mamzellleju
Extension Manager CS5 does'nt work
Jan 7, 2011 2:53 PM
I installed CS5 on my new mac and I tried to open Extension Manager but it doesn't work. I have a open icon in my taskbar but  I see nothing.
When I tried to close the program, it did a error message :"Extension Manager a quitté de manière imprévue".
Someone have a issue ? I need it for AIR 2.5 ..
    Jan 12, 2011 12:57 AM   in reply to mamzellleju
    Do you login as administrator? Does your account have write privilege to “/Users/<YourUserName>/Library/Application Support/Adobe/Extension Manager CS5”?
    If the answer is yes, you can create a file named “ExManLog.YES” (The content of file doesn't matter, only the file name need be accurate, please uncheck "Hide extension" option in info window to make sure this file name really ends with .YES.) in "/Applications/Adobe Extension Manager CS5/Adobe Extension Manager CS5.app/Contents/MacOS", then startup Extension Manager. you will get two log files in “/Users/<YourUserName>/Library/Application Support/Adobe/Extension Manager CS5”. Could you please upload these log files as attachment so others can give you some help? Thanks.
    Jan 12, 2011 11:15 PM   in reply to mamzellleju
    You can also switch to other space to know whether Extension Manager window is displayed in other space if you enabled spaces in System Preferences. If Extension Manager window is not located in current space, Clicking icon on dock will not switch to that space.
    Jan 24, 2011 1:11 PM   in reply to mamzellleju
    Like you, my Exten Mgr does not work, but I go all the way to a Problem Report after a 'quit unexpectedly'. I've tried it in a new 'test user' and it DOES run in that environment, while at the same bringing up a number of notices, which mean little to me, about other CS5 applications with which I'm having problems.
    Fully 50% of this expensive Design Premium upgrade will not run properly, after all these years with the full range of CS offering, and long before with PageMaker, Distiller, and the rest.
    Very frustrating and makes me feel so dumb.
    Feb 7, 2011 3:14 AM   in reply to mamzellleju
    I have the exact same problem on my MacBook Pro / CS 5.  After updating all my CS5 apps, I opened Dreamweaver and was given the message about the Extension Manager opening . . . but it never really got up and running.  It started and then froze.  When I quit, I was given the message that it crashed.  I logged out and logged in to other users on my laptop and all was fine.  The extension manager loads everything.  It just doesn't work for me, the administrator.  So it appears there is a permissions issue with a folder / file / preference.  Any suggestions?
    Mar 3, 2011 1:06 PM   in reply to mamzellleju
    I have the same problem.
    Did you solve it?
    Mar 3, 2011 5:54 PM   in reply to M H2ag
    Nope, no solutions so far. I live without it.
    Greg Heuer, CSI
    http://www.linkedin.com/in/gheuer
    When you think of the long and gloomy history of man, you will find more hideous crimes have been committed in the name of obedience than have ever been committed in the name of rebellion.
      - C. P. Snow
    Mar 14, 2011 4:51 AM   in reply to GAH212
    I think it should be a permission issue. To help troubleshooting, please save the following commands as a script file, and run it from terminal, e.g. "bin/sh <YourFileName>". A plain text file named "output.txt" will be generated in your home directory. Please upload output.txt so we can get more information about your system.
    In addition, there are some locale-dependent directories in these commands. If your locale is not American English (en_US), please replace "en_US" with your locale.
    cd ~
    ls -ld "./Library/Application Support/Adobe" > output.txt
    ls -ld "./Library/Application Support/Adobe/Bridge CS5" >> output.txt
    ls -ld "./Library/Application Support/Adobe/Bridge CS5/Configuration" >> output.txt
    ls -ld "./Library/Application Support/Adobe/Bridge CS5/Configuration/Extensions" >> output.txt
    ls -ld "./Library/Application Support/Adobe/Extension Manager CS5" >> output.txt
    ls -ld "./Library/Application Support/Adobe/Extension Manager CS5/Configuration" >> output.txt
    ls -ld "./Library/Application Support/Adobe/Extension Manager CS5/Configuration/Extensions" >> output.txt
    ls -ld "./Library/Application Support/Adobe/Dreamweaver CS5" >> output.txt
    ls -ld "./Library/Application Support/Adobe/Dreamweaver CS5/en_US" >> output.txt
    ls -ld "./Library/Application Support/Adobe/Dreamweaver CS5/en_US/Configuration" >> output.txt
    ls -ld "./Library/Application Support/Adobe/Dreamweaver CS5/en_US/Configuration/Extensions" >> output.txt
    ls -ld "./Library/Application Support/Adobe/Adobe InDesign CS5" >> output.txt
    ls -ld "./Library/Application Support/Adobe/Adobe InDesign CS5/Configuration" >> output.txt
    ls -ld "./Library/Application Support/Adobe/Adobe InDesign CS5/Configuration/Extensions" >> output.txt
    ls -ld "./Library/Application Support/Adobe/Flash CS5" >> output.txt
    ls -ld "./Library/Application Support/Adobe/Flash CS5/en_US" >> output.txt
    ls -ld "./Library/Application Support/Adobe/Flash CS5/en_US/Configuration" >> output.txt
    ls -ld "./Library/Application Support/Adobe/Flash CS5/en_US/Configuration/Extensions" >> output.txt
    ls -ld "/Applications/Adobe Illustrator CS5" >> output.txt
    ls -ld "/Applications/Adobe Illustrator CS5/Configuration" >> output.txt
    ls -ld "/Applications/Adobe Illustrator CS5/Configuration/Extensions" >> output.txt
    ls -ld "/Applications/Adobe Photoshop CS5" >> output.txt
    ls -ld "/Users/Shared/Library/Application Support/Adobe/Dreamweaver CS5" >> output.txt
    ls -ld "/Users/Shared/Library/Application Support/Adobe/Dreamweaver CS5/en_US" >> output.txt
    ls -ld "/Users/Shared/Library/Application Support/Adobe/Dreamweaver CS5/en_US/Configuration" >> output.txt
    ls -ld "/Users/Shared/Library/Application Support/Adobe/Dreamweaver CS5/en_US/Configuration/Extensions" >> output.txt
    ls -ld "/Library/Application Support/Adobe" >> output.txt
    ls -ld "/Library/Application Support/Adobe/Extension Manager CS5" >> output.txt
    ls -ld "/Library/Application Support/Adobe/Extension Manager CS5/Illustrator CS5" >> output.txt
    ls -ld "/Library/Application Support/Adobe/InDesign" >> output.txt
    ls -ld "/Library/Application Support/Adobe/InDesign/Version 7.0" >> output.txt
    ls -ld "/Library/Application Support/Adobe/InDesign/Version 7.0/EmStorePath" >> output.txt
    ls -ld "/Library/Application Support/Adobe/InDesign/Version 7.0/en_US" >> output.txt
    ls -ld "/Library/Application Support/Adobe/InDesign/Version 7.0/en_US/Extensions" >> output.txt
    ls -ld "/Library/Application Support/Adobe/Extension Manager" >> output.txt
    ls -ld "/Library/Application Support/Adobe/Extension Manager CS5/FlashCS5" >> output.txt
    ls -ld "/Library/Application Support/Adobe/Fireworks CS5" >> output.txt
    ls -ld "/Library/Application Support/Adobe/Fireworks CS5/EmStorePath" >> output.txt
    ls -ld "/Library/Application Support/Adobe/Fireworks CS5/Extensions" >> output.txt
    ls -ld "/Library/Application Support/Adobe/Fireworks CS5/PreInstall" >> output.txt
    Jun 27, 2011 9:43 AM   in reply to mamzellleju
    I am having the same issue.  The user is an admin.  Brand new install of OS & CS5 Design Premium.  Do not have this issue on any of the 250 machines that this build is out there on.  Extension Manager starts and no window comes up.  No, spaces is not on.  Log in as another user.  Extension Manager starts.  Go into Library/Application Support/Adobe....there isn't an Extension Manager folder.
    Thoughts?
