I installed CS5 on my new mac and I tried to open Extension Manager but it doesn't work. I have a open icon in my taskbar but I see nothing.
When I tried to close the program, it did a error message :"Extension Manager a quitté de manière imprévue".
Someone have a issue
? I need it for AIR 2.5 ..
Do you login as administrator? Does your account have write privilege to “/Users/<YourUserName>/Library/Application Support/Adobe/Extension Manager CS5”?
If the answer is yes, you can create a file named “ExManLog.YES” (The content of file doesn't matter, only the file name need be accurate, please uncheck "Hide extension" option in info window to make sure this file name really ends with .YES.) in "/Applications/Adobe Extension Manager CS5/Adobe Extension Manager CS5.app/Contents/MacOS", then startup Extension Manager. you will get two log files in “/Users/<YourUserName>/Library/Application Support/Adobe/Extension Manager CS5”. Could you please upload these log files as attachment so others can give you some help? Thanks.
Like you, my Exten Mgr does not work, but I go all the way to a Problem Report after a 'quit unexpectedly'. I've tried it in a new 'test user' and it DOES run in that environment, while at the same bringing up a number of notices, which mean little to me, about other CS5 applications with which I'm having problems.
Fully 50% of this expensive Design Premium upgrade will not run properly, after all these years with the full range of CS offering, and long before with PageMaker, Distiller, and the rest.
Very frustrating and makes me feel so dumb.
I have the exact same problem on my MacBook Pro / CS 5. After updating all my CS5 apps, I opened Dreamweaver and was given the message about the Extension Manager opening . . . but it never really got up and running. It started and then froze. When I quit, I was given the message that it crashed. I logged out and logged in to other users on my laptop and all was fine. The extension manager loads everything. It just doesn't work for me, the administrator. So it appears there is a permissions issue with a folder / file / preference. Any suggestions?
Nope, no solutions so far. I live without it.
Greg Heuer, CSI
http://www.linkedin.com/in/gheuer
When you think of the long and gloomy history of man, you will find more hideous crimes have been committed in the name of obedience than have ever been committed in the name of rebellion.
- C. P. Snow
I think it should be a permission issue. To help troubleshooting, please save the following commands as a script file, and run it from terminal, e.g. "bin/sh <YourFileName>". A plain text file named "output.txt" will be generated in your home directory. Please upload output.txt so we can get more information about your system.
In addition, there are some locale-dependent directories in these commands. If your locale is not American English (en_US), please replace "en_US" with your locale.
cd ~
ls -ld "./Library/Application Support/Adobe" > output.txt
ls -ld "./Library/Application Support/Adobe/Bridge CS5" >> output.txt
ls -ld "./Library/Application Support/Adobe/Bridge CS5/Configuration" >> output.txt
ls -ld "./Library/Application Support/Adobe/Bridge CS5/Configuration/Extensions" >> output.txt
ls -ld "./Library/Application Support/Adobe/Extension Manager CS5" >> output.txt
ls -ld "./Library/Application Support/Adobe/Extension Manager CS5/Configuration" >> output.txt
ls -ld "./Library/Application Support/Adobe/Extension Manager CS5/Configuration/Extensions" >> output.txt
ls -ld "./Library/Application Support/Adobe/Dreamweaver CS5" >> output.txt
ls -ld "./Library/Application Support/Adobe/Dreamweaver CS5/en_US" >> output.txt
ls -ld "./Library/Application Support/Adobe/Dreamweaver CS5/en_US/Configuration" >> output.txt
ls -ld "./Library/Application Support/Adobe/Dreamweaver CS5/en_US/Configuration/Extensions" >> output.txt
ls -ld "./Library/Application Support/Adobe/Adobe InDesign CS5" >> output.txt
ls -ld "./Library/Application Support/Adobe/Adobe InDesign CS5/Configuration" >> output.txt
ls -ld "./Library/Application Support/Adobe/Adobe InDesign CS5/Configuration/Extensions" >> output.txt
ls -ld "./Library/Application Support/Adobe/Flash CS5" >> output.txt
ls -ld "./Library/Application Support/Adobe/Flash CS5/en_US" >> output.txt
ls -ld "./Library/Application Support/Adobe/Flash CS5/en_US/Configuration" >> output.txt
ls -ld "./Library/Application Support/Adobe/Flash CS5/en_US/Configuration/Extensions" >> output.txt
ls -ld "/Applications/Adobe Illustrator CS5" >> output.txt
ls -ld "/Applications/Adobe Illustrator CS5/Configuration" >> output.txt
ls -ld "/Applications/Adobe Illustrator CS5/Configuration/Extensions" >> output.txt
ls -ld "/Applications/Adobe Photoshop CS5" >> output.txt
ls -ld "/Users/Shared/Library/Application Support/Adobe/Dreamweaver CS5" >> output.txt
ls -ld "/Users/Shared/Library/Application Support/Adobe/Dreamweaver CS5/en_US" >> output.txt
ls -ld "/Users/Shared/Library/Application Support/Adobe/Dreamweaver CS5/en_US/Configuration" >> output.txt
ls -ld "/Users/Shared/Library/Application Support/Adobe/Dreamweaver CS5/en_US/Configuration/Extensions" >> output.txt
ls -ld "/Library/Application Support/Adobe" >> output.txt
ls -ld "/Library/Application Support/Adobe/Extension Manager CS5" >> output.txt
ls -ld "/Library/Application Support/Adobe/Extension Manager CS5/Illustrator CS5" >> output.txt
ls -ld "/Library/Application Support/Adobe/InDesign" >> output.txt
ls -ld "/Library/Application Support/Adobe/InDesign/Version 7.0" >> output.txt
ls -ld "/Library/Application Support/Adobe/InDesign/Version 7.0/EmStorePath" >> output.txt
ls -ld "/Library/Application Support/Adobe/InDesign/Version 7.0/en_US" >> output.txt
ls -ld "/Library/Application Support/Adobe/InDesign/Version 7.0/en_US/Extensions" >> output.txt
ls -ld "/Library/Application Support/Adobe/Extension Manager" >> output.txt
ls -ld "/Library/Application Support/Adobe/Extension Manager CS5/FlashCS5" >> output.txt
ls -ld "/Library/Application Support/Adobe/Fireworks CS5" >> output.txt
ls -ld "/Library/Application Support/Adobe/Fireworks CS5/EmStorePath" >> output.txt
ls -ld "/Library/Application Support/Adobe/Fireworks CS5/Extensions" >> output.txt
ls -ld "/Library/Application Support/Adobe/Fireworks CS5/PreInstall" >> output.txt
I am having the same issue. The user is an admin. Brand new install of OS & CS5 Design Premium. Do not have this issue on any of the 250 machines that this build is out there on. Extension Manager starts and no window comes up. No, spaces is not on. Log in as another user. Extension Manager starts. Go into Library/Application Support/Adobe....there isn't an Extension Manager folder.
Thoughts?
Have you tried to run Extension Manager using sudo command? That the user is admin doesn't means that every application you start up will be run with administrative privilege. If with sudo command you can launch Extension Manager successfully, subsequent launch will not need sudo. If it still doesn't work, could you please generate log files and upload them as attachment according to the first reply in this thread?
Please verify whether you have write privilege for the following folders. (If you have not installed some products, you can ignore corresponding folders). If not, grant youself write privilege. If some of these folders don’t exist yet, you can create them manually and grant write privilege.
