Hello,
I've been meaning to ask for a long time: I often find myself cycling
through the measurement units (CTRL-ALT-SHIFT-U by default), especially
to switch between pts and mm.
Anway, I notice that there seem to be two types of points, or at least,
when you cycle through, to get past pts you have to press twice.
So I'm wondering: what is (is there?) a difference between those two
point measurements? What is the difference? How do I know which is
which? What's the real point? What am I asking? Why am I here?
No, but seriously. Do you know?
Ariel
mpc999 wrote:
Maybe you're seeing Postscript points and traditional points, two choices in units preferences that are very similar.
No, that governs the spacing of the tick marks in rulers that use points. The custom setting is also points, but changes the number of minor ticks between major lines. If you leave it at twelve, you'll be looking at Pica divisions.
Hi mpc999: I also considered that -- but I measured carefully, well
zoomed in, and I saw that there was no difference. I think that's a
choice you make in preferences only (ie Adobe points or Trad points) and
it redefines the points measurement wherever it is used throughout the
document.
Peter, you're right. Selecting custom in the prefs brings up 12pt in the
adjacent box (never noticed those boxes before, never used custom
either). I tried changing custom to 36pts, and lo! that change is
clearly reflected in the ruler when I cycle through the units. So one of
the points is the regular point, and the other is the custom.
But, if I'm guessing correctly, the custom unit IS actually points? It's
just the display on the ruler that changes when you select custom,
right? I guess some people want to be able to easily tick-off every 54th
point or what have you. But the underlying measurement unit remains
points, which is why (at least in CS4) it displays as points (ie all
measurements have the pt suffix).
So in that case Custom is not really the same as the other units.
Because for all other units, if you type 1 in some measurement box,
you'll get different actual lengths; but for custom and points you'll
get 1 point in both cases. Wait, and I guess that the same for inches
and decimal inches too.
Okay, I guess this is making sense. Thanks!
Ariel