    Jul 5, 2011 3:44 AM   in reply to Bodester22
    Have you tried to run Extension Manager using sudo command? That the user is admin doesn't means that every application you start up will be run with administrative privilege. If with sudo command you can launch Extension Manager successfully, subsequent launch will not need sudo. If it still doesn't work, could you please generate log files and upload them as attachment according to the first reply in this thread?
    Jul 5, 2011 5:09 AM   in reply to Carl Sun
    Can you please explain how to use the sudo command to fix this problem.
    Thanks.
    Jul 6, 2011 3:19 AM   in reply to onlinesteve
    1. Open Terminal window.
    2. Input the following command and press enter.
    sudo "/Applications/Adobe Extension Manager CS5/Adobe Extension Manager CS5.app/Contents/MacOS/Adobe Extension Manager CS5"
    3. When requested, input your root password.
    Aug 4, 2011 11:16 PM   in reply to mamzellleju
    Carl..if you were here, I'd kiss you!!
    After spending last hour searching for a solution, yours worked!  I did have to adjust for CS5.5 ...that's where I was having the issue, but after I changed that and pasted into terminal, I FINALLY got extension manager working.
    Thanks!!!!
    Aug 9, 2011 10:18 AM   in reply to Carl Sun
    Hi Carl,
    This works, but the moment I quit Terminal and try to run it as usual ( as a app ), it stops working again.
    What do you think can be causing this problem?
    Aug 9, 2011 6:42 PM   in reply to billhdz
    Please verify whether you have write privilege for the following folders. (If you have not installed some products, you can ignore corresponding folders). If not, grant youself write privilege. If some of these folders don’t exist yet, you can create them manually and grant write privilege.
    /Library/Application Support/Adobe/InDesign/Version 7.0/<Locale>/Extensions
    /Library/Application Support/Adobe/ Premiere Pro CS5/Configuration/Extensions
    /Library/Application Support/Adobe/Extension Manager CS5/ Premiere Pro CS5
    /Users/<UserName>/Library/Application Support/Adobe/Flash CS5/<Locale>/Configuration/Extensions
    /Users/<UserName>/Library/Application Support/Adobe/ Adobe Contribute CS5/<Locale>/Configuration/Extensions
    /Users/<UserName>/Library/Application Support/Adobe/Adobe InDesign CS5/Configuration/Extensions
    /Users/<UserName>/Library/Application Support/Adobe/Bridge CS5/Configuration/Extensions
    /Users/<UserName>/Library/Application Support/Adobe/Dreamweaver CS5/<Locale>/Configuration/Extensions
    /Users/<UserName>/Library/Application Support/Adobe/Extension Manager CS5/Configuration/Extensions
    /Users/Shared/Library/Application Support/Adobe/Dreamweaver CS5/<Locale>/Configuration/Extensions
    Orange directories are created by CS installer, green directories are created by ExMan during the first launch, blue directories are created by ExMan when necessary.
    Aug 9, 2011 6:45 PM   in reply to Carl Sun
    Sorry, the reply loses the font color after post. But it has no much impact.
    Jan 9, 2012 11:21 AM   in reply to Carl Sun
    I tried all of the above as well. No change. EM launches and immediately crashes.
    Jan 10, 2012 6:41 PM   in reply to kalantan
    Have you install Flash FireBug? It conflicts with Extension Manager. Is the window of Extension Manager visible or nothing is displayed when crash?
    1. Please move all files under "/Users/<UserName>/Library/Preferences/Macromedia/Flash Player/#Security/FlashPlayerTrust" and "/Library/Application Support/Macromedia/FlashPlayerTrust" to somewhere else, then start up Extension Manager.
    2. If it doesn't help, move all above files back. please generate log files to help troubleshooting.
    Feb 12, 2012 2:48 PM   in reply to Carl Sun
    I installed Adobe Extension Manager 5.5 all the while I use Adobe Photoshop 5.02. I'm trying to install a Adobe Extension but it gives me an error, it wouldn't be related to the fact I installed Extension Manager 5.5 and not 5.02, if so where do find Extension Manager 5.02 ?
    Feb 12, 2012 6:17 PM   in reply to StrongBeaver
    Extension Manager CS5 should be used with Photoshop 5.02. You can download Extension Manager CS5 from http://www.adobe.com/exchange/em_download/em50_download.html. If you use Mac OS X 10.7 (Lion), after installing Extension Manager CS5, you will be notified to update to 5.0.2. You can also install 5.0.2 patch manually (click http://download.macromedia.com/pub/dw_exchange/extension_manager/mac/A dobeExtensionManager_5_0_2_mul_AdobeUpdate.dmg to download). This patch solved the issue that the signature of third party extensions cannot be validated.
    Feb 12, 2012 8:48 PM   in reply to Carl Sun
    What do I do with the update which is a DMG file ? I read it's an iso file on one site,I read on another site you need a special program ?
    Feb 12, 2012 8:52 PM   in reply to StrongBeaver
    Are you using Windows or Mac OS X? The dmg file is only needed on Mac OS X 10.7. If you do use Mac OS X 10.7, you can double click the DMG file to mount it, then double click the installer in new window.
    Feb 12, 2012 9:09 PM   in reply to Carl Sun
    I'm using Windows.  Is there an update for Windows ?
    Feb 12, 2012 9:12 PM   in reply to StrongBeaver
    There is no update for Windows. That issue only exists on Mac.
    Feb 14, 2012 5:46 AM   in reply to mamzellleju
    I have this issue on Windows 7. It appears to be the same as posted above.
    I have installed Extension manager CS5 from the adobe site. but the app will not open. I see it on the windows bar but cannot video the actual screen. See attached video.
    Video here
    http://acoustified.com/ExtensionManagerNotWorkingWindows7/ExtensionMan agerNotWorkingWindows7.mp4
    Please help. J
    Feb 14, 2012 7:25 AM   in reply to Jlev911
    Hi Jlev911,
    I am not sure what the root cause is for your problem, but you can try the steps below. Hope they can work.
    1. Delete extension manager gui preference file in X:\Users\<username>\AppData\Roaming\Adobe\Extension Manager CS5\Configuration\Extensions\exman_uiPreferences.xml, and restart extension manager.
    2. From your video I know you have 4 products installed. Have you ever launched extension manager successfully?Did this problem happen after you installed one product? If this problem showed up after you installed a product, try to rename its XManConfig.xml to other file name and restart extension manager.
    3. If "X:\Users\<username>\AppData\Roaming\Macromedia\Flash Player\#Security\FlashPlayerTrust" exists, move it to somewhere else and restart extenson manager.
    4. From your video I saw FireFox was opened. Try to close it and restart extenson manager. If it does not help, disable its plugins and restart extension manager again( some plugins conflict with extension manager ).
    5. Do you have enough permission to launch extension manager? Try to launch it with administrator and make sure you have write access to extension manager folders( I don't have extension manger cs5 installed, but they might locate in your home directory and pubic directory )?
    6. If all of them still can not help you, generate extenson manger log files, attach them to the forum and we can check what happened( create ExManLog.YES in the same folder of extension manager exe file ).
    Feb 26, 2013 4:57 AM   in reply to mamzellleju
    Hello.  My extension manager will not start either.  I have deleted and reinstalled. I have tried to start using the sudo command.  Nothing seems to work.  Please advise (error log attached).  Thank you.