/Library/Application Support/Adobe/InDesign/Version 7.0/<Locale>/Extensions
/Library/Application Support/Adobe/ Premiere Pro CS5/Configuration/Extensions
/Library/Application Support/Adobe/Extension Manager CS5/ Premiere Pro CS5
/Users/<UserName>/Library/Application Support/Adobe/Flash CS5/<Locale>/Configuration/Extensions
/Users/<UserName>/Library/Application Support/Adobe/ Adobe Contribute CS5/<Locale>/Configuration/Extensions
/Users/<UserName>/Library/Application Support/Adobe/Adobe InDesign CS5/Configuration/Extensions
/Users/<UserName>/Library/Application Support/Adobe/Bridge CS5/Configuration/Extensions
/Users/<UserName>/Library/Application Support/Adobe/Dreamweaver CS5/<Locale>/Configuration/Extensions
/Users/<UserName>/Library/Application Support/Adobe/Extension Manager CS5/Configuration/Extensions
/Users/Shared/Library/Application Support/Adobe/Dreamweaver CS5/<Locale>/Configuration/Extensions
Orange directories are created by CS installer, green directories are created by ExMan during the first launch, blue directories are created by ExMan when necessary.
Have you install Flash FireBug? It conflicts with Extension Manager. Is the window of Extension Manager visible or nothing is displayed when crash?
1. Please move all files under "/Users/<UserName>/Library/Preferences/Macromedia/Flash Player/#Security/FlashPlayerTrust" and "/Library/Application Support/Macromedia/FlashPlayerTrust" to somewhere else, then start up Extension Manager.
2. If it doesn't help, move all above files back. please generate log files to help troubleshooting.
Extension Manager CS5 should be used with Photoshop 5.02. You can download Extension Manager CS5 from http://www.adobe.com/exchange/em_download/em50_download.html. If you use Mac OS X 10.7 (Lion), after installing Extension Manager CS5, you will be notified to update to 5.0.2. You can also install 5.0.2 patch manually (click http://download.macromedia.com/pub/dw_exchange/extension_manager/mac/A dobeExtensionManager_5_0_2_mul_AdobeUpdate.dmg to download). This patch solved the issue that the signature of third party extensions cannot be validated.
I have this issue on Windows 7. It appears to be the same as posted above.
I have installed Extension manager CS5 from the adobe site. but the app will not open. I see it on the windows bar but cannot video the actual screen. See attached video.
Video here
http://acoustified.com/ExtensionManagerNotWorkingWindows7/ExtensionMan agerNotWorkingWindows7.mp4
Please help. J
Hi Jlev911,
I am not sure what the root cause is for your problem, but you can try the steps below. Hope they can work.
1. Delete extension manager gui preference file in X:\Users\<username>\AppData\Roaming\Adobe\Extension Manager CS5\Configuration\Extensions\exman_uiPreferences.xml, and restart extension manager.
2. From your video I know you have 4 products installed. Have you ever launched extension manager successfully?Did this problem happen after you installed one product? If this problem showed up after you installed a product, try to rename its XManConfig.xml to other file name and restart extension manager.
3. If "X:\Users\<username>\AppData\Roaming\Macromedia\Flash Player\#Security\FlashPlayerTrust" exists, move it to somewhere else and restart extenson manager.
4. From your video I saw FireFox was opened. Try to close it and restart extenson manager. If it does not help, disable its plugins and restart extension manager again( some plugins conflict with extension manager ).
5. Do you have enough permission to launch extension manager? Try to launch it with administrator and make sure you have write access to extension manager folders( I don't have extension manger cs5 installed, but they might locate in your home directory and pubic directory )?
6. If all of them still can not help you, generate extenson manger log files, attach them to the forum and we can check what happened( create ExManLog.YES in the same folder of extension manager exe file ).
Hello. My extension manager will not start either. I have deleted and reinstalled. I have tried to start using the sudo command. Nothing seems to work. Please advise (error log attached). Thank you.
| Process: | Adobe Extension Manager CS5.5 [1774] |
| Path: | /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/MacOS/Adobe Extension Manager CS5.5 |
| Identifier: | com.adobe.ExtensionManager |
| Version: | "5.5.2.20" (5.5.20) |
| Code Type: | X86 (Native) |
Parent Process: launchd [135]
| User ID: | 501 |
| Date/Time: | 2013-02-26 07:50:06.041 -0500 |
| OS Version: | Mac OS X 10.8.2 (12C60) |
Report Version: 10
| Interval Since Last Report: | 687747 sec |
| Crashes Since Last Report: | 17 |
Per-App Interval Since Last Report: 13 sec
Per-App Crashes Since Last Report: 3
| Anonymous UUID: | 6E42F100-0B0C-CBA5-E28E-70FC1D9E5CB8 |
Crashed Thread: 11
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
VM Regions Near 0:
| --> __PAGEZERO | 0000000000000000-0000000000001000 [ | 4K] ---/--- SM=NUL /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/MacOS/Adobe Extension Manager CS5.5 |
| __TEXT | 0000000000001000-0000000000210000 [ 2108K] r-x/rwx SM=COW /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/MacOS/Adobe Extension Manager CS5.5 |
Thread 0:: Dispatch queue: com.apple.main-thread
| 0 com.apple.CoreGraphics | 0x912dcd38 sseCGSBlendXXXX8888Transpose + 520 | |
| 1 com.apple.CoreGraphics | 0x9118ae84 CGSBlendABGR8888toRGBA8888 + 949 | |
| 2 com.apple.CoreGraphics | 0x911635e1 argb32_image + 2504 | |
| 3 libRIP.A.dylib | 0x936fed08 ripd_Mark + 291 | |
| 4 libRIP.A.dylib | 0x936feba3 ripl_BltImage + 1585 | |
| 5 libRIP.A.dylib | 0x936fe30f ripc_RenderImage + 259 | |
| 6 libRIP.A.dylib | 0x936fbeca ripc_DrawImage + 1078 | |
| 7 com.apple.CoreGraphics | 0x9115f435 CGContextDrawImage + 427 | |
| 8 com.apple.HIToolbox | 0x9402c37a HIViewDrawCGImage + 220 | |
| 9 AdobeOwl | 0x0049df95 OWLOSXApplicationContainerCreate + 94901 | |
| 10 AdobeOwl | 0x0049fb2a OWLOSXApplicationContainerCreate + 101962 | |
| 11 AdobeOwl | 0x0039887c OWLThemeChangeInterpolator + 84760 | |
| 12 AdobeOwl | 0x00398d5b OWLThemeChangeInterpolator + 86007 | |
| 13 AdobeOwl | 0x004a04ac OWLOSXApplicationContainerCreate + 104396 | |
| 14 AdobeOwl | 0x003842b1 OWLThemeChangeInterpolator + 1357 | |
| 15 com.apple.HIToolbox | 0x94109b6b _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36 | |
| 16 com.apple.HIToolbox | 0x93f91594 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1343 | |
| 17 com.apple.HIToolbox | 0x93f90980 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430 | |
