jerome.f.2mn
How to activate Time Remapping ? (CS5)
Feb 8, 2012 7:56 AM
Tags: #time-remapping
Hi.
I try to activate time remapping on a Layer, without success.
I tried AEGP_SetLayerFlag without.
I tried the Do_Command hint from here http://forums.adobe.com/message/1799231#1799231 nothing worked.
Here's my portion of code :
    ERR(suites.FootageSuite5()->AEGP_NewFootage(S_my_id,ANIM_pathZ, NULL,&options, AEGP_InterpretationStyle_NO_DIALOG_GUESS, NULL, &ANIMH));
    ERR(suites.FootageSuite5()->AEGP_AddFootageToProject(ANIMH, AnimationfolderH, &ANIM_itemH));
    AEGP_LayerH       ANIM_layerH    = NULL;
    A_Boolean            is_add_validB        = FALSE;
    ERR(suites.LayerSuite5()->AEGP_IsAddLayerValid(ANIM_itemH, AnimationcompH, &is_add_validB));
    if (is_add_validB)
        ERR(suites.LayerSuite5()->AEGP_AddLayer(ANIM_itemH, AnimationcompH, &ANIM_layerH));
        ERR(suites.LayerSuite7()->AEGP_SetLayerFlag(ANIM_layerH,AEGP_LayerFla g_TIME_REMAPPING,true));
        ERR(suites.CommandSuite1()->AEGP_DoCommand(2153));
    Feb 9, 2012 2:07 AM   in reply to jerome.f.2mn
    i don't know why the AEGPDoCommand fails to deliver for you.
    you can however use AEGP_ExecuteScript() and use java from within your plug-in to enable the time remapping.
    here is a thread that shows the complete process of using AEGP_ExecuteScript:
    http://forums.adobe.com/message/3625857#3625857%233625857
    it actually goes into more trouble than you need.
    a simple AEGP_ExecuteScript("simplest java code to enable time remapping") will do the trick.