    Process:     Adobe Extension Manager CS5.5 [1774]
    Path:        /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/MacOS/Adobe Extension Manager CS5.5
    Identifier:  com.adobe.ExtensionManager
    Version:     "5.5.2.20" (5.5.20)
    Code Type:   X86 (Native)
    Parent Process:  launchd [135]
    User ID:     501
    Date/Time:   2013-02-26 07:50:06.041 -0500
    OS Version:  Mac OS X 10.8.2 (12C60)
    Report Version:  10
    Interval Since Last Report:      687747 sec
    Crashes Since Last Report:       17
    Per-App Interval Since Last Report:  13 sec
    Per-App Crashes Since Last Report:   3
    Anonymous UUID:                  6E42F100-0B0C-CBA5-E28E-70FC1D9E5CB8
    Crashed Thread:  11
    Exception Type:  EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
    VM Regions Near 0:
    --> __PAGEZERO         0000000000000000-0000000000001000 [4K] ---/--- SM=NUL  /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/MacOS/Adobe Extension Manager CS5.5
    __TEXT             0000000000001000-0000000000210000 [ 2108K] r-x/rwx SM=COW  /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/MacOS/Adobe Extension Manager CS5.5
    Thread 0:: Dispatch queue: com.apple.main-thread
    0   com.apple.CoreGraphics    0x912dcd38 sseCGSBlendXXXX8888Transpose + 520
    1   com.apple.CoreGraphics    0x9118ae84 CGSBlendABGR8888toRGBA8888 + 949
    2   com.apple.CoreGraphics    0x911635e1 argb32_image + 2504
    3   libRIP.A.dylib            0x936fed08 ripd_Mark + 291
    4   libRIP.A.dylib            0x936feba3 ripl_BltImage + 1585
    5   libRIP.A.dylib            0x936fe30f ripc_RenderImage + 259
    6   libRIP.A.dylib            0x936fbeca ripc_DrawImage + 1078
    7   com.apple.CoreGraphics    0x9115f435 CGContextDrawImage + 427
    8   com.apple.HIToolbox       0x9402c37a HIViewDrawCGImage + 220
    9   AdobeOwl                  0x0049df95 OWLOSXApplicationContainerCreate + 94901
    10  AdobeOwl                  0x0049fb2a OWLOSXApplicationContainerCreate + 101962
    11  AdobeOwl                  0x0039887c OWLThemeChangeInterpolator + 84760
    12  AdobeOwl                  0x00398d5b OWLThemeChangeInterpolator + 86007
    13  AdobeOwl                  0x004a04ac OWLOSXApplicationContainerCreate + 104396
    14  AdobeOwl                  0x003842b1 OWLThemeChangeInterpolator + 1357
    15  com.apple.HIToolbox       0x94109b6b _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
    16  com.apple.HIToolbox       0x93f91594 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1343
    17  com.apple.HIToolbox       0x93f90980 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430
    18  com.apple.HIToolbox       0x93f907ca SendEventToEventTargetWithOptions + 94
    19  com.apple.HIToolbox       0x93faad17 HIView::SendDraw(short, OpaqueGrafPtr*, __HIShape const*, CGContext*) + 491
    20  com.apple.HIToolbox       0x940379d5 HIView::RecursiveDrawComposited(__HIShape const*, __HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 759
    21  com.apple.HIToolbox       0x94037d5c HIView::RecursiveDrawComposited(__HIShape const*, __HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 1662
    22  com.apple.HIToolbox       0x94037d5c HIView::RecursiveDrawComposited(__HIShape const*, __HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 1662
    23  com.apple.HIToolbox       0x94036df0 HIView::DrawComposited(short, OpaqueGrafPtr*, __HIShape const*, unsigned long, HIView*, CGContext*) + 802
    24  com.apple.HIToolbox       0x94036a82 HIView::Draw(short, OpaqueGrafPtr*, unsigned long) + 82
    25  com.apple.HIToolbox       0x94036a29 HIView::Render(unsigned long, CGContext*) + 45
    26  com.apple.HIToolbox       0x93fb3460 FlushWindowObject(WindowData*, void**, unsigned char) + 812
    27  com.apple.HIToolbox       0x93fbbfb1 FlushAllBuffers(__CFRunLoopObserver*, unsigned long, void*) + 245
    28  com.apple.CoreFoundation  0x9326adfe __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 30
    29  com.apple.CoreFoundation  0x9326ad3d __CFRunLoopDoObservers + 381
    30  com.apple.CoreFoundation  0x93244623 CFRunLoopRunSpecific + 355
    31  com.apple.CoreFoundation  0x932444ab CFRunLoopRunInMode + 123
    32  com.apple.HIToolbox       0x93fb515a RunCurrentEventLoopInMode + 242
    33  com.apple.HIToolbox       0x93fb4ec9 ReceiveNextEventCommon + 374
    34  com.apple.HIToolbox       0x9411a35d _AcquireNextEvent + 68
    35  com.apple.HIToolbox       0x9410911a RunApplicationEventLoop + 225
    36  com.adobe.ExtensionManager0x00005e88 main + 4416
    37  com.adobe.ExtensionManager0x0000232a start + 54
    Thread 1:
    0   libsystem_kernel.dylib    0x978100ee __workq_kernreturn + 10
    1   libsystem_c.dylib         0x9572604c _pthread_workq_return + 45
    2   libsystem_c.dylib         0x95725e19 _pthread_wqthread + 448
    3   libsystem_c.dylib         0x9570dcca start_wqthread + 30
    Thread 2:: Dispatch queue: com.apple.libdispatch-manager
    0   libsystem_kernel.dylib    0x978109ae kevent + 10
    1   libdispatch.dylib         0x996c4c71 _dispatch_mgr_invoke + 993
    2   libdispatch.dylib         0x996c47a9 _dispatch_mgr_thread + 53
    Thread 3:
    Thread 4:
    0   libsystem_kernel.dylib    0x9780d8e6 mach_wait_until + 10
    1   libsystem_c.dylib         0x957b4c1c nanosleep + 375
    2   com.adobe.ExtensionManager0x0015182f ScObjects::Thread::sleep(unsigned int) + 143
    3   com.adobe.ExtensionManager0x0015188f ScObjects::Thread::wait(unsigned int) + 23
    4   com.adobe.ExtensionManager0x0014845a ScObjects::BridgeTalkThread::run() + 332
    5   com.adobe.ExtensionManager0x00151d99 ScObjects::Thread::go(void*) + 315
    6   libsystem_c.dylib         0x95723557 _pthread_start + 344
    7   libsystem_c.dylib         0x9570dcee thread_start + 34
    Thread 5:
    0   libsystem_kernel.dylib    0x9780d7d2 mach_msg_trap + 10
    1   libsystem_kernel.dylib    0x9780ccb0 mach_msg + 68
    2   com.adobe.adobeswfl       0x062d518f ExternalPlayer_Initialize + 465535
    3   libsystem_c.dylib         0x95723557 _pthread_start + 344
    4   libsystem_c.dylib         0x9570dcee thread_start + 34
    Thread 6:
    0   libsystem_kernel.dylib    0x9780f8e2 __psynch_cvwait + 10
    1   libsystem_c.dylib         0x95728289 _pthread_cond_wait + 938
    2   libsystem_c.dylib         0x957b5afc pthread_cond_wait + 48
    3   com.adobe.adobeswfl       0x06282f54 ExternalPlayer_Initialize + 129092
    4   com.adobe.adobeswfl       0x0605334a 0x6044000 + 62282
    5   com.adobe.adobeswfl       0x06282ce7 ExternalPlayer_Initialize + 128471
    6   com.adobe.adobeswfl       0x06282d3f ExternalPlayer_Initialize + 128559
    7   libsystem_c.dylib         0x95723557 _pthread_start + 344
    8   libsystem_c.dylib         0x9570dcee thread_start + 34
    Thread 7:
    Thread 8:
    Thread 9:
    Thread 10:
    Thread 11 Crashed:
