adrianeelise
Trial version of illustrator won't finish installing...
Feb 11, 2012 12:45 PM
Trial version of Illustrator won't finish installing -an error message tells me to close Bridge CS5 but it's not running!  What do I do-I need this for school.  ( All the folders installed but the program itself won't finish installing).  I went to setup exe and did a re-try but got the same message. Need help ASAP !  Thanks!
    Feb 12, 2012 1:49 AM   in reply to adrianeelise
    Yes, it is. Check your task manager and terminate the process.
    Mylenium
    Feb 13, 2012 3:04 PM   in reply to adrianeelise
    Four hours sounds like a long time, but it really depends on the size of the file you're downloading and the type of connection you're using. Here are some guidelines to help give you a sense of what's expected:
    http://kb2.adobe.com/cps/915/cpsid_91596.html#main_How_long_does_it_ta ke_to_download_a_product_
    You might also try disabling startup items, and then restarting your computer and trying the download again to make sure that no programs are running.
    Feb 13, 2012 3:10 PM   in reply to adrianeelise
    Here's a doc which guides you how to close the background process for Bridge which is still running:
    http://kb2.adobe.com/cps/926/cpsid_92664.html
  • Gautham K
    Nov 8, 2010
    Feb 13, 2012 3:32 PM   in reply to adrianeelise
    Hi Adriane,
    I believe this is a duplicate thread for the issue you have posted in http://forums.adobe.com/thread/961889?tstart=0.
    As per our conversation earlier today, the issue you were facing has been resolved.
    Please let us know in case of further issues with the Illustrator trial.
