Trial version of Illustrator won't finish installing -an error message tells me to close Bridge CS5 but it's not running! What do I do-I need this for school. ( All the folders installed but the program itself won't finish installing). I went to setup exe and did a re-try but got the same message. Need help ASAP ! Thanks!
Hi Adriane,
I believe this is a duplicate thread for the issue you have posted in http://forums.adobe.com/thread/961889?tstart=0.
As per our conversation earlier today, the issue you were facing has been resolved.
Please let us know in case of further issues with the Illustrator trial.
Yes, it is. Check your task manager and terminate the process.
Mylenium
I know what you are saying but when I go to the menu what do I do? Highlight it and then click end process? When I go to applications the only thing that shows running is the AI assistant and task manager. When I do the end process thing a warning message comes up telling me that I could damage something. Are you sure about this? My photoshop is a purchased product. This is just a trial of illustrator. Please advise asap!
Also should the download take 4 hours before the final install? People I have talked to say they never heard of any trial taking 4 hours.
Four hours sounds like a long time, but it really depends on the size of the file you're downloading and the type of connection you're using. Here are some guidelines to help give you a sense of what's expected:
http://kb2.adobe.com/cps/915/cpsid_91596.html#main_How_long_does_it_take_to_download_a_product_
You might also try disabling startup items, and then restarting your computer and trying the download again to make sure that no programs are running.
Here's a doc which guides you how to close the background process for Bridge which is still running:
Hi Adriane,