    0   com.apple.CoreFoundation  0x93229d1e CFURLCreateStringWithFileSystemPath + 206
    1   com.apple.CoreFoundation  0x93229c25 CFURLCopyFileSystemPath + 53
    2   com.adobe.ExtensionManager0x000d08e5 CMemoryMappedFile::CMemoryMappedFile(FSRef const&, bool) + 97
    3   com.adobe.ExtensionManager0x000d0d2a CMacFileBuffer::CMacFileBuffer(FSRef const&, HFSUniStr255 const&, bool, bool) + 192
    4   com.adobe.ExtensionManager0x000adbc1 CFile::Open(wchar_t const*, unsigned int, bool) + 411
    5   com.adobe.ExtensionManager0x0011dd70 CMacrPluginConfigFile::load(CString const&) + 196
    6   com.adobe.ExtensionManager0x00019062 CMacrExtensionManager::updatePluginFile(CMacrExtension const*, CMacrProduct const*, CMacrExtensionPaths const&, bool) + 126
    7   com.adobe.ExtensionManager0x000298b7 CMacrExtensionManager::migrateFiles(CString const&, CMacrPath const&, CMacrPath const&, CMacrPath const&, CMacrPath const&, CMacrProduct const*, int) + 7253
    8   com.adobe.ExtensionManager0x00029fe3 CMacrExtensionManager::migrateExtensionFromExtensionFile(CString const&, CString const&, CString const&, CMacrProduct const*) + 1377
    9   com.adobe.ExtensionManager0x0002a45c CMacrExtensionManager::migrateExtensionsFromProductPreferredFolder(CM acrProduct const*) + 574
    10  com.adobe.ExtensionManager0x0002a91d CMacrExtensionManager::migrateExtensionsFromProductsPreferredFolders( ) + 163
    11  com.adobe.ExtensionManager0x00119b53 MigratePreferredExtensionCommand::execute() + 19
    12  com.adobe.ExtensionManager0x000dd150 CommandExecutor_Impl::run() + 144
    13  com.adobe.ExtensionManager0x000dd16b CommandExecutor_Impl::runHelper(void*) + 17
    14  libsystem_c.dylib         0x95723557 _pthread_start + 344
    15  libsystem_c.dylib         0x9570dcee thread_start + 34
    Thread 11 crashed with X86 Thread State (32-bit):
      eax: 0x00000000  ebx: 0x93229c61  ecx: 0x00000000  edx: 0x00000000
      edi: 0x00000000  esi: 0xac448840  ebp: 0xb05b0798  esp: 0xb05aef20
       ss: 0x00000023  efl: 0x00010246  eip: 0x93229d1e   cs: 0x0000001b
       ds: 0x00000023   es: 0x00000023   fs: 0x00000023   gs: 0x0000000f
      cr2: 0x00000000
    Logical CPU: 2
    Binary Images:
    0x1000 -   0x20ffeb +com.adobe.ExtensionManager ("5.5.2.20" - 5.5.20) <E83C03FC-E291-08C5-9492-CB67B8FC2F19> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/MacOS/Adobe Extension Manager CS5.5
      0x367000 -   0x36afe7 +libwchar.dylib (1) <DE7B4F71-F31A-46F7-B70D-A8A157B5EB6B> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/libwchar.dylib
      0x36e000 -   0x568fef +AdobeOwl (1) <466BD72B-E2A5-447A-9384-B6DC9AD3AE0C> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
      0x5e3000 -   0xae1fc3 +AdobeOwlCanvas (1) <45219076-15E0-4A0D-9BC0-2FFED8EA7E46> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobeOwlCanvas.framework/Versions/A/Ado beOwlCanvas
      0xc2a000 -   0xc9afeb +com.adobe.adobe_caps (adobe_caps 3.5.18.0 - 3.5.18.0) <A54D73C5-EBCF-75F1-9BB0-ADBB36042DEC> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/adobe_caps.framework/Versions/a/adobe_c aps
      0xca8000 -   0xcacffc +com.adobe.AdobeCrashReporter (3.0 - 5.5.20101001) <EA9B7B55-7FE5-14D2-FBAE-817121F94086> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A /AdobeCrashReporter
      0xcb2000 -   0xce7fef +com.adobe.pip (5.5.0.1272) <4AD1ED99-8BB9-B49E-16E5-B7E7A97AAA99> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
      0xcf2000 -   0xd48ffb +com.adobe.headlights.LogSessionFramework (2.1.2.1263) <5B594BC9-5222-651B-6B70-7AD067035B1A> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSess ion
      0xd8c000 -   0xdc8ff7  com.apple.vmutils (4.2.1 - 108) <6918860D-B24F-356C-9374-025BFFEA66A3> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutil s
      0xde2000 -   0xe8dfff  libcrypto.0.9.7.dylib (106) <041B3399-5033-3395-9A71-6693F3A33D94> /usr/lib/libcrypto.0.9.7.dylib
    0x18c3000 -  0x18d0ff3  com.apple.Librarian (1.1 - 1) <88A55A5E-40FF-3234-8394-2317120B79AB> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Libr arian
    0x1f00000 -  0x1f70feb +com.adobe.adobe_caps (adobe_caps 3.5.18.0 - 3.5.18.0) <A54D73C5-EBCF-75F1-9BB0-ADBB36042DEC> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
    0x1ff6000 -  0x1ff8ff3  com.apple.LiveType.component (2.1.4 - 2.1.4) <D60E2537-3B47-EA99-0077-6CE394378D07> /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    0x3403000 -  0x3405ff7  Motion (729) <051B60E9-B39F-EBB2-5B96-F088D147E78C> /Library/Frameworks/Motion.framework/Versions/A/Motion
    0x3445000 -  0x3446ffd  com.apple.textencoding.unicode (2.5 - 2.5) <4E2ABBEB-1F0D-3C06-BA0C-C3CEDDF17BD2> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
    0x3798000 -  0x37deffb  com.apple.motion.component (1.0 - 729) <494487C6-EA30-43DD-39E4-BED23C5A5B1C> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
    0x6044000 -  0x6847fe2 +com.adobe.adobeswfl (1.0.7) <53D59B93-133D-41B4-AE25-83532E5C0F6C> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobeOwl.framework/Resources/AdobeSWFL. bundle/Contents/MacOS/AdobeSWFL
    0x7b18000 -  0x7b26fff  libSimplifiedChineseConverter.dylib (61) <60899F9C-A79F-3BC2-855E-DC5C78B98FEB> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
    0x7b2d000 -  0x7b91fe2  com.apple.LiveType.framework (2.1.4 - 2.1.4) <C9D29156-2471-2A9D-3657-EF06204229C6> /Library/Application Support/ProApps/*/LiveType.framework/Versions/A/LiveType
    0x7bb1000 -  0x7c4eff8  com.apple.procore.framework (4.0.2 - 757) <D3146F1E-F86D-F2A2-509B-E3F9640CBE40> /Library/Application Support/ProApps/*/ProCore.framework/Versions/A/ProCore
    0xf326000 -  0xf338ffd  libTraditionalChineseConverter.dylib (61) <519CAA3F-715E-3CAE-B158-57EC95D916B1> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
    0xf93b000 -  0xfd2dfff +WebKit.dylib (1.0.7) <6FB30C58-17FE-4A4B-971E-CDE89FB7DD1B> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobeOwl.framework/Resources/WebKit.dyl ib
    0x111a5000 - 0x11263ff3  ColorSyncDeprecated.dylib (400) <35E3054C-5DF1-30D4-A368-C4FDB0992373> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated .dylib
    0x8fea3000 - 0x8fed5e57  dyld (210.2.3) <23DBDBB1-1D21-342C-AC2A-0E55F27E6A1F> /usr/lib/dyld
    0x90007000 - 0x9000bffe  libcache.dylib (57) <834FDCA7-FE3B-33CC-A12A-E11E202477EC> /usr/lib/system/libcache.dylib
    0x9000c000 - 0x900bbff7  com.apple.CoreText (260.0 - 275.16) <873ADCD9-D361-3753-A220-CDD289196AD8> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x900bc000 - 0x900bcfff  libkeymgr.dylib (25) <D5E93F7F-9315-3AD6-92C7-941F7B54C490> /usr/lib/system/libkeymgr.dylib
    0x900c9000 - 0x900d0fff  liblaunch.dylib (442.26.2) <310C99F8-0811-314D-9BB9-D0ED6DFA024B> /usr/lib/system/liblaunch.dylib
    0x900d1000 - 0x90115fff  libGLU.dylib (8.6.1) <06BAFDCA-800C-35E3-B1A3-F05E105B86AB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
