BoozAda
How to make a proper fade (in&out)
Feb 6, 2012 7:53 AM
Tags: #premiere_pro_cs5.5
PremierePro CS 5.5 Windows 7 sourch FullHD
Till now I am disappointed by the way premiere makes fades.
I can do it in the effect window by making keypoints or direcly in the timeline setting keypoints but the fades are never proper. They all flickering somewhere.
When I check the fade in the effectwindow by looking at the transparenty of each frame; it is perfect. But when I see the result after rendering or codering many fades are flickering.
How to make the perfect fade?
    Feb 6, 2012 8:28 AM   in reply to BoozAda
    Turn your playback resolution to full.
    Feb 6, 2012 9:53 AM   in reply to BoozAda
    Welcome to the forum.
    Also, for smoothest playback, be sure to Render that portion of your Timeline, by hitting Enter/Return. You can also restrict the Rendering to just the Transition area, with the WAB (Work Area Bar).
    Good luck,
    Hunt
    Feb 6, 2012 9:55 AM   in reply to BoozAda
    Why not use the dip to black effect under video transitions/dissolve in the effects tab?
    Feb 6, 2012 1:17 PM   in reply to BoozAda
    That shouldn't happen and normally doesn't.
    What are the properties of your media and your sequence?
    Feb 6, 2012 1:20 PM   in reply to BoozAda
    Do they also flicker when MPE is set to software?
    Feb 7, 2012 6:33 AM   in reply to BoozAda
    No that is not what i mean.
    Do you have a CUDA card?
    What are your sequence settings
    What is your source exactly
    And what are your export settings.
    Pref screendumps.
    Feb 7, 2012 11:32 AM   in reply to BoozAda
    Should have mentioned the Black Magic card right up front.
    Make a timeline without the card (native Premiere TL) with the same footage and transitions and see if it still flickers.
    Feb 7, 2012 11:41 AM   in reply to Ann Bens
    In your graphic, item 13, I notice you have spaces between your clips. Close up the spaces and insert your dissolve or fades. PPro does not like empty space.
    Feb 7, 2012 1:45 PM   in reply to cvid01
    I create sequences just like this all the time without issue.  Been doing so since before Premiere went Pro.  This alone should not cause a problem.
    Feb 7, 2012 2:10 PM   in reply to Jim Simon
    It will play it but it won't look right when you encode unless you join up those clips in your timeline and then add the dip to black transition and your good. Once you have the dip to back transition draged to your video clip you can then adjust how it looks in the effect control tab above your preview window.
    Feb 7, 2012 2:12 PM   in reply to bertrenolds
    My exports look exactly the way they do in the sequence, even with gaps.  Always have.
    Feb 7, 2012 2:17 PM   in reply to Jim Simon
    Yea, you will have tons of non-video parts that are just black screen unless that is what you are going for but it does show up exactly like it will be in the timeline when you encode and have gaps.
    Feb 7, 2012 2:40 PM   in reply to BoozAda
    No one has mentioned this yet, but, is the video asset under the fade reasonably constant? does it contain a scene change?  does the clip exposure change under the fade?  If the video is changing, the fade may appear to flicker as the video is being changed by the motion as well as the fade.
    Feb 8, 2012 2:32 AM   in reply to BoozAda
    You need to find out what is causing the problem.
    Premiere does not have issues with keyframing opacity.
    If you use a 3rd party card that is the first place to look.
    Thats why you have to make a Premiere native timeline with the same footage and transitions then export.
    If the export is fine you will know it is the card or the card's software.
    If the export shows the same flickering we have to look elsewere.
    Like is Premiere updated, is your grafics card updated etc.
    You can also put a transparant video or blanc title under the transition; see it that will help.
    Feb 8, 2012 3:37 AM   in reply to BoozAda
    OK.
    If you have MPE hardware on, turn that off and see if there is any difference.
    try the transparant video or a regular transition.
    Feb 8, 2012 11:27 AM   in reply to BoozAda
    I ran into this problem today as well! What I had to do instead of dissolving to "nothing", I had to dissolve to either a black clip or move my media up one track and put a solid black underneath the dissolve to nothing. Worked perfectly, but not sure why it happens!
    Oh, and my source material is XDCAM 1080p29.97, so maybe it's a source format issue?
    Feb 9, 2012 8:14 AM   in reply to BoozAda
    MPE is Mercury Playback Engine. This can be set to software or if the a appropriated card is installed to GPU acceleration. But you have it turned off.