| 18 com.apple.HIToolbox | 0x93f907ca SendEventToEventTargetWithOptions + 94 | |
| 19 com.apple.HIToolbox | 0x93faad17 HIView::SendDraw(short, OpaqueGrafPtr*, __HIShape const*, CGContext*) + 491 | |
| 20 com.apple.HIToolbox | 0x940379d5 HIView::RecursiveDrawComposited(__HIShape const*, __HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 759 | |
| 21 com.apple.HIToolbox | 0x94037d5c HIView::RecursiveDrawComposited(__HIShape const*, __HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 1662 | |
| 22 com.apple.HIToolbox | 0x94037d5c HIView::RecursiveDrawComposited(__HIShape const*, __HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 1662 | |
| 23 com.apple.HIToolbox | 0x94036df0 HIView::DrawComposited(short, OpaqueGrafPtr*, __HIShape const*, unsigned long, HIView*, CGContext*) + 802 | |
| 24 com.apple.HIToolbox | 0x94036a82 HIView::Draw(short, OpaqueGrafPtr*, unsigned long) + 82 | |
| 25 com.apple.HIToolbox | 0x94036a29 HIView::Render(unsigned long, CGContext*) + 45 | |
| 26 com.apple.HIToolbox | 0x93fb3460 FlushWindowObject(WindowData*, void**, unsigned char) + 812 | |
| 27 com.apple.HIToolbox | 0x93fbbfb1 FlushAllBuffers(__CFRunLoopObserver*, unsigned long, void*) + 245 | |
| 28 com.apple.CoreFoundation | 0x9326adfe __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 30 | |
| 29 com.apple.CoreFoundation | 0x9326ad3d __CFRunLoopDoObservers + 381 | |
| 30 com.apple.CoreFoundation | 0x93244623 CFRunLoopRunSpecific + 355 | |
| 31 com.apple.CoreFoundation | 0x932444ab CFRunLoopRunInMode + 123 | |
| 32 com.apple.HIToolbox | 0x93fb515a RunCurrentEventLoopInMode + 242 | |
| 33 com.apple.HIToolbox | 0x93fb4ec9 ReceiveNextEventCommon + 374 | |
| 34 com.apple.HIToolbox | 0x9411a35d _AcquireNextEvent + 68 | |
| 35 com.apple.HIToolbox | 0x9410911a RunApplicationEventLoop + 225 | |
| 36 com.adobe.ExtensionManager | 0x00005e88 main + 4416 | |
| 37 com.adobe.ExtensionManager | 0x0000232a start + 54 |
Thread 1:
| 0 libsystem_kernel.dylib | 0x978100ee __workq_kernreturn + 10 | |
| 1 libsystem_c.dylib | 0x9572604c _pthread_workq_return + 45 | |
| 2 libsystem_c.dylib | 0x95725e19 _pthread_wqthread + 448 | |
| 3 libsystem_c.dylib | 0x9570dcca start_wqthread + 30 |
Thread 2:: Dispatch queue: com.apple.libdispatch-manager
| 0 libsystem_kernel.dylib | 0x978109ae kevent + 10 | |
| 1 libdispatch.dylib | 0x996c4c71 _dispatch_mgr_invoke + 993 | |
| 2 libdispatch.dylib | 0x996c47a9 _dispatch_mgr_thread + 53 |
Thread 3:
Thread 4:
| 0 libsystem_kernel.dylib | 0x9780d8e6 mach_wait_until + 10 | |
| 1 libsystem_c.dylib | 0x957b4c1c nanosleep + 375 | |
| 2 com.adobe.ExtensionManager | 0x0015182f ScObjects::Thread::sleep(unsigned int) + 143 | |
| 3 com.adobe.ExtensionManager | 0x0015188f ScObjects::Thread::wait(unsigned int) + 23 | |
| 4 com.adobe.ExtensionManager | 0x0014845a ScObjects::BridgeTalkThread::run() + 332 | |
| 5 com.adobe.ExtensionManager | 0x00151d99 ScObjects::Thread::go(void*) + 315 | |
| 6 libsystem_c.dylib | 0x95723557 _pthread_start + 344 | |
| 7 libsystem_c.dylib | 0x9570dcee thread_start + 34 |
Thread 5:
| 0 libsystem_kernel.dylib | 0x9780d7d2 mach_msg_trap + 10 | |
| 1 libsystem_kernel.dylib | 0x9780ccb0 mach_msg + 68 | |
| 2 com.adobe.adobeswfl | 0x062d518f ExternalPlayer_Initialize + 465535 | |
| 3 libsystem_c.dylib | 0x95723557 _pthread_start + 344 | |
| 4 libsystem_c.dylib | 0x9570dcee thread_start + 34 |
Thread 6:
| 0 libsystem_kernel.dylib | 0x9780f8e2 __psynch_cvwait + 10 | |
| 1 libsystem_c.dylib | 0x95728289 _pthread_cond_wait + 938 | |
| 2 libsystem_c.dylib | 0x957b5afc pthread_cond_wait + 48 | |
| 3 com.adobe.adobeswfl | 0x06282f54 ExternalPlayer_Initialize + 129092 | |
| 4 com.adobe.adobeswfl | 0x0605334a 0x6044000 + 62282 | |
| 5 com.adobe.adobeswfl | 0x06282ce7 ExternalPlayer_Initialize + 128471 | |
| 6 com.adobe.adobeswfl | 0x06282d3f ExternalPlayer_Initialize + 128559 | |
| 7 libsystem_c.dylib | 0x95723557 _pthread_start + 344 | |
| 8 libsystem_c.dylib | 0x9570dcee thread_start + 34 |
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11 Crashed:
| 0 com.apple.CoreFoundation | 0x93229d1e CFURLCreateStringWithFileSystemPath + 206 | |
| 1 com.apple.CoreFoundation | 0x93229c25 CFURLCopyFileSystemPath + 53 | |
| 2 com.adobe.ExtensionManager | 0x000d08e5 CMemoryMappedFile::CMemoryMappedFile(FSRef const&, bool) + 97 | |
| 3 com.adobe.ExtensionManager | 0x000d0d2a CMacFileBuffer::CMacFileBuffer(FSRef const&, HFSUniStr255 const&, bool, bool) + 192 | |
| 4 com.adobe.ExtensionManager | 0x000adbc1 CFile::Open(wchar_t const*, unsigned int, bool) + 411 | |
| 5 com.adobe.ExtensionManager | 0x0011dd70 CMacrPluginConfigFile::load(CString const&) + 196 | |
| 6 com.adobe.ExtensionManager | 0x00019062 CMacrExtensionManager::updatePluginFile(CMacrExtension const*, CMacrProduct const*, CMacrExtensionPaths const&, bool) + 126 | |
| 7 com.adobe.ExtensionManager | 0x000298b7 CMacrExtensionManager::migrateFiles(CString const&, CMacrPath const&, CMacrPath const&, CMacrPath const&, CMacrPath const&, CMacrProduct const*, int) + 7253 | |
| 8 com.adobe.ExtensionManager | 0x00029fe3 CMacrExtensionManager::migrateExtensionFromExtensionFile(CString const&, CString const&, CString const&, CMacrProduct const*) + 1377 | |
| 9 com.adobe.ExtensionManager | 0x0002a45c CMacrExtensionManager::migrateExtensionsFromProductPreferredFolder(CM acrProduct const*) + 574 | |
| 10 com.adobe.ExtensionManager | 0x0002a91d CMacrExtensionManager::migrateExtensionsFromProductsPreferredFolders( ) + 163 | |
| 11 com.adobe.ExtensionManager | 0x00119b53 MigratePreferredExtensionCommand::execute() + 19 | |
| 12 com.adobe.ExtensionManager | 0x000dd150 CommandExecutor_Impl::run() + 144 | |
| 13 com.adobe.ExtensionManager | 0x000dd16b CommandExecutor_Impl::runHelper(void*) + 17 | |
| 14 libsystem_c.dylib | 0x95723557 _pthread_start + 344 | |
| 15 libsystem_c.dylib | 0x9570dcee thread_start + 34 |
Thread 11 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x93229c61 ecx: 0x00000000 edx: 0x00000000
edi: 0x00000000 esi: 0xac448840 ebp: 0xb05b0798 esp: 0xb05aef20
ss: 0x00000023 efl: 0x00010246 eip: 0x93229d1e cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000023 gs: 0x0000000f
cr2: 0x00000000
Logical CPU: 2
Binary Images:
| 0x1000 - 0x20ffeb +com.adobe.ExtensionManager ("5.5.2.20" - 5.5.20) <E83C03FC-E291-08C5-9492-CB67B8FC2F19> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/MacOS/Adobe Extension Manager CS5.5 |
0x367000 - 0x36afe7 +libwchar.dylib (1) <DE7B4F71-F31A-46F7-B70D-A8A157B5EB6B> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/libwchar.dylib