    0x90116000 - 0x90164ff3  com.apple.SystemConfiguration (1.12.2 - 1.12.2) <7BA6C58B-0357-356F-BB69-17ACB5E35988> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
    0x90165000 - 0x901c9fff  com.apple.datadetectorscore (4.0 - 269.1) <3EFFB8D8-CD46-3BB2-9B9F-2F757B9EC998> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
    0x901ca000 - 0x901ccfff  libCVMSPluginSupport.dylib (8.6.1) <8A174BD9-992E-351D-8F9A-DF6991723ABE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC VMSPluginSupport.dylib
    0x901cd000 - 0x90265fff  com.apple.CoreServices.OSServices (557.4 - 557.4) <C724AB29-A596-3E1E-9FF1-A4E509AD843A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
    0x90266000 - 0x90266fff  com.apple.Cocoa (6.7 - 19) <354094F0-F36B-36F9-BF5F-FD60590FBEB9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x90267000 - 0x902c2fff  com.apple.htmlrendering (77 - 1.1.4) <5C0C669F-AE07-3983-B38F-EB829B5CE609> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
    0x902c3000 - 0x90327ff3  libstdc++.6.dylib (56) <F8FA490A-8F3C-3645-ABF5-78926CE9C62C> /usr/lib/libstdc++.6.dylib
    0x906a1000 - 0x906e6ff7  com.apple.NavigationServices (3.7 - 200) <F6531764-6E43-3AF3-ACDD-8A5551EF016A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
    0x906e7000 - 0x906f1fff  com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <B855E8B4-2EE3-3BFF-8547-98A0F084F9AF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
    0x906f2000 - 0x90727fff  libTrueTypeScaler.dylib (84.5) <2598F930-5E6B-37D7-B1E6-18181A972C6E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x90959000 - 0x90986ffb  com.apple.CoreServicesInternal (154.2 - 154.2) <DCCF604B-1DB8-3F09-8122-545E2E7F466D> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Vers ions/A/CoreServicesInternal
    0x90987000 - 0x909d6ff6  libTIFF.dylib (845) <989A2EB9-3A49-3157-8E9C-B16E6005BC64> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib TIFF.dylib
    0x909d7000 - 0x909d9fff  com.apple.securityhi (4.0 - 55002) <79E3B880-3AB7-3BF3-9CDF-117A45599545> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
    0x909da000 - 0x909defff  com.apple.CommonPanels (1.2.5 - 94) <6B3E7E53-7708-3DA2-8C50-59C2B4735DE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
    0x909df000 - 0x90c5bff7  com.apple.QuickTime (7.7.1 - 2599.13) <FE609160-E1EF-341D-9B6A-205D3E03A4D2> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x90c5c000 - 0x90cd8ffb  libType1Scaler.dylib (101.1) <0D94D786-29F7-33DB-B64B-B264FA5EACD2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
    0x90dce000 - 0x90e28fff  com.apple.Symbolication (1.3 - 93) <A839CFC2-F870-3652-B353-15A55D88F88D> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/ Symbolication
    0x90f8b000 - 0x91103ff5  com.apple.QuartzCore (1.8 - 304.0) <D9E018B8-6E5F-3FFA-A1B2-2B1BC1E03CA2> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x91104000 - 0x91546fff  com.apple.CoreGraphics (1.600.0 - 324.6) <66556166-F9A7-3EEC-A562-46061C7A79E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x91547000 - 0x915affe7  libvDSP.dylib (380.6) <55780308-4DCA-3B10-9703-EAFC3E13A3FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
    0x9171b000 - 0x9171cfff  libdnsinfo.dylib (453.18) <41C7B8E2-2A81-31DE-BD8B-F0C29E169D4F> /usr/lib/system/libdnsinfo.dylib
    0x9171d000 - 0x9177afff  com.apple.audio.CoreAudio (4.1.0 - 4.1.0) <9549B81F-4425-34EE-802B-F462068DC0C5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x917f5000 - 0x9188ffff  com.apple.CoreSymbolication (3.0 - 87) <1A13CC83-4635-3AC6-9A86-E8DCE99562B5> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Version s/A/CoreSymbolication
    0x91890000 - 0x918c6ffb  com.apple.DebugSymbols (98 - 98) <9A9ADA0A-E487-3C8F-9998-286EE04C235A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/D ebugSymbols
    0x918c7000 - 0x91929fff  libc++.1.dylib (65.1) <C0CFF9FF-5D52-3EAE-B921-6AE1DA00A135> /usr/lib/libc++.1.dylib
    0x921a7000 - 0x9222cff7  com.apple.SearchKit (1.4.0 - 1.4.0) <454E950F-291C-3E95-8F35-05CA0AD6B327> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
    0x9222d000 - 0x9233a057  libobjc.A.dylib (532.2) <FA455371-7395-3D58-A89B-D1520612D1BC> /usr/lib/libobjc.A.dylib
    0x9233b000 - 0x92349fff  com.apple.opengl (1.8.6 - 1.8.6) <1AD1AE7B-B57B-35B5-B571-32A34F0DA737> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x9234d000 - 0x92509ffd  libicucore.A.dylib (491.11.1) <B19E450A-BAF1-3967-9C95-7F77DC0B4639> /usr/lib/libicucore.A.dylib
    0x9250c000 - 0x92529fff  libxpc.dylib (140.41) <1BFE3149-C242-3A77-9729-B00DEDC8CCF2> /usr/lib/system/libxpc.dylib
    0x9252d000 - 0x9253dff2  com.apple.LangAnalysis (1.7.0 - 1.7.0) <875363E7-6D02-3229-A9DD-E5A5568A7D61> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x9256f000 - 0x92812ffb  com.apple.CoreImage (8.2.2 - 1.0.1) <85BFFB09-D765-3F5F-AF65-FB136DDCAEF3> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /CoreImage.framework/Versions/A/CoreImage
    0x9281a000 - 0x92821fff  libsystem_dnssd.dylib (379.32.1) <6A505284-2382-3F27-B96F-15FFDACF004E> /usr/lib/system/libsystem_dnssd.dylib
    0x9282e000 - 0x9285aff7  libsystem_info.dylib (406.17) <AA5611DB-A944-3072-B6BE-ACAB08689547> /usr/lib/system/libsystem_info.dylib
    0x928a5000 - 0x928a5fff  com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <908B8D40-3FB5-3047-B482-3DF95025ECFC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
    0x928a6000 - 0x928aefff  com.apple.CommerceCore (1.0 - 26) <AF0D1990-8CBF-3AB4-99DF-8B7AE14FB0D5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
    0x928af000 - 0x92bccff3  com.apple.Foundation (6.8 - 945.11) <03B242AC-519C-3683-AA52-E73536B3D55F> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x92bd3000 - 0x92bd5ffb  libRadiance.dylib (845) <3F87840F-217D-3074-A29D-919BAAED2F4A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib Radiance.dylib
    0x92bd6000 - 0x92c2dff7  com.apple.ScalableUserInterface (1.0 - 1) <2B5E454B-BC49-3E85-B54D-1950397C448C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /ScalableUserInterface.framework/Versions/A/ScalableUserInterface
    0x930e9000 - 0x930ecff7  libcompiler_rt.dylib (30) <CE5DBDB4-0124-3E2B-9105-989DF98DD108> /usr/lib/system/libcompiler_rt.dylib
    0x930ed000 - 0x930edfff  com.apple.ApplicationServices (45 - 45) <677C4ACC-9D12-366F-8A87-B898AC806DD9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
    0x930ee000 - 0x930f7ffd  com.apple.audio.SoundManager (4.0 - 4.0) <ABC5FE40-B222-36EB-9905-5C8C4BFD8C87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
    0x930f8000 - 0x93127ff7  com.apple.securityinterface (6.0 - 55024.4) <7C5E28DC-F8BE-3238-883F-E1646A2AF895> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/Sec urityInterface
    0x93128000 - 0x93147ff3  com.apple.Ubiquity (1.2 - 243.10) <D2C9F356-1681-31D2-B292-5227E2DDEB0B> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiqu ity
