AlanTheBeast2
Time Machine not backing up new folder created in Bridge
Feb 11, 2012 12:59 PM
Again, as has happened in the past, I create a folder under Adobe Bridge (photo raws and edits) that doesn't get backed up in TM.
Since I've been burned in the past, I go checking into the TM backup ("Latest") after a backup to be sure the backup occurred and there is no sign of the new folder or files.
Anyone else have non-backups under TM?
(Yes: I checked, the folder in question is not in the TM exclude list);
Anything I'm missing?
  • Omke Oudeman
    Nov 27, 2004
    Feb 12, 2012 3:28 AM   in reply to AlanTheBeast2
    Don't use TM myself, instead I use Synchronize Pro, so can't check my self. But in general. creating a new folder in Bridge it appears on your system and then TM should be able to read it. Can you give some more details.
    Did you use spaces or other characters like hyphens, commas and slashes (',/)
    Where did you save the folder to, nested in another folder or as top of the list folder.
    And you double checked the folder is not locked and you do have read and write permission to it (select the folder and choose get info, at the bottom shows the permissions for the user)