0x36e000 - 0x568fef +AdobeOwl (1) <466BD72B-E2A5-447A-9384-B6DC9AD3AE0C> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x5e3000 - 0xae1fc3 +AdobeOwlCanvas (1) <45219076-15E0-4A0D-9BC0-2FFED8EA7E46> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobeOwlCanvas.framework/Versions/A/Ado beOwlCanvas
0xc2a000 - 0xc9afeb +com.adobe.adobe_caps (adobe_caps 3.5.18.0 - 3.5.18.0) <A54D73C5-EBCF-75F1-9BB0-ADBB36042DEC> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/adobe_caps.framework/Versions/a/adobe_c aps
0xca8000 - 0xcacffc +com.adobe.AdobeCrashReporter (3.0 - 5.5.20101001) <EA9B7B55-7FE5-14D2-FBAE-817121F94086> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A /AdobeCrashReporter
0xcb2000 - 0xce7fef +com.adobe.pip (5.5.0.1272) <4AD1ED99-8BB9-B49E-16E5-B7E7A97AAA99> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
0xcf2000 - 0xd48ffb +com.adobe.headlights.LogSessionFramework (2.1.2.1263) <5B594BC9-5222-651B-6B70-7AD067035B1A> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSess ion
0xd8c000 - 0xdc8ff7 com.apple.vmutils (4.2.1 - 108) <6918860D-B24F-356C-9374-025BFFEA66A3> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutil s
0xde2000 - 0xe8dfff libcrypto.0.9.7.dylib (106) <041B3399-5033-3395-9A71-6693F3A33D94> /usr/lib/libcrypto.0.9.7.dylib
0x18c3000 - 0x18d0ff3 com.apple.Librarian (1.1 - 1) <88A55A5E-40FF-3234-8394-2317120B79AB> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Libr arian
0x1f00000 - 0x1f70feb +com.adobe.adobe_caps (adobe_caps 3.5.18.0 - 3.5.18.0) <A54D73C5-EBCF-75F1-9BB0-ADBB36042DEC> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
0x1ff6000 - 0x1ff8ff3 com.apple.LiveType.component (2.1.4 - 2.1.4) <D60E2537-3B47-EA99-0077-6CE394378D07> /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x3403000 - 0x3405ff7 Motion (729) <051B60E9-B39F-EBB2-5B96-F088D147E78C> /Library/Frameworks/Motion.framework/Versions/A/Motion
0x3445000 - 0x3446ffd com.apple.textencoding.unicode (2.5 - 2.5) <4E2ABBEB-1F0D-3C06-BA0C-C3CEDDF17BD2> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x3798000 - 0x37deffb com.apple.motion.component (1.0 - 729) <494487C6-EA30-43DD-39E4-BED23C5A5B1C> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0x6044000 - 0x6847fe2 +com.adobe.adobeswfl (1.0.7) <53D59B93-133D-41B4-AE25-83532E5C0F6C> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobeOwl.framework/Resources/AdobeSWFL. bundle/Contents/MacOS/AdobeSWFL
0x7b18000 - 0x7b26fff libSimplifiedChineseConverter.dylib (61) <60899F9C-A79F-3BC2-855E-DC5C78B98FEB> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
0x7b2d000 - 0x7b91fe2 com.apple.LiveType.framework (2.1.4 - 2.1.4) <C9D29156-2471-2A9D-3657-EF06204229C6> /Library/Application Support/ProApps/*/LiveType.framework/Versions/A/LiveType
0x7bb1000 - 0x7c4eff8 com.apple.procore.framework (4.0.2 - 757) <D3146F1E-F86D-F2A2-509B-E3F9640CBE40> /Library/Application Support/ProApps/*/ProCore.framework/Versions/A/ProCore
0xf326000 - 0xf338ffd libTraditionalChineseConverter.dylib (61) <519CAA3F-715E-3CAE-B158-57EC95D916B1> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
0xf93b000 - 0xfd2dfff +WebKit.dylib (1.0.7) <6FB30C58-17FE-4A4B-971E-CDE89FB7DD1B> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobeOwl.framework/Resources/WebKit.dyl ib
0x111a5000 - 0x11263ff3 ColorSyncDeprecated.dylib (400) <35E3054C-5DF1-30D4-A368-C4FDB0992373> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated .dylib
0x8fea3000 - 0x8fed5e57 dyld (210.2.3) <23DBDBB1-1D21-342C-AC2A-0E55F27E6A1F> /usr/lib/dyld
0x90007000 - 0x9000bffe libcache.dylib (57) <834FDCA7-FE3B-33CC-A12A-E11E202477EC> /usr/lib/system/libcache.dylib
0x9000c000 - 0x900bbff7 com.apple.CoreText (260.0 - 275.16) <873ADCD9-D361-3753-A220-CDD289196AD8> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x900bc000 - 0x900bcfff libkeymgr.dylib (25) <D5E93F7F-9315-3AD6-92C7-941F7B54C490> /usr/lib/system/libkeymgr.dylib
0x900c9000 - 0x900d0fff liblaunch.dylib (442.26.2) <310C99F8-0811-314D-9BB9-D0ED6DFA024B> /usr/lib/system/liblaunch.dylib
0x900d1000 - 0x90115fff libGLU.dylib (8.6.1) <06BAFDCA-800C-35E3-B1A3-F05E105B86AB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
0x90116000 - 0x90164ff3 com.apple.SystemConfiguration (1.12.2 - 1.12.2) <7BA6C58B-0357-356F-BB69-17ACB5E35988> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
0x90165000 - 0x901c9fff com.apple.datadetectorscore (4.0 - 269.1) <3EFFB8D8-CD46-3BB2-9B9F-2F757B9EC998> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
0x901ca000 - 0x901ccfff libCVMSPluginSupport.dylib (8.6.1) <8A174BD9-992E-351D-8F9A-DF6991723ABE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC VMSPluginSupport.dylib
0x901cd000 - 0x90265fff com.apple.CoreServices.OSServices (557.4 - 557.4) <C724AB29-A596-3E1E-9FF1-A4E509AD843A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
0x90266000 - 0x90266fff com.apple.Cocoa (6.7 - 19) <354094F0-F36B-36F9-BF5F-FD60590FBEB9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x90267000 - 0x902c2fff com.apple.htmlrendering (77 - 1.1.4) <5C0C669F-AE07-3983-B38F-EB829B5CE609> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
0x902c3000 - 0x90327ff3 libstdc++.6.dylib (56) <F8FA490A-8F3C-3645-ABF5-78926CE9C62C> /usr/lib/libstdc++.6.dylib
0x906a1000 - 0x906e6ff7 com.apple.NavigationServices (3.7 - 200) <F6531764-6E43-3AF3-ACDD-8A5551EF016A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
0x906e7000 - 0x906f1fff com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <B855E8B4-2EE3-3BFF-8547-98A0F084F9AF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
0x906f2000 - 0x90727fff libTrueTypeScaler.dylib (84.5) <2598F930-5E6B-37D7-B1E6-18181A972C6E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x90959000 - 0x90986ffb com.apple.CoreServicesInternal (154.2 - 154.2) <DCCF604B-1DB8-3F09-8122-545E2E7F466D> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Vers ions/A/CoreServicesInternal
0x90987000 - 0x909d6ff6 libTIFF.dylib (845) <989A2EB9-3A49-3157-8E9C-B16E6005BC64> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib TIFF.dylib
0x909d7000 - 0x909d9fff com.apple.securityhi (4.0 - 55002) <79E3B880-3AB7-3BF3-9CDF-117A45599545> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
0x909da000 - 0x909defff com.apple.CommonPanels (1.2.5 - 94) <6B3E7E53-7708-3DA2-8C50-59C2B4735DE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
0x909df000 - 0x90c5bff7 com.apple.QuickTime (7.7.1 - 2599.13) <FE609160-E1EF-341D-9B6A-205D3E03A4D2> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x90c5c000 - 0x90cd8ffb libType1Scaler.dylib (101.1) <0D94D786-29F7-33DB-B64B-B264FA5EACD2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x90dce000 - 0x90e28fff com.apple.Symbolication (1.3 - 93) <A839CFC2-F870-3652-B353-15A55D88F88D> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/ Symbolication
