I used Actobat 9 Pro to create a portfolio containing PDFs, which I set up to enable comments. I then used Acrobat 9 Reader to open several PDFs and created comments. I emailed the portfolio to my workmate who also made comments.
We can see both sets of comments in the PDFs, identified with out user names - which is great.
However, if I print the PDFs, the comments do not appear. Are they only visible on-line? is there any way to print them, with their context in the PDF?
Sue.
The Print dialog obtained from File > Print in Adobe Reader (9) provides for selection of "Document and Markups".
As your screen capture depicts Adobe Reader's Properties does not provide for user configuration of how Comments, Markups, and associated Pop-ups are displayed.
You must have Acrobat Pro (...maybe Standard also) for this functionality.
It seems that there is no way to do this, as no-one has replied. Is there any alternative or work-around?
In the Print dialog ....
Hi Dave.
Yes, that's the setting I'm using when I print from 9 Reader. However, no comments appear on my printed page.
I followed a link on the sidebar on this question - I think it's Re: Print a PDF with sticky notes info visible? It seems you can print a PDF with comments from 9 Pro or 9 Standard, but not from 9 Reader.
This is a shame because we would rather not have to spend the money for a Pro or Standard licence for all our users.
Sue.
PS typo in my original post:
"We can see both sets of comments in the PDFs, identified with out user names" - should be "identified with our user names".
NB I should clarify that I'm using the setting "Document and Markups" when I print from 9 Reader - but no comments appear..
This is what I see in "Preferences" in 9 Reader. Apparently nothing relating to Comments...
Thanks Dave. I'll take this as confirmation that Adobe 9 Reader cannot print comments with a document.
Seems not to work unless you have the professional version at £15/month, which I certainly don't want for a once a year task. Tried print screen from a full page view and dropped the image into .docx seemed to work fine for me.
This option is also available in the free Reader, maybe not Reader 9 but certainly in newer versions. Here's a screenshot from Reader XI:
The only option that's not available in Reader is to print only the values of form fields.
If you can unable to print a pdf with the comment you can follow the steps:-
I have a similar problem. After a very long wait, I receive an error message from Adobe Acrobat Pro that it was expecting a .dic? Dictionary? I use Screenshots to get around this problem. It is much slower and uses more printer ink, but it is better than nothing. Good luck!
