JimVag1947
using a clipping mask
Feb 8, 2012 10:33 AM
I saw a video tutorial(here in adobe) as to how a mask is created.
The quesion is if the only way to create a mask is by "placing" an image in the artwork. Let me explain.
I have created a frame and behide it i have placed a blue rectangular, i want the framed "filled" with this blue color.
As i understand it, i will have to use a mask to achieve what i want, nonetheless this seems not to be possible with what i describe above.
SO, can i use mask in what is described above?
If not, what are my alternatives?
    Feb 8, 2012 10:40 AM   in reply to JimVag1947
    Which version of Illustrator are you using?
    You may also want to show a sketch about what you're going to do. It's not that crystal-clear as you may think.
    Feb 8, 2012 10:56 AM   in reply to JimVag1947
    You can use a clipping mask to mask anything, vector objects or placed images.
    What you do is this:
    Put your masking object in front of the object you want to mask.
    Select both and Object > Clipping Mask > Make.
    If your masking object consists of two paths you must make a compound of them before creating your mask.
    Note that all colour attributes that the masking object may have had before the mask was made will disappear, but you can colour the mask separately afterwards.
    A fill to the mask will (strangely) appear behind the masked objects.
    Feb 8, 2012 2:00 PM   in reply to JimVag1947
    Do you want the frame itself Blue?  Or the inside area of the frame Blue?  Either way, it'll be a matter of creating a rectangle or two and manipulating some anchor points as necessary.  Simple stuff.
    Feb 8, 2012 7:37 PM   in reply to JimVag1947
    The generic and better term for what Illustrator calls a Clipping Mask is clipping path. Abiding by this convention would help reduce confusion due to the fact that Illustrator has other masking features which do not have to be paths: Opacity masks.
    But  by your description you merely want to fill a rectangle with a blue color. Neither masking feature is necessary to do that. Simply give the rectangle a blue fill.
    So if that's not what you are trying to do, you need to explain the situation better.
    JET
    Feb 8, 2012 7:59 PM   in reply to JimVag1947
    Is this frme y0ou refer to a raster image that you placed in Illustrator. In the case you might need to amke an Opacity Mask
    Feb 9, 2012 4:04 AM   in reply to JimVag1947
    Put a blue rectangle below the frame objects and group all.
    You could also use Live Paint, but you don't state which version of AI you're using.
    Feb 9, 2012 4:37 AM   in reply to JimVag1947
    Dimitris,
    If I understand it in the right way, you can just set the size of the blue rectangle and move either that or the frame parts. so that its boundaries fit the inner shape of the frame, or just somewhere between the inner and outer shapes; in the latter case, the outermost part of the rectangle is hidden beneath the frame parts.
    Edit: Hi Kurt.
    Feb 9, 2012 5:17 AM   in reply to JimVag1947
    What Jacob says.
    But why don't the corners of the frame line up properly?
    The ends should be cut off at 45° if they are to form a good mitre.
    Feb 12, 2012 4:25 AM   in reply to JimVag1947
    For my part you are welcome, Dimitris.
