P.J. Steele 23 posts
Sep 30, 2008
Routing calls based on a leading number
Feb 7, 2012 6:46 AM
Tags: #fmg #workflow #sip
Is it possible to use different profile based on a padded phone number?  Reminiscent of the 'Dial 9 to get out'
i.e. 812345678901
8 = a routing number
12345678901 the phone to call.
I tried changing my workflow.xml without luck
<Context name="rtmp">
     <Condition variable="destNum" value="^8.*$">
          <AppNode sequence="1" app="bridge" args="sip|${destNum}@myContext8"/>
          <AppNode sequence="2" app="hangup" args="null"/>
     </Condition>
</Context>
     <Condition variable="destNum" value="^9.*$">
          <AppNode sequence="1" app="bridge" args="sip|${destNum}@myContext9"/>
     </Condition>
</Context>
    Feb 7, 2012 11:35 AM   in reply to P.J. Steele
    All conditions need to go into one context node (e.g. rtmp in your case). See changed node after strikethrough.
         <Condition variable="destNum" value="^8(.*)$">
              <AppNode sequence="1" app="bridge" args="sip|$1@myContext8"/>
         </Condition>
    </Context>
         <Condition variable="destNum" value="^9(.*)$">
              <AppNode sequence="1" app="bridge" args="sip|$1@myContext9"/>
         </Condition>
    </Context>
    There must be a SIP profileID myContext8 & myContext9 in sip.xml to point to your sip gateway.
    Feb 7, 2012 11:41 AM   in reply to P.J. Steele
       $1 variable in below example would contain the substring after removing prefix 8.
         </Condition>