    0x93190000 - 0x9320cff3  com.apple.Metadata (10.7.0 - 707.3) <6B6A6216-23D0-34CE-8099-BEE9BA42501E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
    0x9320d000 - 0x933f5ff3  com.apple.CoreFoundation (6.8 - 744.12) <E939CEA0-493C-3233-9983-5070981BB350> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
    0x933f6000 - 0x933f9ffc  libpam.2.dylib (20) <FCF74195-A99E-3B07-8E49-688D4A6F1E18> /usr/lib/libpam.2.dylib
    0x933fa000 - 0x934f2ff9  libsqlite3.dylib (138.1) <AD7C5914-35F0-37A3-9238-A29D2E26C755> /usr/lib/libsqlite3.dylib
    0x934f5000 - 0x934fdfff  libcopyfile.dylib (89) <4963541B-0254-371B-B29A-B6806888949B> /usr/lib/system/libcopyfile.dylib
    0x93501000 - 0x93576ff7  com.apple.ApplicationServices.ATS (332 - 341.1) <95206704-F9C9-33C4-AF25-FE9890E160B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
    0x935a6000 - 0x935b0fff  libCSync.A.dylib (324.6) <D2E8AC70-C6D1-3C40-8A82-E50422EDCFBF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x935c0000 - 0x935ccff8  libbz2.1.0.dylib (29) <7031A4C0-784A-3EAA-93DF-EA1F26CC9264> /usr/lib/libbz2.1.0.dylib
    0x9366a000 - 0x9366dff9  libCGXType.A.dylib (324.6) <3004616B-51F6-3B9D-8B85-DCCA3DF9BC10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
    0x936ee000 - 0x93717ff7  libRIP.A.dylib (324.6) <7976E6A2-A489-33F5-A727-7634DDE3B761> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x93aac000 - 0x93aacfff  com.apple.vecLib (3.8 - vecLib 3.8) <83160DD1-5614-3E34-80EB-97041016EF1F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x93aed000 - 0x93af4ffe  com.apple.agl (3.2.1 - AGL-3.2.1) <D0A9B878-7F1F-3210-B6AF-91D2DBEFF21B> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x93af5000 - 0x93eadffa  libLAPACK.dylib (1073.4) <9A6E5EAD-F2F2-3D5C-B655-2B536DB477F2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
    0x93eae000 - 0x93ebcff3  libsystem_network.dylib (77.10) <7FBF5A15-97BA-3721-943E-E77F0C40DBE1> /usr/lib/system/libsystem_network.dylib
    0x93ebd000 - 0x93ebdfff  com.apple.Accelerate (1.8 - Accelerate 1.8) <4EC0548E-3A3F-310D-A366-47B51D5B6398> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x93ebe000 - 0x93ee3ffb  com.apple.framework.familycontrols (4.1 - 410) <5A8504E7-D95D-3101-8E20-38EADE8DEAE1> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
    0x93f3e000 - 0x93f5cff3  com.apple.openscripting (1.3.6 - 148.2) <55738D66-CC15-3F43-9265-00C3322D39C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
    0x93f5d000 - 0x94340ff3  com.apple.HIToolbox (2.0 - 625) <5A312E41-9940-363E-B891-90C4672E6850> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
    0x94341000 - 0x9435afff  com.apple.Kerberos (2.0 - 1) <9BDE8F4D-DBC3-34D1-852C-898D3655A611> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x9435b000 - 0x9442ffff  com.apple.backup.framework (1.4.1 - 1.4.1) <55F2A679-9B21-3F43-A580-4C2ECF6A5FC5> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x94430000 - 0x94431fff  libsystem_sandbox.dylib (220) <4E42390B-25EC-3530-AF01-337E430C16EB> /usr/lib/system/libsystem_sandbox.dylib
    0x94432000 - 0x9457fffb  com.apple.CFNetwork (596.2.3 - 596.2.3) <1221EF86-659B-3136-AB57-0CC6B130CDA2> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x94581000 - 0x945a5fff  libJPEG.dylib (845) <547FA9A5-0BBB-3E39-BACA-F3E2DAE57DB0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib JPEG.dylib
    0x94644000 - 0x9485bfff  com.apple.CoreData (106.1 - 407.7) <17FD06D6-AD7C-345A-8FA4-1F0FBFF4DAE1> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x94975000 - 0x95531ffb  com.apple.AppKit (6.8 - 1187.34) <06EDB1D1-3B8A-3699-8E3A-D8F50A27AB7C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x95532000 - 0x955e6fff  com.apple.coreui (2.0 - 181.1) <C15ABF35-B7F5-34ED-A461-386DAF65D96B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x955e7000 - 0x955e8fff  libDiagnosticMessagesClient.dylib (8) <39B3D25A-148A-3936-B800-0D393A00E64F> /usr/lib/libDiagnosticMessagesClient.dylib
    0x9570d000 - 0x957cafeb  libsystem_c.dylib (825.25) <B1F6916A-F558-38B5-A18C-D9733625FDC9> /usr/lib/system/libsystem_c.dylib
    0x957d1000 - 0x9580cfe7  libGLImage.dylib (8.6.1) <A3442557-18D5-332E-8859-423D5A20EBBE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
    0x95939000 - 0x959a1ff7  com.apple.framework.IOKit (2.0 - 755.18.10) <9A80E97E-544F-3A45-916D-6DB7ED217E33> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x959a2000 - 0x959f0ffb  libFontRegistry.dylib (100) <3B8350C2-4D8F-38C4-A22E-2F855D7E83D1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x959f1000 - 0x95a91ff7  com.apple.QD (3.42 - 285) <1B8307C6-AFA8-312E-BA5B-679070EF2CA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
    0x95a92000 - 0x95abbfff  libxslt.1.dylib (11.3) <0DE17DAA-66FF-3195-AADB-347BEB5E2EFA> /usr/lib/libxslt.1.dylib
    0x95abc000 - 0x95ad9fff  libCRFSuite.dylib (33) <C9D72D0C-871A-39A2-8AFB-682D11AE7D0D> /usr/lib/libCRFSuite.dylib
    0x95ada000 - 0x95be7ff3  com.apple.ImageIO.framework (3.2.0 - 845) <BF959BCB-C30A-3680-B7C2-91B327B2B63B> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x95d38000 - 0x95d5afff  libc++abi.dylib (24.4) <06479DA4-BC23-34B6-BAFC-A885814261D0> /usr/lib/libc++abi.dylib
    0x95fe8000 - 0x95ffbff9  com.apple.MultitouchSupport.framework (235.28 - 235.28) <5C8CFA21-D4FC-32E8-B199-0F7155E6ED9A> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
    0x9603b000 - 0x96042ffb  libunwind.dylib (35.1) <E1E8D8B3-3C78-3AB1-B398-C180DC6DCF05> /usr/lib/system/libunwind.dylib
    0x96043000 - 0x960edfff  com.apple.LaunchServices (539.7 - 539.7) <AF33EBD3-BC0B-30B5-B7DA-5CCCF12D7EDD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
    0x96e27000 - 0x96e28ffd  libunc.dylib (25) <58599CBF-E262-3CEA-AFE1-35560E0177DC> /usr/lib/system/libunc.dylib
    0x96e55000 - 0x96ea1fff  libcorecrypto.dylib (106.2) <20EBADBA-D6D6-36F0-AE80-168E9AF13DB6> /usr/lib/system/libcorecrypto.dylib
    0x96ee3000 - 0x96f75ffb  libvMisc.dylib (380.6) <6DA3A03F-20BE-300D-A664-B50A7B4E4B1A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
    0x96f76000 - 0x96f78fff  libdyld.dylib (210.2.3) <05D6FF2A-F09B-309D-95F7-7AF10259C707> /usr/lib/system/libdyld.dylib
    0x96f79000 - 0x96f7cfff  com.apple.help (1.3.2 - 42) <AD7EB1F0-A068-3A2C-9D59-38E59CEC0D96> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
    0x96f82000 - 0x96f8effe  libkxld.dylib (2050.18.24) <48A75AF6-9D5A-3552-948E-30A1682D3664> /usr/lib/system/libkxld.dylib
    0x96f90000 - 0x96f90fff  com.apple.CoreServices (57 - 57) <956C6C6D-A5DD-314F-9C57-4A61D41F30CE> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
    0x9761e000 - 0x97698ff3  com.apple.securityfoundation (6.0 - 55115.4) <8A3DA1FE-1985-3ECB-945A-6B1E853B4BDC> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
    0x97699000 - 0x977f1ffb  com.apple.audio.toolbox.AudioToolbox (1.8 - 1.8) <9205DFC2-8DAE-354E-AD87-46E229B5F2F1> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
