apInc4u
Cannot associate pdf with Reader using Windows 7
Feb 10, 2012 8:04 PM
It took me nearly a half hour just to get this far since I couldn't comment without login, and I couldn't login because my old id must have expired, and then the origina discussion wouldn't let me comment directly on their post, but finally I can say "thank you" to x3sw for posting this same question and a working solution.
Thank you!  Thank you!  Thank you!
Registry edit worked...of course at first it didn't and I didn't know why and then after some investigation I realized that one of the quotation marks was missing and ~viola~, like magic Windows 7 would finally recognize Reader as a viable option for opening PDFs.
    Feb 11, 2012 3:34 AM   in reply to apInc4u
    You may want to take a look at some of the videos in here:
    http://forums.adobe.com/docs/DOC-1021
    Feb 11, 2012 8:34 AM   in reply to apInc4u
    I'm looking for the answer to this same problem but can not find it.  could you please send me a link to the answer.  Thanks
    Feb 11, 2012 5:52 PM   in reply to apInc4u
    From your opening post, I understood that you had solved the problem of the title. I was only trying to help you with your posting problems...
    Feb 11, 2012 8:06 PM   in reply to traveling dot
    The easiest way to associate PDF files with Reader is to uninstall it, then reinstall the latest version.
    Full installer download link: http://get.adobe.com/reader/enterprise/
    Feb 12, 2012 10:01 AM   in reply to Pat Willener
    Pat,
    I tried that and it still didn't work.  I found the answer to my problem from Fran in Ohio's post.  All I had to do was go into my Adobe shortcut and when the screen came up do the following
    Go to
    EDIT
    PREFERENCES
    GENERAL
    then
    UNCHECK -> Enable Prtotected Mode at Startup
    then hit ENTER.
    After that my Adobe worked fine and I was able to view and print information from my Adobe screen.
