File icons are not showing in Files panel of Dreamweaver CS5.5 Mac
Feb 7, 2012 1:32 AM
Hi, I recently noticed that the icons for the files in the Files panel are missing. Only the folder icons show...
I have ditched the preferences, but no result. Anybody?
    Feb 7, 2012 3:05 AM   in reply to Chinmayo
    This is a known issue with Mac 10.7.3. It's currently being investigated by Adobe engineers.
    Feb 13, 2012 2:02 AM   in reply to Chinmayo
    Hi - I have the same problem - exactly the same... no solutions? Use Lion 10.7.3
    Thanky you Adobe for solving the problem
    Feb 13, 2012 5:03 AM   in reply to David_Powers
    Hi David,
    the same question about "MacOS X Lion 10.7.3" is asked there: http://forums.adobe.com/message/4202546#4202546. When I remember right, you understand japanese language. Would you please have a look there?
    Hans-Günter
    Feb 13, 2012 7:21 AM   in reply to hans-g.
    There's nothing to add to the Japanese thread. You've already translated my earlier comment. All I know from my contacts inside Adobe is that they're investigating. There is no solution yet.
    I don't know if it's related, but the Mac version of Dreamweaver was built using Carbon, the old Mac API. Adobe is in the process of converting Dreamweaver to the Cocoa API. I don't know how far the conversion process has got, but Dreamweaver CS5.5 certainly uses Carbon for some, if not all, parts of the program. Until Dreamweaver is completely "decarbonized", I imagine there will always be a danger of things breaking when Apple releases a new version of Mac OS X.
    Feb 13, 2012 7:39 AM   in reply to David_Powers
    Hi David,
    thank you for your efforts and your detailed information.
    Hans-Günter
    Feb 15, 2012 4:08 PM   in reply to David_Powers
    Hi Guys,
    I'm also experiencing this and I just wanted to mention, it seems when a file is copied and then pasted, the original file icon appears. Granted it doesn't make sense to copy and paste your entire site just to get the icons to show, but on a per-file basis this works.
    -Kennedy
    Feb 25, 2012 6:11 AM   in reply to shiruna
    Anything yet on this situation?
    RD
    Feb 26, 2012 5:55 AM   in reply to Chinmayo
    Just to add a clue to the situation...
    In my case, the icons for the images disappeared first. Then several days later the icons for the HTML files disappeared.
    The blank spaces where the icons should be are still clickable.
    System: Mac OS X 10.7.3
    Dreamweaver: CS5.5
    Mar 20, 2012 3:08 PM   in reply to Chinmayo
    Same problem with Dreamweaver CS 5.
    Mar 26, 2012 1:32 PM   in reply to Chinmayo
    I think I found the solution:
    To bring back the lost icons (on Mac) - go to your user configuration folder for DW, (~user/library/application support/adobe/Dreamweaver/en_US/Configuration) and edit the Extensions.txt file by adding JPG,GIF,PNG,PDF to the first line (should be the line with ':All Documents')
    Now files show up with DW icons and the thousands of console errors are not being generated.
    Adobe should be embarassed that such a simple solution wasn't found by them for this issue. I, like many others have found the lack of communication by Adobe in supporting its products, a major negative for their company. And their lack of support will be reflected in my willingness to give them money for their products.
    Mar 26, 2012 8:14 PM   in reply to crockej
    I think you misunderstood the thread. We're talking about file icons not showing up inside Dreamweaver's FTP browser, not files we've associated with Dreamweaver. I'm also not getting any console errors.
    Mar 27, 2012 5:49 AM   in reply to crockej
    Mar 27, 2012 7:24 AM   in reply to mentlity
    Make sure to include the 3 letter extension of any file that doesn't have an icon in the Extensions.txt file (MOV,SWF,ZIP,FLV).
    Mar 27, 2012 7:37 AM   in reply to crockej
    Did that, still the same.
    rd
    Mar 27, 2012 10:10 AM   in reply to mentlity
    You guys are talking about two different things. The solution posted by crocketj (correct me if I'm wrong) is for files that you want to open with Dreamweaver not displaying a Dreamweaver icon in the finder.
    The problem that mentlity has, which this thread is about, is ALL file icons not appearing inside Dreamweaver's FTP browser.
    These are two totally seperate issues and one solution doesn't fix the other.
    Mar 27, 2012 11:00 AM   in reply to Kennn213
    I was looking at the original post which shows icons not showing in the local view (not the remote view). But for my situation, it fixed the problem for both the local and remote view (on my laptop and my tower). If this solution doesn't work for others, sorry... good luck in finding a solution.