    0x977f2000 - 0x977fafff  com.apple.DiskArbitration (2.5.1 - 2.5.1) <25A7232F-9B6A-3746-A3A8-12479D086B1E> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
    0x977fb000 - 0x97815ffc  libsystem_kernel.dylib (2050.18.24) <C17D49D0-7961-3B67-B443-C788C6E5AA76> /usr/lib/system/libsystem_kernel.dylib
    0x97816000 - 0x978d4ff3  com.apple.ColorSync (4.8.0 - 4.8.0) <EFEDCB37-4F20-3CEC-A185-5D2976E11BAC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
    0x978d5000 - 0x97a10ff7  libBLAS.dylib (1073.4) <FF74A147-05E1-37C4-BC10-7DEB57FE5326> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
    0x97a69000 - 0x97b5affc  libiconv.2.dylib (34) <B096A9B7-83A6-31B3-8D2F-87D91910BF4C> /usr/lib/libiconv.2.dylib
    0x97b5b000 - 0x97b64ff9  com.apple.CommonAuth (3.0 - 2.0) <A1A6CC3D-AA88-3519-A305-9B5D76C5D63B> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/Com monAuth
    0x97b65000 - 0x97b66fff  libquarantine.dylib (52) <D526310F-DC77-37EA-8F5F-83928EFA3262> /usr/lib/system/libquarantine.dylib
    0x97b67000 - 0x97b87ffd  com.apple.ChunkingLibrary (2.0 - 133.2) <FE5F0F1E-B15D-3F76-8655-DC2FE19BF56E> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/ A/ChunkingLibrary
    0x97c99000 - 0x97ca0ff3  com.apple.NetFS (5.0 - 4.0) <1F7041F2-4E97-368C-8F5D-24153D81BBDB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x97ca3000 - 0x97cc7fff  com.apple.PerformanceAnalysis (1.16 - 16) <18DE0F9F-1264-394D-AC56-6B2A1771DFBE> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versi ons/A/PerformanceAnalysis
    0x97ddc000 - 0x97de6ffe  com.apple.bsd.ServiceManagement (2.0 - 2.0) <9732BA61-D6F6-3644-82DA-FF0D6FEEFC69> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/Ser viceManagement
    0x97de7000 - 0x97df3ff7  com.apple.NetAuth (4.0 - 4.0) <4983C4B8-9D95-3C4D-897E-07743326487E> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAut h
    0x97df4000 - 0x97e09fff  com.apple.ImageCapture (8.0 - 8.0) <B8BD421F-D5A9-3FB4-8E89-AD5CFC0D4030> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
    0x97e0a000 - 0x97e3dff3  com.apple.GSS (3.0 - 2.0) <B1D719C1-B000-3BE3-B747-329D608585DD> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x97e3e000 - 0x97e3efff  com.apple.Carbon (154 - 155) <C0A26E7B-28F1-3C7E-879E-A3CF3ED5111C> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x980d9000 - 0x980ddff7  libmacho.dylib (829) <5280A013-4F74-3F74-BE0C-7F612C49F1DC> /usr/lib/system/libmacho.dylib
    0x98114000 - 0x9821fff7  libJP2.dylib (845) <D409C913-6FA4-3D60-BFE0-B9FC6A02FEE0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib JP2.dylib
    0x98220000 - 0x98251fff  com.apple.DictionaryServices (1.2 - 184.4) <0D5BE86F-F40A-3E39-8569-19FCA5EDF9D3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x98252000 - 0x982b8fff  com.apple.print.framework.PrintCore (8.1 - 387.1) <F8CF762B-B707-3021-958F-BB8D33DB3576> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
    0x982b9000 - 0x982baffd  com.apple.TrustEvaluationAgent (2.0 - 23) <E42347C0-2D3C-36A4-9200-757FFA61B388> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
    0x982bb000 - 0x982c8ff7  com.apple.AppleFSCompression (49 - 1.0) <166AA1F8-E50A-3533-A3B5-8737C5118CC3> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versio ns/A/AppleFSCompression
    0x982c9000 - 0x982cdffc  libGIF.dylib (845) <714E9F0D-D7A3-3F58-B46E-FCBE0F144B23> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib GIF.dylib
    0x982ce000 - 0x982dcff7  libz.1.dylib (43) <245F1B61-2276-3BBB-9891-99934116D833> /usr/lib/libz.1.dylib
    0x982dd000 - 0x9831cff7  com.apple.bom (12.0 - 192) <0637E52C-D151-37B3-904F-8656B2FD44DD> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x98327000 - 0x985e7fff  com.apple.security (7.0 - 55179.1) <CB470E48-621B-34D9-9E78-8B773358CB6B> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x985e8000 - 0x9860dff7  com.apple.CoreVideo (1.8 - 99.3) <5B872AC0-E82D-3475-A3F9-FD95F380560D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x9860e000 - 0x98653ff5  com.apple.opencl (2.1.20 - 2.1.20) <41C4AE6E-67B6-33E2-A9B6-BF6F01580B16> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x986ab000 - 0x9871affb  com.apple.Heimdal (3.0 - 2.0) <1ABF438B-30E6-3165-968C-E2EA1A9DF1FD> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimda l
    0x9871b000 - 0x988a4ff7  com.apple.vImage (6.0 - 6.0) <1D1F67FE-4F75-3689-BEF6-4A46C8039E70> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
    0x988a5000 - 0x9893cff7  com.apple.ink.framework (10.8.2 - 150) <D90FF7BC-6B90-39F1-AC52-670269947C58> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
    0x9893d000 - 0x98940ffd  libCoreVMClient.dylib (24.4) <C54E8FD0-61EC-3DC8-8631-54288AC66AC8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
    0x98941000 - 0x98941ffd  libOpenScriptingUtil.dylib (148.2) <907E25B1-4F50-3461-B8D5-733C687EB534> /usr/lib/libOpenScriptingUtil.dylib
    0x9895a000 - 0x98d77fff  FaceCoreLight (2.4.1) <571DE3F8-CA8A-3E71-9AF4-F06FFE721CE6> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/ FaceCoreLight
    0x98d78000 - 0x98d78fff  libSystem.B.dylib (169.3) <F479E729-89C7-3B4C-9731-678EB673A861> /usr/lib/libSystem.B.dylib
    0x98d79000 - 0x98d95ff7  libPng.dylib (845) <14C43094-C670-3575-BF9B-3A967E05EAC0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib Png.dylib
    0x98d96000 - 0x98da1fff  libcommonCrypto.dylib (60026) <A6C6EDB8-7E69-3827-81F3-9A74D0935461> /usr/lib/system/libcommonCrypto.dylib
    0x98da2000 - 0x98dfbfff  com.apple.AE (645.3 - 645.3) <6745659F-006D-3F25-94D6-DF944E9A01FD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
    0x98dfc000 - 0x98e08ffa  com.apple.CrashReporterSupport (10.8.2 - 415) <BAE9900A-51E7-3AD4-A7FB-7E6CCFFB2F21> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Vers ions/A/CrashReporterSupport
    0x98e09000 - 0x98e13fff  libsystem_notify.dylib (98.5) <7EEE9475-18F8-3099-B0ED-23A3E528ABE0> /usr/lib/system/libsystem_notify.dylib
    0x98e14000 - 0x98e29fff  com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) <DE68CEB5-4959-3652-83B8-D2B00D3B932D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x98e2a000 - 0x98e30fff  libGFXShared.dylib (8.6.1) <E32A7266-FCDD-352C-9C2A-8939265974AF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
    0x98e75000 - 0x98e87fff  libbsm.0.dylib (32) <DADD385E-FE53-3458-94FB-E316A6345108> /usr/lib/libbsm.0.dylib
    0x98eb3000 - 0x98eb4fff  liblangid.dylib (116) <E13CC8C5-5034-320A-A210-41A2BDE4F846> /usr/lib/liblangid.dylib
    0x98eb5000 - 0x98f9eff7  libxml2.2.dylib (22.3) <015A4FA6-5BB9-3F95-AFB8-B9281E22685B> /usr/lib/libxml2.2.dylib
    0x98f9f000 - 0x98fadfff  libxar.1.dylib (105) <343E4A3B-1D04-34A3-94C2-8C7C9A8F736B> /usr/lib/libxar.1.dylib
    0x98fae000 - 0x992b3ff7  com.apple.CoreServices.CarbonCore (1037.3 - 1037.3) <4571EDDC-704A-3FB1-B9A6-59870AA6165F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
