How we can write the Flex program to talk with FMG, Is there any example for connecting flex with FMG? And how we can connect the SIP enabled device with FMG?
There is a sample app (server and client) located in /opt/adobe/fmg/FMSApplications/telephony
The client is in FlashPhone/Source
To start use the simple commands to know it is working. i.e. 777 and 888
Once you get it working you can change the SIP.XML and WORKFLOW.XML to make external calls
How to connect the FMG for external calls (ie: pc to ordinary mobile phone)
After Installation, In fmg folder doc/QuickStartGuide.pdf talks about few steps to get started with integration to external SIPGateway to route calls to mobile phones (or whatever the SIPGateway being used allows).
Hope it helps.