0x90f8b000 - 0x91103ff5 com.apple.QuartzCore (1.8 - 304.0) <D9E018B8-6E5F-3FFA-A1B2-2B1BC1E03CA2> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x91104000 - 0x91546fff com.apple.CoreGraphics (1.600.0 - 324.6) <66556166-F9A7-3EEC-A562-46061C7A79E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x91547000 - 0x915affe7 libvDSP.dylib (380.6) <55780308-4DCA-3B10-9703-EAFC3E13A3FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
0x9171b000 - 0x9171cfff libdnsinfo.dylib (453.18) <41C7B8E2-2A81-31DE-BD8B-F0C29E169D4F> /usr/lib/system/libdnsinfo.dylib
0x9171d000 - 0x9177afff com.apple.audio.CoreAudio (4.1.0 - 4.1.0) <9549B81F-4425-34EE-802B-F462068DC0C5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x917f5000 - 0x9188ffff com.apple.CoreSymbolication (3.0 - 87) <1A13CC83-4635-3AC6-9A86-E8DCE99562B5> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Version s/A/CoreSymbolication
0x91890000 - 0x918c6ffb com.apple.DebugSymbols (98 - 98) <9A9ADA0A-E487-3C8F-9998-286EE04C235A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/D ebugSymbols
0x918c7000 - 0x91929fff libc++.1.dylib (65.1) <C0CFF9FF-5D52-3EAE-B921-6AE1DA00A135> /usr/lib/libc++.1.dylib
0x921a7000 - 0x9222cff7 com.apple.SearchKit (1.4.0 - 1.4.0) <454E950F-291C-3E95-8F35-05CA0AD6B327> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
0x9222d000 - 0x9233a057 libobjc.A.dylib (532.2) <FA455371-7395-3D58-A89B-D1520612D1BC> /usr/lib/libobjc.A.dylib
0x9233b000 - 0x92349fff com.apple.opengl (1.8.6 - 1.8.6) <1AD1AE7B-B57B-35B5-B571-32A34F0DA737> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9234d000 - 0x92509ffd libicucore.A.dylib (491.11.1) <B19E450A-BAF1-3967-9C95-7F77DC0B4639> /usr/lib/libicucore.A.dylib
0x9250c000 - 0x92529fff libxpc.dylib (140.41) <1BFE3149-C242-3A77-9729-B00DEDC8CCF2> /usr/lib/system/libxpc.dylib
0x9252d000 - 0x9253dff2 com.apple.LangAnalysis (1.7.0 - 1.7.0) <875363E7-6D02-3229-A9DD-E5A5568A7D61> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9256f000 - 0x92812ffb com.apple.CoreImage (8.2.2 - 1.0.1) <85BFFB09-D765-3F5F-AF65-FB136DDCAEF3> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /CoreImage.framework/Versions/A/CoreImage
0x9281a000 - 0x92821fff libsystem_dnssd.dylib (379.32.1) <6A505284-2382-3F27-B96F-15FFDACF004E> /usr/lib/system/libsystem_dnssd.dylib
0x9282e000 - 0x9285aff7 libsystem_info.dylib (406.17) <AA5611DB-A944-3072-B6BE-ACAB08689547> /usr/lib/system/libsystem_info.dylib
0x928a5000 - 0x928a5fff com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <908B8D40-3FB5-3047-B482-3DF95025ECFC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
0x928a6000 - 0x928aefff com.apple.CommerceCore (1.0 - 26) <AF0D1990-8CBF-3AB4-99DF-8B7AE14FB0D5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
0x928af000 - 0x92bccff3 com.apple.Foundation (6.8 - 945.11) <03B242AC-519C-3683-AA52-E73536B3D55F> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92bd3000 - 0x92bd5ffb libRadiance.dylib (845) <3F87840F-217D-3074-A29D-919BAAED2F4A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib Radiance.dylib
0x92bd6000 - 0x92c2dff7 com.apple.ScalableUserInterface (1.0 - 1) <2B5E454B-BC49-3E85-B54D-1950397C448C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x930e9000 - 0x930ecff7 libcompiler_rt.dylib (30) <CE5DBDB4-0124-3E2B-9105-989DF98DD108> /usr/lib/system/libcompiler_rt.dylib
0x930ed000 - 0x930edfff com.apple.ApplicationServices (45 - 45) <677C4ACC-9D12-366F-8A87-B898AC806DD9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
0x930ee000 - 0x930f7ffd com.apple.audio.SoundManager (4.0 - 4.0) <ABC5FE40-B222-36EB-9905-5C8C4BFD8C87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
0x930f8000 - 0x93127ff7 com.apple.securityinterface (6.0 - 55024.4) <7C5E28DC-F8BE-3238-883F-E1646A2AF895> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/Sec urityInterface
0x93128000 - 0x93147ff3 com.apple.Ubiquity (1.2 - 243.10) <D2C9F356-1681-31D2-B292-5227E2DDEB0B> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiqu ity
0x93190000 - 0x9320cff3 com.apple.Metadata (10.7.0 - 707.3) <6B6A6216-23D0-34CE-8099-BEE9BA42501E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
0x9320d000 - 0x933f5ff3 com.apple.CoreFoundation (6.8 - 744.12) <E939CEA0-493C-3233-9983-5070981BB350> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
0x933f6000 - 0x933f9ffc libpam.2.dylib (20) <FCF74195-A99E-3B07-8E49-688D4A6F1E18> /usr/lib/libpam.2.dylib
0x933fa000 - 0x934f2ff9 libsqlite3.dylib (138.1) <AD7C5914-35F0-37A3-9238-A29D2E26C755> /usr/lib/libsqlite3.dylib
0x934f5000 - 0x934fdfff libcopyfile.dylib (89) <4963541B-0254-371B-B29A-B6806888949B> /usr/lib/system/libcopyfile.dylib
0x93501000 - 0x93576ff7 com.apple.ApplicationServices.ATS (332 - 341.1) <95206704-F9C9-33C4-AF25-FE9890E160B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
0x935a6000 - 0x935b0fff libCSync.A.dylib (324.6) <D2E8AC70-C6D1-3C40-8A82-E50422EDCFBF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x935c0000 - 0x935ccff8 libbz2.1.0.dylib (29) <7031A4C0-784A-3EAA-93DF-EA1F26CC9264> /usr/lib/libbz2.1.0.dylib
0x9366a000 - 0x9366dff9 libCGXType.A.dylib (324.6) <3004616B-51F6-3B9D-8B85-DCCA3DF9BC10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
0x936ee000 - 0x93717ff7 libRIP.A.dylib (324.6) <7976E6A2-A489-33F5-A727-7634DDE3B761> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x93aac000 - 0x93aacfff com.apple.vecLib (3.8 - vecLib 3.8) <83160DD1-5614-3E34-80EB-97041016EF1F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x93aed000 - 0x93af4ffe com.apple.agl (3.2.1 - AGL-3.2.1) <D0A9B878-7F1F-3210-B6AF-91D2DBEFF21B> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x93af5000 - 0x93eadffa libLAPACK.dylib (1073.4) <9A6E5EAD-F2F2-3D5C-B655-2B536DB477F2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
0x93eae000 - 0x93ebcff3 libsystem_network.dylib (77.10) <7FBF5A15-97BA-3721-943E-E77F0C40DBE1> /usr/lib/system/libsystem_network.dylib
0x93ebd000 - 0x93ebdfff com.apple.Accelerate (1.8 - Accelerate 1.8) <4EC0548E-3A3F-310D-A366-47B51D5B6398> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x93ebe000 - 0x93ee3ffb com.apple.framework.familycontrols (4.1 - 410) <5A8504E7-D95D-3101-8E20-38EADE8DEAE1> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
0x93f3e000 - 0x93f5cff3 com.apple.openscripting (1.3.6 - 148.2) <55738D66-CC15-3F43-9265-00C3322D39C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
