Hi DW friends, I'm working on the
and up to the part "Building a simple recordset". My problem is from inside the server behavior panel when I cliick the plus
button at the top left of the Server Behaviors panel, the drop-down menu appears but there is no option of "Recordset"
Anyone have a suggestion how I can get the Recordset option to appear so I can setup my Recordset????
Details:
Windows Vista
CS5
thanks in advance for help and consideration.
marc
If the servers are running and the connection is OK, I don't see any reason why you can't see Recordset listed. It should be at the top of the menu when you click the plus button in the Server Behaviors panel. It should also be listed in the Bindings panel.
If it's not there in either panel, try shutting down Dreamweaver and restarting. If that still doesn't work, you might need to dump your personal configuration folder (see http://forums.adobe.com/thread/494812).
After that, I'm out of ideas.
David, tks for the reply.... and tks to your reply I realized I was clicking the behavior button.in Tag Inspector panel. (not one of my brightest moments)... I have since opened the correct Server Behavior Panel and evertthing appears as it should.
Thanks again for your time and prompt attention.
