I can´t install CS5.5 Master Collection. I´ve allready tried to un/install .NET framework but nothing happened.
What the log says is:
Exit Code: 7
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 140 error(s), 136 warning(s)
----------- Payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 1.0.0.0 -----------
ERROR: Error 1935.An error occurred during the installation of assembly component {43CC1B37-B20C-3EBC-9C04-F809989E4FD3}. HRESULT: 0x80070005.
ERROR: Install MSI payload failed with error: 1603 - Error irrecuperable durante la instalación.
MSI Error message: Error 1935.An error occurred during the installation of assembly component {43CC1B37-B20C-3EBC-9C04-F809989E4FD3}. HRESULT: 0x80070005.
WARNING: DW036: Payload cannot be installed due to dependent operation failure
WARNING: DW036: Payload cannot be installed due to dependent operation failure... and so on
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Adobe ExtendScript Toolkit CS5.5: Install failed
ERROR: DW050: - Adobe Buzzword CS5.5: Install failed
ERROR: DW050: - Adobe Dreamweaver CS5.5: Failed due to Language Pack installation failure
ERROR: DW050: - Microsoft_VC90_ATL_x86: Install failed
ERROR: DW050: - Adobe Linguistics CS5 x64: Install failed
ERROR: DW050: - AIR for Apple iOS support (FB): Install failed
ERROR: DW050: - Digital Publishing: Failed due to Language Pack installation failure
ERROR: DW050: - Microsoft_VC90_CRT_x86: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 Core: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe Premiere Pro CS5.5 Support: Install failed
ERROR: DW050: - Adobe Premiere Pro CS5.5_AdobePremierePro5.5es_ESLanguagePack: Install failed
ERROR: DW050: - Microsoft_VC80_ATL_x86: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 Core_x64: Failed due to Language Pack installation failure
ERROR: DW050: - Recommended Common Fonts Installation x64: Install failed
ERROR: DW050: - Suite Shared Configuration CS5.5: Install failed
ERROR: DW050: - AdobePDFL x64 CS5: Install failed
ERROR: DW050: - DynamiclinkSupport: Install failed
ERROR: DW050: - Microsoft_VC80_MFCLOC_x86_x64: Install failed
ERROR: DW050: - Adobe Audition_AdobeAudition4es_ESLanguagePack: Install failed
ERROR: DW050: - IE Plugin CS5.1: Install failed
ERROR: DW050: - Adobe Illustrator CS5.1: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe XMP Panels CS5: Install failed
ERROR: DW050: - Pixel Bender Toolkit: Install failed
ERROR: DW050: - Adobe WinSoft Linguistics Plugin CS5.5: Install failed
ERROR: DW050: - Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64: Install failed
ERROR: DW050: - Adobe Hunspell Linguistics Plugin CS5.5: Install failed
ERROR: DW050: - CSXS Story Extension: Install failed
ERROR: DW050: - Photoshop Camera Raw: Install failed
ERROR: DW050: - Camera Profiles Installer: Install failed
ERROR: DW050: - Adobe Flash CS5.5_AdobeFlash11.5-es_ESLanguagePack: Install failed
ERROR: DW050: - Adobe Extension Manager CS5.5: Install failed
ERROR: DW050: - Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll: Install failed
ERROR: DW050: - Adobe Flash Player 10 Plugin: Install failed
ERROR: DW050: - AdobeColorCommonSetRGB: Install failed
ERROR: DW050: - Microsoft_VC80_CRT_x86_x64: Install failed
ERROR: DW050: - AdobeColorPhotoshop CS5.5: Install failed
ERROR: DW050: - Firefox Plugin CS5.1: Install failed
