if i select a check box i cant able to get the values in language columns in datagird??.......whats
Feb 12, 2012 11:27 PM
Tags: none (add) #script #action #3<?xml version="1.0"?>
<!-- dpcontrols\ModifyDataGridData.mxml -->
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" width="500"
height="600" >
<mx:Script>
<![CDATA[
import mx.collections.*;
import mx.controls.*;
import mx.events.*;
import mx.utils.object_proxy;
// Add event information to a log (displayed in the TextArea).
public function collectionEventHandler(event:CollectionEvent):void {
switch(event.kind) {
case CollectionEventKind.ADD:
addLog("Item "+ event.location + " added");
break;
case CollectionEventKind.REMOVE:
addLog("Item "+ event.location + " removed");
break;
case CollectionEventKind.REPLACE:
addLog("Item "+ event.location + " Replaced");
break;
case CollectionEventKind.UPDATE:
addLog("Item updated");
break;
// Helper function for adding information to the log.
public function addLog(str:String):void {
// log.text += str + "\n";
// Add a person to the ArrayCollection.
public function addPerson():void {
var s:String;
var l:String;
if(rg1.selected)
s=rg1.label;
else
s=rg2.label;
if(ENG.selected)
l=ENG.label;
else
l=TAM.label;
if(ENG.selected && TAM.selected)
l=ENG.label.toString()+'&'+TAM.label.toString();
ac.addItem({Name:NameInput.text, Age:AgeInput.text,Sex:s ,Languagesknown:l});
clearInputs();
// Remove a person from the ArrayCollection.
public function removePerson():void { // Make sure an item is selected.
if (dg.selectedIndex >= 0) {
ac.removeItemAt(dg.selectedIndex);
// Update an existing person in the ArrayCollection.
public function updatePerson():void {
var s:String;
var l:String;
if(rg1.selected)
s=rg1.label;
else
s=rg2.label;
if(ENG.selected)
l=ENG.label;
if(TAM.selected)
l=TAM.label;
if(dg.selectedItem !== null) {
ac.setItemAt({Name:NameInput.text, Age:AgeInput.text,Sex:s,languageknown:l},dg.selectedIndex);
// The change event listener for the DataGrid.
// Clears the text input controls and updates them with the contents
// of the selected item.
public function dgChangeHandler():void {
var s:String;
var l:String;
if(rg1.selected)
s=rg1.label;
else
s=rg2.label;
if(ENG.selected)
l=ENG.label;
if(TAM.selected)
l=TAM.label;
clearInputs();
NameInput.text = dg.selectedItem.Name;
AgeInput.text = dg.selectedItem.Age;
s=dg.selectedItem.Sex;
l=dg.selectedItem.Languageknown;
// Clear the text from the input controls.
public function clearInputs():void {
var s:String;
var l:String;
if(rg1.selected)
s=rg1.label;
else
s=rg2.label;
if(ENG.selected)
l=ENG.label;
if(TAM.selected)
l=TAM.label;
NameInput.text = "";
AgeInput.text = "";
s="";
l="";
</mx:Script>
<!-- The ArrayCollection used by the DataGrid and ComboBox. -->
<mx:ArrayCollection id="ac"
collectionChange="collectionEventHandler(event)">
</mx:ArrayCollection>
<mx:DataGrid width="450" id="dg" dataProvider="{ac}"
change="dgChangeHandler()">
<mx:columns>
<mx:DataGridColumn dataField="Name" headerText="Name"/>
<mx:DataGridColumn dataField="Age" headerText="Age"/>
<mx:DataGridColumn dataField="Sex" headerText="Sex"/>
<mx:DataGridColumn dataField="Languageknown" headerText="Languageknown"/>
</mx:columns>
</mx:DataGrid>
<!-- Form for data to add or change in the ArrayCollection. -->
<mx:Form>
<mx:FormItem label="Name">
<mx:TextInput id="NameInput"/>
</mx:FormItem>
<mx:FormItem label="Age">
<mx:TextInput id="AgeInput"/>
</mx:FormItem>
</mx:Form>
<mx:Form width="300" height="90">
<mx:RadioButtonGroup id="radiogroup1"/>
<mx:FormItem width="53" label="Sex">
</mx:FormItem>
<mx:RadioButton id="rg1" label="Male" groupName="radiogroup1"/>
<mx:RadioButton id="rg2" label="Female" groupName="radiogroup1"/>
</mx:Form>
<mx:Form x="98" width="304" height="150">
<mx:FormItem label="Languages known" >
</mx:FormItem>
<mx:CheckBox id="ENG" label="English"
<mx:CheckBox id="TAM" label="Tamil" />
</mx:Form>
<mx:HBox>
<!-- Buttons to initiate operations on the collection. -->
<mx:Button label="Add New" click="addPerson()"/>
<mx:Button label="Update Selected" click="updatePerson()"/>
<mx:Button label="Remove Selected" click="removePerson()"/>
<!-- Clear the text input fields. -->
<mx:Button label="Clear" click="clearInputs()"/>
</mx:HBox>
</mx:Application>
