Locked
1
Playback
Feb 04, 2012 Feb 04, 2012
This question was posted in response to the following article: http://help.adobe.com/en_US/FlashPlayer/LSM/WS6aa5ec234ff3f285139dc56112e3786b68c-7ff5.html
36.3K
Guest
Feb 14, 2012 Feb 14, 2012
Would this help with my system so that AVG would not block my ability to use my updated version of the flash player?
Adobe Employee ,
No, I do not believe this would be relevant in the AVG case unless the website you were visiting specifically uses this feature.  Can you give me more details on why you suspect AVG is interfering with playback?
Chris
Guest
Every time I get to a place on any site, (Yahoo News) the video says that I need to install a Flash Drive and I have Adobe"s latest version installed. I check list of Security on computer and it tells me that AVG has disabled the Video because of a security threat to my Browser.
Wyatt--
Adobe Employee ,
What browser are you using?  When you go to the following page, does it tell you which version you have installed?
http://kb2.adobe.com/cps/155/tn_15507.html
Chris
Guest
Thank -you and I found out That Google Chrome just installed was an additive to the situation.
Wyatt--
Mar 30, 2012 Mar 30, 2012
My webcam's mic works great through comp tests and soundcard tests, but when I use it for tinychat, the mic stays silent even though I allow it and can see the color coded bar go up and down. It was recommended to me that flash was the problem. I dunno what to do.
Adobe Employee ,
Apr 02, 2012 Apr 02, 2012
Hilary,
What version of Flash Player do you have installed?
http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html
Chris
The very latest one. The 11.2 version or something like that.
Adobe Employee ,
What browser and operating system are you using?  Also, what webcamera do you have installed?
Microsoft windows xp professional, sp3. I have a GE camera minicam pro. However, I have gotten other webcams and they have had the exact same problem. I am not sure if it's a site specific problem, although it can't be because everyone else's works.
Adobe Employee ,
Apr 03, 2012 Apr 03, 2012
Does your computer use a proxy server to connect to the internet?  If so, this might be the problem.  In this case, tinychat needs to implement RTMPT, they might be using just RTMP instead which does not support proxy settings.
To verify your microphone is working in Flash player, we'll need to do a local test through the Flash settings dialog.  You can access the Flash settings dialog by right clicking on most Flash content.  For example, right click on the Global Privacy Settings panel and click the Settings menu item.
Then click the microphone tab and you should see the volume level move as you start talking.  If this works, then Flash should be able to use your mic properly given the proper network connections.
Adobe Employee ,
Apr 05, 2012 Apr 05, 2012
Where you able to resolve the mic problems?  I'm also wondering if this could be related to the following garbled sound output bug we have against TinyChat.  If so, could take a minute and cast a vote to get this issue fixed?
Bug 3154302
Chris
Chris, I was able to see the mic work in flash, but when I test my mic in flash it is choppy and weird sounding: distorted. When I test my mic in windows test, it sounds smooth and responsive. So I have no idea what the HELL is going on... I also have another bug with adobe flash in youtube.... Smh..
Adobe Employee ,
When you head the choppy / weird sounding issue with the mic, was that in TinyChat?  If so, then it's probably related to the bug I mentioned.
What's going on with YouTube?
Apr 06, 2012 Apr 06, 2012
Chris, no. When I tested my mic in adobe flash on my computer when beginning a video, it was choppy and broken.
As far as youtube is concerned, when I full screen mode a playlist, the player plays only every other video and not videos in synchronized order the way I set my playlist up. However, when I take it out of fullscreen, it then plays correctly. Someone needs to fix that problem ASAP.
Adobe Employee ,
Apr 20, 2012 Apr 20, 2012
Thanks for the feedback on the microphone.  I believe you should report the playlist problem to YouTube, as it's most likely their issue.
Apr 24, 2012 Apr 24, 2012
ZASHTO PO VREME NA GLEDANE NA KLIP PC MI ZABIVA?
Jun 11, 2012 Jun 11, 2012
hi i have installed the new adobe player 11 on my pc and now i cant stream videos or fb games and youtube videos on my Firefox can you help me thanks.
i have tried the fire fox maintenance service from fire fox website and nothing worked
Adobe Employee ,
Mohamad - Can you try the troubleshooting steps listed in this FAQ and let us know if it helps?
How do I disable Flash Player's protected mode for Firefox?
Jun 26, 2012 Jun 26, 2012
I have the most current version of Flash but have lost internet sounds. The media player on my computer works but I have lost sound on all browsers. What could the issue be?
Jun 30, 2012 Jun 30, 2012
Estou com o mesmo problemas. Alguns vídeos do youtube e todas as tvs online estão sem áudio. Já testei quatro navegadores e em todos o problema é o mesmo. Google Chrome, Explorer, Opera e Firefox. Versão nova do Adobe Flash Palyer 11.
Meu windows é o vista home premium
Aug 24, 2012 Aug 24, 2012
I had similair problem and it ended up being the main sound in programs and features.
When they added several different uaudio players on your system.
ne would play and the other would kick the one playing right off not warrniongs. UnAmerican
Guest
Aug 08, 2012 Aug 08, 2012
Chrome, Windows. When user open my application (this app used p2p) and click Allow on this Peer-Assisted popap (select "remember") http://screencast.com/t/zCAcuafni9 this site(flashstudio.com.ua) doesnt added on Global Settings to this list http://screencast.com/t/zCAcuafni9 so user need click every time Allow... (another app with p2p worked fine)
