yrwiur
Selected photo's folder
Feb 7, 2012 3:09 PM
Tags: #view #folder
After doing a search for all photos that had no keywords I got a number of photos.  I selected the first one and expected the folder in the left hand panel that contained the photo to be highlighted but it wasn't.  It helps to know which folder the picture came from to help identify it.  I finally found that I could do this by adding folder to the grid view options but it took me quite a while to discover this. I could also right click the photo and then pick show in expolrer but this is time consuming.   I don't use LR every day so it's hard to remember all the options and I had to spend 30 minuets finding out how to do this.  I may not have to do this again for months so it will probably take me time to look it up again (getting old).  Maybe it can already be done but I would like to see the folder that the selected photo is in to be highlighted.
    Feb 7, 2012 3:21 PM   in reply to yrwiur
    If you are in a collection, then it's the photo in the collection that is selected, not the image in the folder. If you think about, selecting various iages in a collection and having folders start flashing would be very distracting. But if you have the Default Metadata panel showing you can always click on the arrow to the right of the Folder Name and go directly to that folder and have the image you were on selected.
    Feb 7, 2012 5:11 PM   in reply to yrwiur
    When in a collection right clicking gives the option of showing in explorer as you have discovered while one of the othe options is "Go to Folder in Library". Would that help you?
    Feb 8, 2012 8:43 AM   in reply to yrwiur
    This may not be related to your real question but in order to avoid the problem in the future you might set up a smart collection with the sole criteria being "no keywords." I do extensive keywording and have found this helpful when I forget.
    Feb 8, 2012 10:08 AM   in reply to dgluck1
    Lightroom does that for you....check in the Smart Collections set in the Collections Panel and you'll find a "Without Keywords" smart collection. Was in LR2, LR3 and now LR4 (not sure about LR1, don't have it installed any more).