ERROR: DW050: - Adobe Linguistics CS5.5: Install failed
ERROR: DW050: - Adobe Digital Publishing Application Language Files_AdobeDigitalPublishingAppLang-es_ES: Install failed
ERROR: DW050: - Adobe Device Central CS5.5: Failed due to Language Pack installation failure
ERROR: DW050: - Office Plugin CS5.1: Install failed
ERROR: DW050: - Adobe Mini Bridge CS5.1: Install failed
ERROR: DW050: - Adobe Contribute CS5.1_AdobeContribute6.1es_ESLanguagePack: Install failed
ERROR: DW050: - AdobeMotionPicture CS5.5: Install failed
ERROR: DW050: - Adobe Dreamweaver CS5.5_AdobeDreamweaver11.5es_ESLanguagePack: Install failed
ERROR: DW050: - Adobe SING CS5: Install failed
ERROR: DW050: - AdobeColorCommonSetCMYK: Install failed
ERROR: DW050: - Adobe OnLocation CS5.1: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe Flash CS5.5_AdobeMobileExtension_Flash11.5-es_ES: Install failed
ERROR: DW050: - Adobe Illustrator CS5.1_AdobeIllustrator15_1es_ESLanguagePack: Install failed
ERROR: DW050: - Adobe InDesign CS5.5 Application Feature Set Files: Install failed
ERROR: DW050: - Photoshop Camera Raw (64 bit): Install failed
ERROR: DW050: - Microsoft_VC90_MFC_x86: Install failed
ERROR: DW050: - Adobe Flash Builder 4.5: Install failed
ERROR: DW050: - Adobe Media Encoder CS5.5 X64: Install failed
ERROR: DW050: - Adobe Encore CS5.1_AdobeEncore5.1es_ESLanguagePack: Install failed
ERROR: DW050: - AIR for APPLE IOS Support (FP): Install failed
ERROR: DW050: - Adobe Linguistics CS5: Install failed
ERROR: DW050: - PDF Settings CS5: Install failed
ERROR: DW050: - AdobeTypeSupport CS5: Install failed
ERROR: DW050: - Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-es_ES: Install failed
ERROR: DW050: - Adobe CSXS Infrastructure CS5.5: Install failed
ERROR: DW050: - Adobe Flash Player 10 ActiveX: Install failed
ERROR: DW050: - Adobe InDesign CS5.5 Common Base Files: Install failed
ERROR: DW050: - Adobe Flash Fonts1: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 Spanish Language Pack_AdobePhotoshop12-es_ES: Install failed
ERROR: DW050: - Adobe After Effects CS5.5 Support: Install failed
ERROR: DW050: - Adobe OnLocation CS5.1 Third Party Content Wrapper: Install failed
ERROR: DW050: - AdobeColorEU CS5.5: Install failed
ERROR: DW050: - AdobeHelp: Install failed
ERROR: DW050: - Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-es_ES: Install failed
ERROR: DW050: - Required Common Fonts Installation x64: Install failed
ERROR: DW050: - Microsoft_VC90_ATL_x86_x64: Install failed
ERROR: DW050: - Adobe InDesign CS5.5 Application Base Files: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe InDesign CS5.5 Icon Handler: Install failed
ERROR: DW050: - Adobe After Effects CS5.5_AdobeAfterEffects10.5es_ESLanguagePack: Install failed
ERROR: DW050: - Adobe Fireworks CS5.1: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe Story: Install failed
ERROR: DW050: - Microsoft_VC90_MFCLOC_x86_x64: Install failed
ERROR: DW050: - Microsoft_VC80_ATL_x86_x64: Install failed
ERROR: DW050: - Microsoft_VC90_CRT_x86_x64: Install failed
ERROR: DW050: - Microsoft_VC80_CRT_x86: Install failed
ERROR: DW050: - Adobe Device Central CS5.5_DeviceCentral3.5LP-es_ES: Install failed
ERROR: DW050: - AdobeCMaps x64 CS5: Install failed
ERROR: DW050: - AdobeTypeSupport x64 CS5: Install failed
ERROR: DW050: - Adobe InDesign CS5.5 Icon Handler x64: Install failed
