Hi David,
the same question about "MacOS X Lion 10.7.3" is asked there: http://forums.adobe.com/message/4202546#4202546. When I remember right, you understand japanese language. Would you please have a look there?
Hans-Günter
There's nothing to add to the Japanese thread. You've already translated my earlier comment. All I know from my contacts inside Adobe is that they're investigating. There is no solution yet.
I don't know if it's related, but the Mac version of Dreamweaver was built using Carbon, the old Mac API. Adobe is in the process of converting Dreamweaver to the Cocoa API. I don't know how far the conversion process has got, but Dreamweaver CS5.5 certainly uses Carbon for some, if not all, parts of the program. Until Dreamweaver is completely "decarbonized", I imagine there will always be a danger of things breaking when Apple releases a new version of Mac OS X.
I think I found the solution:
To bring back the lost icons (on Mac) - go to your user configuration folder for DW, (~user/library/application support/adobe/Dreamweaver/en_US/Configuration) and edit the Extensions.txt file by adding JPG,GIF,PNG,PDF to the first line (should be the line with ':All Documents')
Now files show up with DW icons and the thousands of console errors are not being generated.
Adobe should be embarassed that such a simple solution wasn't found by them for this issue. I, like many others have found the lack of communication by Adobe in supporting its products, a major negative for their company. And their lack of support will be reflected in my willingness to give them money for their products.
You guys are talking about two different things. The solution posted by crocketj (correct me if I'm wrong) is for files that you want to open with Dreamweaver not displaying a Dreamweaver icon in the finder.
The problem that mentlity has, which this thread is about, is ALL file icons not appearing inside Dreamweaver's FTP browser.
These are two totally seperate issues and one solution doesn't fix the other.
I was looking at the original post which shows icons not showing in the local view (not the remote view). But for my situation, it fixed the problem for both the local and remote view (on my laptop and my tower). If this solution doesn't work for others, sorry... good luck in finding a solution.
I can confirm that the solution posted by crockej does indeed work, I am not by any means saying that it is a perfect solution, and am sure that it is not the actual fix, but it does work, I landed up having to add JPG,GIF,PNG,PDF,SWF,FLA,ICO,SWZ,MPR,PSD,XLSX,INDD,AI all to fy file list and although this was 90% of the missing icons fixed, it still requires more like m4v etc.
Think of this as more of a temporary solution to the problem, but it does work.
This is what my /Users/XXXXX/Library/Application Support/Adobe/Dreamweaver CS5.5/en_US/Configuration/Extensions.txt file looks like now.
HTM,HTML,SHTM,SHTML,HTA,HTC,XHTML,STM,SSI,JS,JSON,AS,ASC,ASR,XML,XSL,X SD,DTD,XSLT,RSS,RDF,LBI,DWT,ASP,ASA,ASPX,ASCX,ASMX,CONFIG,CS,CSS,CFM,C FML,CFC,TLD,TXT,PHP,PHP3,PHP4,PHP5,PHP-DIST,PHTML,JSP,WML,TPL,LASSO,JS F,VB,VBS,VTM,VTML,INC,SQL,JAVA,EDML,MASTER,INFO,INSTALL,THEME,CONFIG,M ODULE,PROFILE,ENGINE,SVG,JPG,GIF,PNG,PDF,SWF,FLA,ICO,SWZ,MPR,PSD,XLSX, INDD,AI:All Documents
HTM,HTML,HTA,HTC,XHTML:HTML Documents
SHTM,SHTML,STM,SSI,INC:Server-Side Includes
JS,JSON:JavaScript Documents
XML,DTD,XSD,XSL,XSLT,RSS,RDF:XML Files
LBI:Library Files
DWT:Template Files
CSS:Style Sheets
ASP,ASA:Active Server Pages
ASPX,ASCX,ASMX,CS,VB,CONFIG,MASTER:Active Server Plus Pages
CFM,CFML,CFC:ColdFusion Templates
AS:ActionScript Files
ASC:ActionScript Communication Files
ASR:ActionScript Remote Files
TXT:Text Files
PHP,PHP3,PHP4,PHP5,TPL,PHP-DIST,PHTML:PHP Files
LASSO:Lasso Files
JSP,JST:Java Server Pages
JSF:Fireworks Script
TLD:Tag Library Descriptor Files
JAVA:Java Files
SQL:SQL Files
ASX:Windows Media Advanced Stream Redirector
WML:WML Files
EDML:EDML Files
VBS:VBScript Files
VTM,VTML:VTML Files
SVG:Scalable Vector Graphics Files
Thanks to crockej for finding this semi solution for now. ![]()
Looking for Knysna Accommodation?
Same system here, I am using Apple Lion 10.7.3 build (11D50b), I made the alteration with Dreamweaver CS5.5 closed, opened the file with a raw text editor called text wrangler, because I think a text editor like text edit might just change certain headers etc of the file, made the alterations and saved the file over the original. Launched Dreamweaver and it worked.
What text editor application did you use, I would only suggest bbedit, text wrangler, or nano / pico through terminal, these ways you will not change permissions or headers of the file you are editing.
Sorry, I am unsure as to why this is not working for your particular situation, could be multiple reasons, like maybe your Dreamweaver was installed for the root user, or possibly this solution will not work if you have more than 1 user, I am not sure, but happy that it worked for me. Sorry
we will have to wait for Adobe to give us all a far better solution to this issue.
