I am using:
ColdFusion 9.01
Oracle iPlanet Web Server 7.0.13
Windows 2008 R2 Standard
When I try to use the Web Server Configuration Tool, I get the following message: warning "connectors/nsapi/intel-win64/prebuilt/jrun_nsapi.dll". Could it be an incompatability with the versions of software that I am using? Has anyone successfully configured ColdFusion 9.01 with Oracle iPlanet Web Server 7.0.13?
I can't get past this message (see below).
The wsconfig.log file has the following:
02/14 00:39:57 debug Parsing Sun ONE Web Server (iPlanet) configuration file G:\Program Files\Oracle\WebServer7\https-CFAdmin\config\magnus.conf
02/14 00:39:57 debug Parsing Sun ONE Web Server (iPlanet) configuration file G:\Program Files\Oracle\WebServer7\https-CFAdmin\config\obj.conf
02/14 00:39:57 error connectors/nsapi/intel-win64/prebuilt/jrun_nsapi.dll
java.io.FileNotFoundException: connectors/nsapi/intel-win64/prebuilt/jrun_nsapi.dll
at jrunx.connectorinstaller.JarUtils.extractToFile(JarUtils.java:72)
at jrunx.connectorinstaller.CIUtil.extractConnector(CIUtil.java:274)
at jrunx.connectorinstaller.iPlanetInstaller.installConnector(iPlanetIns taller.java:136)
at jrunx.connectorinstaller.ConnectorInstaller.installConnector(Connecto rInstaller.java:341)
at jrunx.connectorinstaller.ConnectorInstaller.doIt(ConnectorInstaller.j ava:275)
at jrunx.connectorinstaller.ConnectorInstaller.main(ConnectorInstaller.j ava:765)
According to ze documentz, iPlanet is not a supported webserver for ColdFusion. I reckon that's your answer.
Sun™ Java™ System Web Server 7 has been renamed to Oracle iPlanet Web Server since the ColdFusion docs came out. However, I am running the 64 bit version of ColdFusion 9.01 and Oracle iPlanet Web Server is 32 bit. There may be an incompatibility there. I am going to try installing the 32 bit version of CF 9.01 and see if that makes any difference.
