It differs a little from what you wrote here. For example, now it says in the documentation:
"For Spotlight search results on iPad, create two icons that measure:50 x 50 pixels", and than "Note that the final visual size of a Spotlight search results icon on iPad is 48 x 48 pixels"
So shouldn't it be ?
Could you clarify it?
There is an error that is thrown when you try to remove the gloss / shine from the icon, this is the code I have:
Once I try to compile the app on the mobile device, I get an error:
Error occurred while packaging the application:
/private/var/folders/zn/znI7EuqSEoGgRID9pjCm-E+++TI/-Tmp-/AOT133495665 1018/someApp-app.xml(238): error 103: application.iPhone is an unexpected element/attribute
This document fails to clarify that if you already have an InfoAdditions node, you do not have to add a new one.
The code provided by Adobe to remove the gloss effect must go inside the existing node, before the UIDeviceFamily.
This is what worked for me:
<InfoAdditions><![CDATA[<key>UIPrerenderedIcon</key><true/><key>UIDevi ceFamily</key><array><string>2</string></array>]]></InfoAdditions>