    Apr 7, 2012 12:37 AM   in reply to crockej
    I can confirm that the solution posted by crockej does indeed work, I am not by any means saying that it is a perfect solution, and am sure that it is not the actual fix, but it does work, I landed up having to add JPG,GIF,PNG,PDF,SWF,FLA,ICO,SWZ,MPR,PSD,XLSX,INDD,AI all to fy file list and although this was 90% of the missing icons fixed, it still requires more like m4v etc.
    Think of this as more of a temporary solution to the problem, but it does work.
    This is what my /Users/XXXXX/Library/Application Support/Adobe/Dreamweaver CS5.5/en_US/Configuration/Extensions.txt file looks like now.
    HTM,HTML,SHTM,SHTML,HTA,HTC,XHTML,STM,SSI,JS,JSON,AS,ASC,ASR,XML,XSL,X SD,DTD,XSLT,RSS,RDF,LBI,DWT,ASP,ASA,ASPX,ASCX,ASMX,CONFIG,CS,CSS,CFM,C FML,CFC,TLD,TXT,PHP,PHP3,PHP4,PHP5,PHP-DIST,PHTML,JSP,WML,TPL,LASSO,JS F,VB,VBS,VTM,VTML,INC,SQL,JAVA,EDML,MASTER,INFO,INSTALL,THEME,CONFIG,M ODULE,PROFILE,ENGINE,SVG,JPG,GIF,PNG,PDF,SWF,FLA,ICO,SWZ,MPR,PSD,XLSX, INDD,AI:All Documents
    HTM,HTML,HTA,HTC,XHTML:HTML Documents
    SHTM,SHTML,STM,SSI,INC:Server-Side Includes
    JS,JSON:JavaScript Documents
    XML,DTD,XSD,XSL,XSLT,RSS,RDF:XML Files
    LBI:Library Files
    DWT:Template Files
    CSS:Style Sheets
    ASP,ASA:Active Server Pages
    ASPX,ASCX,ASMX,CS,VB,CONFIG,MASTER:Active Server Plus Pages
    CFM,CFML,CFC:ColdFusion Templates
    AS:ActionScript Files
    ASC:ActionScript Communication Files
    ASR:ActionScript Remote Files
    TXT:Text Files
    PHP,PHP3,PHP4,PHP5,TPL,PHP-DIST,PHTML:PHP Files
    LASSO:Lasso Files
    JSP,JST:Java Server Pages
    JSF:Fireworks Script
    TLD:Tag Library Descriptor Files
    JAVA:Java Files
    SQL:SQL Files
    ASX:Windows Media Advanced Stream Redirector
    WML:WML Files
    EDML:EDML Files
    VBS:VBScript Files
    VTM,VTML:VTML Files
    SVG:Scalable Vector Graphics Files
    Thanks to crockej for finding this semi solution for now.
    Looking for Knysna Accommodation?
    Apr 7, 2012 2:17 AM   in reply to Chinmayo
    Same system here, I am using Apple Lion 10.7.3 build (11D50b), I made the alteration with Dreamweaver CS5.5 closed, opened the file with a raw text editor called text wrangler, because I think a text editor like text edit might just change certain headers etc of the file, made the alterations and saved the file over the original. Launched Dreamweaver and it worked.
    What text editor application did you use, I would only suggest bbedit, text wrangler, or nano / pico through terminal, these ways you will not change permissions or headers of the file you are editing.
    Apr 7, 2012 2:44 AM   in reply to Chinmayo
    Yes it might very well be corrupted now, I have place a copy of the file I use in a yousendit link, give it a try and see if it works for you.
    Extensions.txt
    Apr 7, 2012 2:54 AM   in reply to Chinmayo
    Sorry, I am unsure as to why this is not working for your particular situation, could be multiple reasons, like maybe your Dreamweaver was installed for the root user, or possibly this solution will not work if you have more than 1 user, I am not sure, but happy that it worked for me. Sorry we will have to wait for Adobe to give us all a far better solution to this issue.
    Apr 7, 2012 4:28 AM   in reply to hackintoshUser
    I understand from Adobe engineers that this problem is related to an issue with Mac OS X 10.7.3. Adobe and Apple have been working on the issue, and I'm told that it will be fixed in 10.7.4.
    May 13, 2012 9:43 AM   in reply to Chinmayo
    This problem has been solved!  The latest software update from Apple fixes this issue.  At least it did for me on both of my MacBook Air and iMac.  The update will bring you up to OS X 10.7.4.
    Nov 21, 2012 10:49 AM   in reply to Chinmayo
    My friend you must creat a new site from the site button  at the top middle of the Dreamweaver page then you can see all icons