0x93f5d000 - 0x94340ff3 com.apple.HIToolbox (2.0 - 625) <5A312E41-9940-363E-B891-90C4672E6850> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
0x94341000 - 0x9435afff com.apple.Kerberos (2.0 - 1) <9BDE8F4D-DBC3-34D1-852C-898D3655A611> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x9435b000 - 0x9442ffff com.apple.backup.framework (1.4.1 - 1.4.1) <55F2A679-9B21-3F43-A580-4C2ECF6A5FC5> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x94430000 - 0x94431fff libsystem_sandbox.dylib (220) <4E42390B-25EC-3530-AF01-337E430C16EB> /usr/lib/system/libsystem_sandbox.dylib
0x94432000 - 0x9457fffb com.apple.CFNetwork (596.2.3 - 596.2.3) <1221EF86-659B-3136-AB57-0CC6B130CDA2> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x94581000 - 0x945a5fff libJPEG.dylib (845) <547FA9A5-0BBB-3E39-BACA-F3E2DAE57DB0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib JPEG.dylib
0x94644000 - 0x9485bfff com.apple.CoreData (106.1 - 407.7) <17FD06D6-AD7C-345A-8FA4-1F0FBFF4DAE1> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x94975000 - 0x95531ffb com.apple.AppKit (6.8 - 1187.34) <06EDB1D1-3B8A-3699-8E3A-D8F50A27AB7C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x95532000 - 0x955e6fff com.apple.coreui (2.0 - 181.1) <C15ABF35-B7F5-34ED-A461-386DAF65D96B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x955e7000 - 0x955e8fff libDiagnosticMessagesClient.dylib (8) <39B3D25A-148A-3936-B800-0D393A00E64F> /usr/lib/libDiagnosticMessagesClient.dylib
0x9570d000 - 0x957cafeb libsystem_c.dylib (825.25) <B1F6916A-F558-38B5-A18C-D9733625FDC9> /usr/lib/system/libsystem_c.dylib
0x957d1000 - 0x9580cfe7 libGLImage.dylib (8.6.1) <A3442557-18D5-332E-8859-423D5A20EBBE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
0x95939000 - 0x959a1ff7 com.apple.framework.IOKit (2.0 - 755.18.10) <9A80E97E-544F-3A45-916D-6DB7ED217E33> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x959a2000 - 0x959f0ffb libFontRegistry.dylib (100) <3B8350C2-4D8F-38C4-A22E-2F855D7E83D1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x959f1000 - 0x95a91ff7 com.apple.QD (3.42 - 285) <1B8307C6-AFA8-312E-BA5B-679070EF2CA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
0x95a92000 - 0x95abbfff libxslt.1.dylib (11.3) <0DE17DAA-66FF-3195-AADB-347BEB5E2EFA> /usr/lib/libxslt.1.dylib
0x95abc000 - 0x95ad9fff libCRFSuite.dylib (33) <C9D72D0C-871A-39A2-8AFB-682D11AE7D0D> /usr/lib/libCRFSuite.dylib
0x95ada000 - 0x95be7ff3 com.apple.ImageIO.framework (3.2.0 - 845) <BF959BCB-C30A-3680-B7C2-91B327B2B63B> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x95d38000 - 0x95d5afff libc++abi.dylib (24.4) <06479DA4-BC23-34B6-BAFC-A885814261D0> /usr/lib/libc++abi.dylib
0x95fe8000 - 0x95ffbff9 com.apple.MultitouchSupport.framework (235.28 - 235.28) <5C8CFA21-D4FC-32E8-B199-0F7155E6ED9A> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
0x9603b000 - 0x96042ffb libunwind.dylib (35.1) <E1E8D8B3-3C78-3AB1-B398-C180DC6DCF05> /usr/lib/system/libunwind.dylib
0x96043000 - 0x960edfff com.apple.LaunchServices (539.7 - 539.7) <AF33EBD3-BC0B-30B5-B7DA-5CCCF12D7EDD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
0x96e27000 - 0x96e28ffd libunc.dylib (25) <58599CBF-E262-3CEA-AFE1-35560E0177DC> /usr/lib/system/libunc.dylib
0x96e55000 - 0x96ea1fff libcorecrypto.dylib (106.2) <20EBADBA-D6D6-36F0-AE80-168E9AF13DB6> /usr/lib/system/libcorecrypto.dylib
0x96ee3000 - 0x96f75ffb libvMisc.dylib (380.6) <6DA3A03F-20BE-300D-A664-B50A7B4E4B1A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
0x96f76000 - 0x96f78fff libdyld.dylib (210.2.3) <05D6FF2A-F09B-309D-95F7-7AF10259C707> /usr/lib/system/libdyld.dylib
0x96f79000 - 0x96f7cfff com.apple.help (1.3.2 - 42) <AD7EB1F0-A068-3A2C-9D59-38E59CEC0D96> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
0x96f82000 - 0x96f8effe libkxld.dylib (2050.18.24) <48A75AF6-9D5A-3552-948E-30A1682D3664> /usr/lib/system/libkxld.dylib
0x96f90000 - 0x96f90fff com.apple.CoreServices (57 - 57) <956C6C6D-A5DD-314F-9C57-4A61D41F30CE> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
0x9761e000 - 0x97698ff3 com.apple.securityfoundation (6.0 - 55115.4) <8A3DA1FE-1985-3ECB-945A-6B1E853B4BDC> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
0x97699000 - 0x977f1ffb com.apple.audio.toolbox.AudioToolbox (1.8 - 1.8) <9205DFC2-8DAE-354E-AD87-46E229B5F2F1> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
0x977f2000 - 0x977fafff com.apple.DiskArbitration (2.5.1 - 2.5.1) <25A7232F-9B6A-3746-A3A8-12479D086B1E> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
0x977fb000 - 0x97815ffc libsystem_kernel.dylib (2050.18.24) <C17D49D0-7961-3B67-B443-C788C6E5AA76> /usr/lib/system/libsystem_kernel.dylib
0x97816000 - 0x978d4ff3 com.apple.ColorSync (4.8.0 - 4.8.0) <EFEDCB37-4F20-3CEC-A185-5D2976E11BAC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
0x978d5000 - 0x97a10ff7 libBLAS.dylib (1073.4) <FF74A147-05E1-37C4-BC10-7DEB57FE5326> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
0x97a69000 - 0x97b5affc libiconv.2.dylib (34) <B096A9B7-83A6-31B3-8D2F-87D91910BF4C> /usr/lib/libiconv.2.dylib
0x97b5b000 - 0x97b64ff9 com.apple.CommonAuth (3.0 - 2.0) <A1A6CC3D-AA88-3519-A305-9B5D76C5D63B> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/Com monAuth
0x97b65000 - 0x97b66fff libquarantine.dylib (52) <D526310F-DC77-37EA-8F5F-83928EFA3262> /usr/lib/system/libquarantine.dylib
0x97b67000 - 0x97b87ffd com.apple.ChunkingLibrary (2.0 - 133.2) <FE5F0F1E-B15D-3F76-8655-DC2FE19BF56E> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/ A/ChunkingLibrary
0x97c99000 - 0x97ca0ff3 com.apple.NetFS (5.0 - 4.0) <1F7041F2-4E97-368C-8F5D-24153D81BBDB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x97ca3000 - 0x97cc7fff com.apple.PerformanceAnalysis (1.16 - 16) <18DE0F9F-1264-394D-AC56-6B2A1771DFBE> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versi ons/A/PerformanceAnalysis
0x97ddc000 - 0x97de6ffe com.apple.bsd.ServiceManagement (2.0 - 2.0) <9732BA61-D6F6-3644-82DA-FF0D6FEEFC69> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/Ser viceManagement
0x97de7000 - 0x97df3ff7 com.apple.NetAuth (4.0 - 4.0) <4983C4B8-9D95-3C4D-897E-07743326487E> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAut h
0x97df4000 - 0x97e09fff com.apple.ImageCapture (8.0 - 8.0) <B8BD421F-D5A9-3FB4-8E89-AD5CFC0D4030> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
0x97e0a000 - 0x97e3dff3 com.apple.GSS (3.0 - 2.0) <B1D719C1-B000-3BE3-B747-329D608585DD> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x97e3e000 - 0x97e3efff com.apple.Carbon (154 - 155) <C0A26E7B-28F1-3C7E-879E-A3CF3ED5111C> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x980d9000 - 0x980ddff7 libmacho.dylib (829) <5280A013-4F74-3F74-BE0C-7F612C49F1DC> /usr/lib/system/libmacho.dylib
