if i select a check box i cant able to get the values in language columns in datagird??.......whats
Feb 12, 2012 11:27 PM
Tags: #script #action #3
<?xml version="1.0"?>
<!-- dpcontrols\ModifyDataGridData.mxml -->
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" width="500"
                height="600" >
    <mx:Script>
        <![CDATA[
            import mx.collections.*;
            import mx.controls.*;
            import mx.events.*;
            import mx.utils.object_proxy;
            // Add event information to a log (displayed in the TextArea).
            public function collectionEventHandler(event:CollectionEvent):void {
                switch(event.kind) {
                    case CollectionEventKind.ADD:
                        addLog("Item "+ event.location + " added");
                        break;
                    case CollectionEventKind.REMOVE:
                        addLog("Item "+ event.location + " removed");
                        break;
                    case CollectionEventKind.REPLACE:
                        addLog("Item "+ event.location + " Replaced");
                        break;
                    case CollectionEventKind.UPDATE:
                        addLog("Item updated");
                        break;
            // Helper function for adding information to the log.
            public function addLog(str:String):void {
    //        log.text += str + "\n";
            // Add a person to the ArrayCollection.
            public function addPerson():void {
                var s:String;
                var l:String;
                if(rg1.selected)
                    s=rg1.label;
                else
                    s=rg2.label;
                if(ENG.selected)
                    l=ENG.label;
                else
                    l=TAM.label;
                if(ENG.selected && TAM.selected)
                    l=ENG.label.toString()+'&'+TAM.label.toString();
                ac.addItem({Name:NameInput.text, Age:AgeInput.text,Sex:s ,Languagesknown:l});
                clearInputs();
            // Remove a person from the ArrayCollection.
            public function removePerson():void {                // Make sure an item is selected.
                if (dg.selectedIndex >= 0) {
                    ac.removeItemAt(dg.selectedIndex);
            // Update an existing person in the ArrayCollection.
            public function updatePerson():void {
                var s:String;
                var l:String;
                if(rg1.selected)
                    s=rg1.label;
                else
                    s=rg2.label;
                if(ENG.selected)
                    l=ENG.label;
                if(TAM.selected)
                    l=TAM.label;
                if(dg.selectedItem !== null) {
                    ac.setItemAt({Name:NameInput.text, Age:AgeInput.text,Sex:s,languageknown:l},dg.selectedIndex);
            // The change event listener for the DataGrid.
            // Clears the text input controls and updates them with the contents
            // of the selected item.
            public function dgChangeHandler():void {
                var s:String;
                var l:String;
                if(rg1.selected)
                    s=rg1.label;
                else
                    s=rg2.label;
                if(ENG.selected)
                    l=ENG.label;
                if(TAM.selected)
                    l=TAM.label;
                clearInputs();
                NameInput.text = dg.selectedItem.Name;
                AgeInput.text = dg.selectedItem.Age;
                s=dg.selectedItem.Sex;
                l=dg.selectedItem.Languageknown;
            // Clear the text from the input controls.
            public function clearInputs():void {
                var s:String;
                var l:String;
                if(rg1.selected)
                    s=rg1.label;
                else
                    s=rg2.label;
                if(ENG.selected)
                    l=ENG.label;
                if(TAM.selected)
                    l=TAM.label;
                NameInput.text = "";
                AgeInput.text = "";
                s="";
                l="";
    </mx:Script>
    <!-- The ArrayCollection used by the DataGrid and ComboBox. -->
    <mx:ArrayCollection id="ac"
                        collectionChange="collectionEventHandler(event)">
    </mx:ArrayCollection>
    <mx:DataGrid width="450" id="dg" dataProvider="{ac}"
                 change="dgChangeHandler()">
        <mx:columns>
            <mx:DataGridColumn dataField="Name" headerText="Name"/>
            <mx:DataGridColumn dataField="Age" headerText="Age"/>
            <mx:DataGridColumn dataField="Sex" headerText="Sex"/>
            <mx:DataGridColumn dataField="Languageknown" headerText="Languageknown"/>
        </mx:columns>
    </mx:DataGrid>
    <!-- Form for data to add or change in the ArrayCollection. -->
    <mx:Form>
        <mx:FormItem label="Name">
            <mx:TextInput id="NameInput"/>
        </mx:FormItem>
        <mx:FormItem label="Age">
            <mx:TextInput id="AgeInput"/>
        </mx:FormItem>
        </mx:Form>
    <mx:Form width="300" height="90">
        <mx:RadioButtonGroup id="radiogroup1"/>
        <mx:FormItem width="53" label="Sex">
        </mx:FormItem>
        <mx:RadioButton id="rg1" label="Male"  groupName="radiogroup1"/>
        <mx:RadioButton id="rg2" label="Female" groupName="radiogroup1"/>
    </mx:Form>
    <mx:Form x="98" width="304" height="150">
        <mx:FormItem label="Languages known" >
        </mx:FormItem>
        <mx:CheckBox id="ENG" label="English"
        <mx:CheckBox id="TAM" label="Tamil" />
        </mx:Form>
    <mx:HBox>
        <!-- Buttons to initiate operations on the collection. -->
        <mx:Button label="Add New" click="addPerson()"/>
        <mx:Button label="Update Selected" click="updatePerson()"/>
        <mx:Button label="Remove Selected" click="removePerson()"/>
        <!-- Clear the text input fields. -->
        <mx:Button label="Clear" click="clearInputs()"/>
    </mx:HBox>
</mx:Application>
    Feb 13, 2012 6:13 AM   in reply to gayathriguru
    Hi gayathriguru,
    You just need to correct the name for Languageknown while inserting object into array collection.
    You have by mistaken written it as Languagesknown instead of Languageknown. (<mx:DataGridColumn dataField="Languageknown" headerText="Languageknown"/>)
    Thanks and Regards
    Pooja Kuber | pkuber@infocepts.com | www.infocepts.com