    0x992b4000 - 0x992bafff  com.apple.print.framework.Print (8.0 - 258) <12AEAD24-6924-3923-9E4A-C5D21231E639> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
    0x995a7000 - 0x995a8fff  libremovefile.dylib (23.1) <98622D14-DAAB-3AD8-A5D9-C322BF572A98> /usr/lib/system/libremovefile.dylib
    0x995a9000 - 0x995bffff  com.apple.CFOpenDirectory (10.8 - 151.10) <3640B988-F915-3E0D-897C-CB04C95BA601> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x995c0000 - 0x996beff7  libFontParser.dylib (84.5) <B3006327-7B2D-3966-A56A-BD85F1D71641> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x996bf000 - 0x996bffff  libsystem_blocks.dylib (59) <3A743C5D-CFA5-37D8-80A8-B6795A9DB04F> /usr/lib/system/libsystem_blocks.dylib
    0x996c0000 - 0x996d2ff7  libdispatch.dylib (228.23) <86EF7D45-2D97-3465-A449-95038AE5DABA> /usr/lib/system/libdispatch.dylib
    0x996d3000 - 0x996d6ff7  com.apple.TCC (1.0 - 1) <437D76CD-6437-3B55-BE2C-A53508858256> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x996d7000 - 0x997f3ff7  com.apple.desktopservices (1.7.2 - 1.7.2) <8E74D101-8398-34F1-A463-B4950680A597> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
    0x997fe000 - 0x99802fff  com.apple.IOSurface (86.0.3 - 86.0.3) <E3A4DB0A-1C1A-31E3-A550-5C0E1C874509> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x99803000 - 0x99820ff7  libresolv.9.dylib (51) <B9742A2A-DF15-3F6E-8FCE-778A58214B3A> /usr/lib/libresolv.9.dylib
    0x99821000 - 0x99838fff  com.apple.GenerationalStorage (1.1 - 132.2) <93694E0D-35D3-3633-976E-F354CBD92F54> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versi ons/A/GenerationalStorage
    0x99895000 - 0x998d7ff7  libauto.dylib (185.1) <B2B5B639-6778-352A-828D-FD8B64A3E8B3> /usr/lib/libauto.dylib
    0x998d8000 - 0x9991affb  com.apple.RemoteViewServices (2.0 - 80.5) <60E04F2F-AFD8-3B1F-BF07-8A3A7EABB8E9> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versio ns/A/RemoteViewServices
    0x99982000 - 0x9998ffff  libGL.dylib (8.6.1) <C7A3917A-C444-33CC-8599-BB9CD8C12BC4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
    0x99990000 - 0x999d1ff7  libcups.2.dylib (327) <F46F8703-FEAE-3442-87CB-45C8BF98BEE5> /usr/lib/libcups.2.dylib
    0x9a377000 - 0x9a37bfff  com.apple.OpenDirectory (10.8 - 151.10) <A1858D81-086F-3BF5-87E3-9B70409FFDF6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
    0x9a3bf000 - 0x9a3ecffe  libsystem_m.dylib (3022.6) <9975D9C3-3B71-38E3-AA21-C5C5F9D9C431> /usr/lib/system/libsystem_m.dylib
    0x9a3ed000 - 0x9a444ff3  com.apple.HIServices (1.20 - 417) <561A770B-8523-3D09-A763-11F872779A4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
    0x9a69e000 - 0x9a69effd  com.apple.audio.units.AudioUnit (1.8 - 1.8) <4C13DEA2-1EB0-3D06-901A-DB93184C06F0> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0xb0000000 - 0xb0011ff8 +com.adobe.ahclientframework (1.6.0.20 - 1.6.0.20) <6FB288F2-45FD-E54A-C9A4-A0D0C374FE37> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
    0xba900000 - 0xba91cffd  libJapaneseConverter.dylib (61) <A3F2F55D-E491-3532-A8F6-8D3F2455704F> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
    0xbab00000 - 0xbab21ffc  libKoreanConverter.dylib (61) <39F6BEE7-AE54-3423-B920-2A3573BC9A1A> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
    External Modification Summary:
      Calls made by other processes targeting this process:
    task_for_pid: 2
    thread_create: 0
    thread_set_state: 0
      Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
      Calls made by all processes on this machine:
    task_for_pid: 4869
    thread_create: 0
    thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=147.0M resident=112.1M(76%) swapped_out_or_unallocated=34.9M(24%)
    Writable regions: Total=138.1M written=28.7M(21%) resident=35.2M(25%) swapped_out=0K(0%) unallocated=102.9M(75%)
    REGION TYPE                  VIRTUAL
    ATS (font support)             33.1M
    CG backing stores              3232K
    CG shared images               1216K
    CoreServices                   2352K
    MALLOC                         48.6M
    MALLOC guard page                48K
    Memory tag=240                    4K
    Memory tag=242                   12K
    Memory tag=249                  192K
    Memory tag=35                  7080K
    Stack                          69.6M
    VM_ALLOCATE                   116.5M
    __DATA                         9792K
    __DATA/__OBJC                   256K
    __IMAGE                         528K
    __IMPORT                        100K
    __LINKEDIT                     34.4M
    __OBJC                         1704K
    __OBJC/__DATA                   248K
    __PAGEZERO                        4K
    __TEXT                        112.6M
    __UNICODE                       544K
    mapped file                   121.5M
    shared memory                   308K
    TOTAL                         563.1M
    Model: iMac12,1, BootROM IM121.0047.B1F, 4 processors, Intel Core i5, 2.5 GHz, 8 GB, SMC 1.71f22
    Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 512 MB
    Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333531533642465238432D48392020
    Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333531533642465238432D48392020
    AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x9A), Atheros 9380: 4.0.70.23-P2P
    Bluetooth: Version 4.0.9f33 10885, 2 service, 18 devices, 1 incoming serial ports
    Network Service: Wi-Fi, AirPort, en1
    Serial ATA Device: WDC WD5000AAKS-402AA0, 500.11 GB
    Serial ATA Device: OPTIARC DVD RW AD-5690H
    USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfd100000 / 2
    USB Device: eUSB ORCA Quad Reader, 0x04e6  (Shuttle Technology), 0x0325, 0xfd130000 / 5
    USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0xfd110000 / 4
    USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd120000 / 3
    USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x850b, 0xfa200000 / 3
    USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfa100000 / 2
    USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfa120000 / 5
    USB Device: Apple Optical USB Mouse, apple_vendor_id, 0x0304, 0xfa123000 / 10
    USB Device: Apple Keyboard, apple_vendor_id, 0x0220, 0xfa122000 / 9
    USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 4
    USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0xfa111000 / 7
    FireWire Device: OEM ATA Device 00, G-TECH, 800mbit_speed
    Feb 26, 2013 5:20 PM   in reply to johnpalacio
    You have to apply Extension Manager 5.5.3 update. Apple made some API changes in Lion which causes Extension Manager CS5/5.5 crash. We released Extension Manager 5.0.3 and 5.5.3 update last April to solve this issue. You can apply this update via Adobe Application Manager or download and install http://download.macromedia.com/pub/dw_exchange/extension_manager/mac/A dobeExtensionManager_5_5_3_mul_AdobeUpdate.dmg (which can be found at http://www.adobe.com/downloads/updates/).