ERROR: DW050: - Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All: Install failed
ERROR: DW050: - Microsoft_VC90_MFC_x86_x64: Install failed
ERROR: DW050: - AdobeColorJA CS5.5: Install failed
ERROR: DW050: - Adobe OnLocation CS5.1_AdobeOnLocation5.1es_ESLanguagePack: Install failed
ERROR: DW050: - AdobeOutputModule: Install failed
ERROR: DW050: - Acrobat Professional: Install failed
ERROR: DW050: - Adobe WinSoft Linguistics Plugin CS5: Install failed
ERROR: DW050: - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
ERROR: DW050: - Adobe Fireworks CS5.1_AdobeFireworks11.1.0es_ESLanguagePack: Install failed
ERROR: DW050: - Microsoft_VC90_MFCLOC_x86: Install failed
ERROR: DW050: - AIR for APPLE IOS Support Wrapper: Install failed
ERROR: DW050: - AdobePDFL CS5: Install failed
ERROR: DW050: - AdobeCMaps CS5: Install failed
ERROR: DW050: - Adobe Toolhints CS5.5: Install failed
ERROR: DW050: - Adobe CSXS Extensions CS5.5: Install failed
ERROR: DW050: - Adobe After Effects CS5.5 Presets: Install failed
ERROR: DW050: - Adobe After Effects CS5.5 Third Party Content Wrapper: Install failed
ERROR: DW050: - Microsoft_VC80_MFC_x86_x64: Install failed
ERROR: DW050: - ph: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 Spanish Language Pack_x64_AdobePhotoshop12-es_ES_x64: Install failed
ERROR: DW050: - Adobe ReviewPanel CS5.5: Install failed
ERROR: DW050: - Required Common Fonts Installation: Install failed
ERROR: DW050: - AdobeColorVideoProfilesAE CS5.5: Install failed
ERROR: DW050: - AmericanEnglishSpeechAnalysisModels: Install failed
ERROR: DW050: - Adobe Premiere Pro CS5.5: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe Player for Embedding x64 3.1: Install failed
ERROR: DW050: - Adobe SwitchBoard 2.0: Install failed
ERROR: DW050: - HIL Help Search: Install failed
ERROR: DW050: - Microsoft_VC80_MFC_x86: Install failed
ERROR: DW050: - Adobe Player for Embedding 3.1: Install failed
ERROR: DW050: - CS5.5 Master Collection: Install failed
ERROR: DW050: - Adobe Audition: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe Flash Catalyst CS5.5: Install failed
ERROR: DW050: - Microsoft_VC80_MFCLOC_x86: Install failed
ERROR: DW050: - Adobe Flash CS5.5: Failed due to Language Pack installation failure
ERROR: DW050: - SiteCatalyst NetAverages CS5.5: Install failed
ERROR: DW050: - Adobe Contribute CS5.1: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe InDesign CS5.5 Application Base Files2: Install failed
ERROR: DW050: - Adobe Flash CS5.5_AdobeMobileExtension_Flash11.5-mul: Install failed
ERROR: DW050: - Recommended Common Fonts Installation: Install failed
ERROR: DW050: - AdobeColorNA CS5.5: Install failed
ERROR: DW050: - AdobeJRE: Install failed
ERROR: DW050: - Adobe Player for Embedding 3.2: Install failed
ERROR: DW050: - Adobe After Effects CS5.5: Failed due to Language Pack installation failure
ERROR: DW050: - AdobeColorVideoProfilesCS CS5.5: Install failed
ERROR: DW050: - Adobe Bridge CS5.1: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 Support: Install failed
ERROR: DW050: - Adobe Dreamweaver Widget Browser: Install failed
ERROR: DW050: - Adobe Encore CS5.1: Failed due to Language Pack installation failure
ERROR: DW050: - Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All: Install failed
ERROR: DW050: - Adobe Content Viewer: Install failed
PLEASE SOMEBODY HELPS!!!!