0x98114000 - 0x9821fff7 libJP2.dylib (845) <D409C913-6FA4-3D60-BFE0-B9FC6A02FEE0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib JP2.dylib
0x98220000 - 0x98251fff com.apple.DictionaryServices (1.2 - 184.4) <0D5BE86F-F40A-3E39-8569-19FCA5EDF9D3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
0x98252000 - 0x982b8fff com.apple.print.framework.PrintCore (8.1 - 387.1) <F8CF762B-B707-3021-958F-BB8D33DB3576> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
0x982b9000 - 0x982baffd com.apple.TrustEvaluationAgent (2.0 - 23) <E42347C0-2D3C-36A4-9200-757FFA61B388> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
0x982bb000 - 0x982c8ff7 com.apple.AppleFSCompression (49 - 1.0) <166AA1F8-E50A-3533-A3B5-8737C5118CC3> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versio ns/A/AppleFSCompression
0x982c9000 - 0x982cdffc libGIF.dylib (845) <714E9F0D-D7A3-3F58-B46E-FCBE0F144B23> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib GIF.dylib
0x982ce000 - 0x982dcff7 libz.1.dylib (43) <245F1B61-2276-3BBB-9891-99934116D833> /usr/lib/libz.1.dylib
0x982dd000 - 0x9831cff7 com.apple.bom (12.0 - 192) <0637E52C-D151-37B3-904F-8656B2FD44DD> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x98327000 - 0x985e7fff com.apple.security (7.0 - 55179.1) <CB470E48-621B-34D9-9E78-8B773358CB6B> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x985e8000 - 0x9860dff7 com.apple.CoreVideo (1.8 - 99.3) <5B872AC0-E82D-3475-A3F9-FD95F380560D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x9860e000 - 0x98653ff5 com.apple.opencl (2.1.20 - 2.1.20) <41C4AE6E-67B6-33E2-A9B6-BF6F01580B16> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x986ab000 - 0x9871affb com.apple.Heimdal (3.0 - 2.0) <1ABF438B-30E6-3165-968C-E2EA1A9DF1FD> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimda l
0x9871b000 - 0x988a4ff7 com.apple.vImage (6.0 - 6.0) <1D1F67FE-4F75-3689-BEF6-4A46C8039E70> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
0x988a5000 - 0x9893cff7 com.apple.ink.framework (10.8.2 - 150) <D90FF7BC-6B90-39F1-AC52-670269947C58> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
0x9893d000 - 0x98940ffd libCoreVMClient.dylib (24.4) <C54E8FD0-61EC-3DC8-8631-54288AC66AC8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
0x98941000 - 0x98941ffd libOpenScriptingUtil.dylib (148.2) <907E25B1-4F50-3461-B8D5-733C687EB534> /usr/lib/libOpenScriptingUtil.dylib
0x9895a000 - 0x98d77fff FaceCoreLight (2.4.1) <571DE3F8-CA8A-3E71-9AF4-F06FFE721CE6> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/ FaceCoreLight
0x98d78000 - 0x98d78fff libSystem.B.dylib (169.3) <F479E729-89C7-3B4C-9731-678EB673A861> /usr/lib/libSystem.B.dylib
0x98d79000 - 0x98d95ff7 libPng.dylib (845) <14C43094-C670-3575-BF9B-3A967E05EAC0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib Png.dylib
0x98d96000 - 0x98da1fff libcommonCrypto.dylib (60026) <A6C6EDB8-7E69-3827-81F3-9A74D0935461> /usr/lib/system/libcommonCrypto.dylib
0x98da2000 - 0x98dfbfff com.apple.AE (645.3 - 645.3) <6745659F-006D-3F25-94D6-DF944E9A01FD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
0x98dfc000 - 0x98e08ffa com.apple.CrashReporterSupport (10.8.2 - 415) <BAE9900A-51E7-3AD4-A7FB-7E6CCFFB2F21> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Vers ions/A/CrashReporterSupport
0x98e09000 - 0x98e13fff libsystem_notify.dylib (98.5) <7EEE9475-18F8-3099-B0ED-23A3E528ABE0> /usr/lib/system/libsystem_notify.dylib
0x98e14000 - 0x98e29fff com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) <DE68CEB5-4959-3652-83B8-D2B00D3B932D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x98e2a000 - 0x98e30fff libGFXShared.dylib (8.6.1) <E32A7266-FCDD-352C-9C2A-8939265974AF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
0x98e75000 - 0x98e87fff libbsm.0.dylib (32) <DADD385E-FE53-3458-94FB-E316A6345108> /usr/lib/libbsm.0.dylib
0x98eb3000 - 0x98eb4fff liblangid.dylib (116) <E13CC8C5-5034-320A-A210-41A2BDE4F846> /usr/lib/liblangid.dylib
0x98eb5000 - 0x98f9eff7 libxml2.2.dylib (22.3) <015A4FA6-5BB9-3F95-AFB8-B9281E22685B> /usr/lib/libxml2.2.dylib
0x98f9f000 - 0x98fadfff libxar.1.dylib (105) <343E4A3B-1D04-34A3-94C2-8C7C9A8F736B> /usr/lib/libxar.1.dylib
0x98fae000 - 0x992b3ff7 com.apple.CoreServices.CarbonCore (1037.3 - 1037.3) <4571EDDC-704A-3FB1-B9A6-59870AA6165F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
0x992b4000 - 0x992bafff com.apple.print.framework.Print (8.0 - 258) <12AEAD24-6924-3923-9E4A-C5D21231E639> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
0x995a7000 - 0x995a8fff libremovefile.dylib (23.1) <98622D14-DAAB-3AD8-A5D9-C322BF572A98> /usr/lib/system/libremovefile.dylib
0x995a9000 - 0x995bffff com.apple.CFOpenDirectory (10.8 - 151.10) <3640B988-F915-3E0D-897C-CB04C95BA601> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x995c0000 - 0x996beff7 libFontParser.dylib (84.5) <B3006327-7B2D-3966-A56A-BD85F1D71641> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x996bf000 - 0x996bffff libsystem_blocks.dylib (59) <3A743C5D-CFA5-37D8-80A8-B6795A9DB04F> /usr/lib/system/libsystem_blocks.dylib
0x996c0000 - 0x996d2ff7 libdispatch.dylib (228.23) <86EF7D45-2D97-3465-A449-95038AE5DABA> /usr/lib/system/libdispatch.dylib
0x996d3000 - 0x996d6ff7 com.apple.TCC (1.0 - 1) <437D76CD-6437-3B55-BE2C-A53508858256> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x996d7000 - 0x997f3ff7 com.apple.desktopservices (1.7.2 - 1.7.2) <8E74D101-8398-34F1-A463-B4950680A597> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
0x997fe000 - 0x99802fff com.apple.IOSurface (86.0.3 - 86.0.3) <E3A4DB0A-1C1A-31E3-A550-5C0E1C874509> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x99803000 - 0x99820ff7 libresolv.9.dylib (51) <B9742A2A-DF15-3F6E-8FCE-778A58214B3A> /usr/lib/libresolv.9.dylib
0x99821000 - 0x99838fff com.apple.GenerationalStorage (1.1 - 132.2) <93694E0D-35D3-3633-976E-F354CBD92F54> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versi ons/A/GenerationalStorage
0x99895000 - 0x998d7ff7 libauto.dylib (185.1) <B2B5B639-6778-352A-828D-FD8B64A3E8B3> /usr/lib/libauto.dylib
0x998d8000 - 0x9991affb com.apple.RemoteViewServices (2.0 - 80.5) <60E04F2F-AFD8-3B1F-BF07-8A3A7EABB8E9> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versio ns/A/RemoteViewServices
0x99982000 - 0x9998ffff libGL.dylib (8.6.1) <C7A3917A-C444-33CC-8599-BB9CD8C12BC4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
0x99990000 - 0x999d1ff7 libcups.2.dylib (327) <F46F8703-FEAE-3442-87CB-45C8BF98BEE5> /usr/lib/libcups.2.dylib
0x9a377000 - 0x9a37bfff com.apple.OpenDirectory (10.8 - 151.10) <A1858D81-086F-3BF5-87E3-9B70409FFDF6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
