance
    Some/Much of the above are available by going to the Windows
    Control Panel and then the Hardware option (Win7 option name)
    OR Control Panel--System--Hardware Tab--Device Manager for WinXP
    And the EXACT type and size of file that is causing you problems
    -for pictures, that includes the camera used and the pixel dimensions
    Plus Video-Specific Information http://forums.adobe.com/thread/459220
    Read Bill Hunt on editing a VOB/MPG file http://forums.adobe.com/thread/464549
    Edit Vob http://premierepro.wikia.com/wiki/FAQ:How_do_I_import_VOB_files_/_edit _a_DVD%3F
    Read Hunt on Using MOD/TOD files http://forums.adobe.com/thread/699990
    Work through all of the steps (ideas) listed at http://forums.adobe.com/thread/459220
    If your problem isn't fixed after you follow all of the steps, report back with ALL OF THE DETAILS asked for in the FINALLY section at the troubleshooting link
    Also read file troubleshooting http://kb2.adobe.com/cps/407/kb407928.html
    Error Compiling http://premierepro.wikia.com/wiki/Error:Error_compiling_movie
    Reset Corrupted Preferences = Press/HOLD Ctrl+Alt+Shift while starting program
    Feb 5, 2012 5:06 PM   in reply to bandl44
    I don't do BluRay, so only have 2 quick comments (maybe someone who does BluRay will add)
    1-make sure your nVidia driver is up to date
    2-make sure your writing drive firmware is up to date
    Feb 5, 2012 7:18 PM   in reply to bandl44
    What "buttons" are you talking about? Please post a screenshot of what you are describing.
    Feb 6, 2012 6:07 AM   in reply to bandl44
    Obviously, this is not normal. I vaguely recall someone else with similar issues. I would try a reinstall.
    Are other Adobe things working okay? If so, try a repair install of Encore.
    Not where I can give you a link to that info.
    Feb 6, 2012 6:49 AM   in reply to bandl44
    Ed,
    I does sound like a GUI display issue, if the BD/DVD radio button on the New Project dialog box is not working. [I thought that you were going to be having issues with Menu Buttons, but am incorrect.]
    I second John T's rec. to update the video driver to the latest. Do that from either the card mfgr's. Web site, or if you have a Dell, HP, or other major mfgr's. computer, check their site. Do NOT trust Windows, or any utility, to tell you if you have the latest.
    Next, and while I have not seen GUI issues recently, check your mouse driver - there were some bad intelliPoint (MS), and SetPoint (Logitec) mouse drivers, that caused all sorst of GUI issues with Adobe programs. Always worth testing, though the mouse drivers over the last few years seem stable.
    There are also some other causes for GUI issues, such as the monitor's resolution, and also some "features" in the OS, like Aero in Windows, that can render dialog box buttons inoperative.
    As for your last screen-cap, that is telling you that you have already created a Project in that Path, with the name "Untitled." Your options are to overwrite that, or change the Name, or Path, to be something different.
    Good luck,
    Hunt
    Feb 6, 2012 12:41 PM   in reply to bandl44
    Excellent! Now if I can just remember this fix until I can add it to the list at home...
    Feb 7, 2012 7:08 PM   in reply to bandl44
    Great news, and so very glad to have helped, even in a tiny way.
    Happy authoring,
    Hunt