0x9a3bf000 - 0x9a3ecffe libsystem_m.dylib (3022.6) <9975D9C3-3B71-38E3-AA21-C5C5F9D9C431> /usr/lib/system/libsystem_m.dylib
0x9a3ed000 - 0x9a444ff3 com.apple.HIServices (1.20 - 417) <561A770B-8523-3D09-A763-11F872779A4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
0x9a69e000 - 0x9a69effd com.apple.audio.units.AudioUnit (1.8 - 1.8) <4C13DEA2-1EB0-3D06-901A-DB93184C06F0> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0xb0000000 - 0xb0011ff8 +com.adobe.ahclientframework (1.6.0.20 - 1.6.0.20) <6FB288F2-45FD-E54A-C9A4-A0D0C374FE37> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0xba900000 - 0xba91cffd libJapaneseConverter.dylib (61) <A3F2F55D-E491-3532-A8F6-8D3F2455704F> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab21ffc libKoreanConverter.dylib (61) <39F6BEE7-AE54-3423-B920-2A3573BC9A1A> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
External Modification Summary:
Calls made by other processes targeting this process:
| task_for_pid: 2 | |
| thread_create: 0 | |
| thread_set_state: 0 |
Calls made by this process:
| task_for_pid: 0 | |
Calls made by all processes on this machine:
| task_for_pid: 4869 | |
VM Region Summary:
ReadOnly portion of Libraries: Total=147.0M resident=112.1M(76%) swapped_out_or_unallocated=34.9M(24%)
Writable regions: Total=138.1M written=28.7M(21%) resident=35.2M(25%) swapped_out=0K(0%) unallocated=102.9M(75%)
| REGION TYPE | VIRTUAL |
| ATS (font support) | 33.1M |
| CG backing stores | 3232K |
| CG shared images | 1216K |
| CoreServices | 2352K |
| MALLOC | 48.6M |
| MALLOC guard page | 48K |
| Memory tag=240 | 4K |
| Memory tag=242 | 12K |
| Memory tag=249 | 192K |
| Memory tag=35 | 7080K |
| Stack | 69.6M |
| VM_ALLOCATE | 116.5M |
| __DATA | 9792K |
| __DATA/__OBJC | 256K |
| __IMAGE | 528K |
| __IMPORT | 100K |
| __LINKEDIT | 34.4M |
| __OBJC | 1704K |
| __OBJC/__DATA | 248K |
| __PAGEZERO | 4K |
| __TEXT | 112.6M |
| __UNICODE | 544K |
| mapped file | 121.5M |
| shared memory | 308K |
| TOTAL | 563.1M |
Model: iMac12,1, BootROM IM121.0047.B1F, 4 processors, Intel Core i5, 2.5 GHz, 8 GB, SMC 1.71f22
Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 512 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333531533642465238432D48392020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333531533642465238432D48392020
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x9A), Atheros 9380: 4.0.70.23-P2P
Bluetooth: Version 4.0.9f33 10885, 2 service, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: WDC WD5000AAKS-402AA0, 500.11 GB
Serial ATA Device: OPTIARC DVD RW AD-5690H
USB Device: hub_device, 0x0424 (SMSC), 0x2514, 0xfd100000 / 2
USB Device: eUSB ORCA Quad Reader, 0x04e6 (Shuttle Technology), 0x0325, 0xfd130000 / 5
USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0xfd110000 / 4
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd120000 / 3
USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x850b, 0xfa200000 / 3
USB Device: hub_device, 0x0424 (SMSC), 0x2514, 0xfa100000 / 2
USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfa120000 / 5
USB Device: Apple Optical USB Mouse, apple_vendor_id, 0x0304, 0xfa123000 / 10
USB Device: Apple Keyboard, apple_vendor_id, 0x0220, 0xfa122000 / 9
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 4
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0xfa111000 / 7
FireWire Device: OEM ATA Device 00, G-TECH, 800mbit_speed
You have to apply Extension Manager 5.5.3 update. Apple made some API changes in Lion which causes Extension Manager CS5/5.5 crash. We released Extension Manager 5.0.3 and 5.5.3 update last April to solve this issue. You can apply this update via Adobe Application Manager or download and install http://download.macromedia.com/pub/dw_exchange/extension_manager/mac/A dobeExtensionManager_5_5_3_mul_AdobeUpdate.dmg (which can be found at http://www.adobe.com/downloads/updates/).
You said you have tried everything. If you have installed 5.0.3 update, deleted files in "/Users/<UserName>/Library/Preferences/Macromedia/Flash Player/#Security/FlashPlayerTrust" and "/Library/Application Support/Macromedia/FlashPlayerTrust", deleted "/Users/<UserName>/Library/Preferences/Adobe/Extension Manager CS5/exman_uiPreferences.xml", launched Extension Manager with sudo command, please generate log files and send them to exman.beijing@gmail.com.
I am sorry if I appear ignorant, but I have no /Library/ file under my /Users/<user name>. Only under /Users/Shared/ which does not have a Preference file. The only other Library file I have is straight under the Macintosh HD. I can not find a file called FlashPlayerTrust or exman_uiPreferences.xml. Launching via sudo cammand still gives me no window in Extension Manager. How do I generate a log file to send you?
The folder ""/Users/<UserName>/Library/" is hidden since Mac OS X 10.7. You have two ways to go to this folder in Finder.
1. Click menu "Go"->"Go to Folder...", input "/Users/<UserName>/Library/" (exclude quotation mark) then click "Go".
2. Press "option" key down, click menu "Go" then click "Library" in the dropdown menu.
To generate log files, please refer to http://forums.adobe.com/message/4275082#4275082. You have to replace all "6" in the instruction with "5".
1. Open Finder.
2. Navigate to "Applications/Utilities".
3. Double click "Terminal.app" to launch it.
4. In the Terminal window, input the following command (including double quotation mark) then press "return" key.
cd "/Applications/Adobe Extension Manager CS5/Adobe Extension Manager CS5.app/Contents/MacOS"
5. Input the following command then press "return" key.
sudo touch ExManLog.YES
6. When being prompted, input the password of administrator user then press "return" key. A file named "ExManLog.YES" should have been created in this folder.
7. Launch Extension Manager.
8. Wait a while then quit Extension Manager.
9. Send log files (ExtensionManager.log, log0.log, ...) in "/Users/<UserName>/Library/Application Support/Adobe/Extension Manager CS5/" to exman.beijing@gmail.com .
The logs are really strange. I suspect the update was not complete so the swf file didn't match with main executable file. Currently you can delete the EM CS5 installation folder ("/Applications/Adobe Extension Manager CS5/") directly, then download and install EM CS5 GM build (http://download.macromedia.com/pub/dw_exchange/extension_manager/mac/A dobeExtensionManager5All.dmg) and EM 5.0.3 patch (http://download.macromedia.com/pub/dw_exchange/extension_manager/mac/A dobeExtensionManager_5_0_3_mul_AdobeUpdate.dmg) in turn.
